w705 unlock problem v0.915045/UNI CARD SERIAL: 00078859 Loaded 51 flash descriptors CFG:00000000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 11 secs. CFG:00000000000000 ChipID:E800,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0053 OTP LOCKED:1 CID:53 PAF:1 IMEI:35180603642436 CERT:RED LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082 LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082 Model (from GDFS):W705 MAPP CXC article: R1EA030 prg1213-8995_ORANGE_RK MAPP CXC version: R1EA030 Language Package: ORANGE-SIGN CDA article: 1223-2681 CDA version: R8A Default article: 1211-9605 Default version: R1EA030 PROVIDER: 234-33 Network LOCKED SECURITY UNITS BACKUP CREATED. Elapsed: 25 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:10110000000000 ChipID:E800,EMP protocol:0401 BOOTROM MODE DETECTED OTP LOCKED:1 CID:53 PAF:1 IMEI:35180603642436 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Elapsed: 25 secs. CFG:00000000000000 ChipID:E800,EMP protocol:0401 BOOTROM MODE DETECTED OTP LOCKED:1 CID:53 PAF:1 IMEI:35180603642436 CERT:RED LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Unlock DONE Elapsed: 16 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:10100000000000 ChipID:E800,EMP protocol:0401 BOOTROM MODE DETECTED OTP LOCKED:1 CID:53 PAF:1 IMEI:35180603642436 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Elapsed: 22 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:10100000000000 ChipID:E800,EMP protocol:0401 BOOTROM MODE DETECTED OTP LOCKED:1 CID:53 PAF:1 IMEI:35180603642436 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Elapsed: 10 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:10110000000000 ChipID:E800,EMP protocol:0401 BOOTROM MODE DETECTED OTP LOCKED:1 CID:53 PAF:1 IMEI:35180603642436 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Elapsed: 9 secs. SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:10010000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 7 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:10110000000000 ChipID:E800,EMP protocol:0401 BOOTROM MODE DETECTED OTP LOCKED:1 CID:53 PAF:1 IMEI:35180603642436 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Elapsed: 9 secs. SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:10010000000000 ChipID:E800,EMP protocol:0401 BOOTROM MODE DETECTED OTP LOCKED:1 CID:53 PAF:1 IMEI:35180603642436 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Elapsed: 11 secs. |
pls tell here what procedure you can do in settings |
use ist three option 1 use server 2 anabel pre loder secority then ulock flash option |
try this in settings tab 1 3 4 tic unlock repair |
sory this is log with i send above use 1,3,4 option thel unlock but tis is error and one time its show unlock done but inser correct sim card pl help |
try restore back up to avoid 5locks then unlock again br venuno |
where is restore back up option |
use ub for unlocking sony ericsone,,,,,,,,,,,,,,,, |
some information if this model is doing with many credits in SetoolBox or UB? |
