08-12-2008, 10:24 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | K800 corrupted gdfs done again by SEtool w/ guide 1. go to emptyboard fill & repair 2. select any db2020 model 3. press "TP STAGE #1". read "instructions" and execute them. or (3a. check the box between the TP STAGE 1 & 2 in order to automatically proceed to tp sage 2 if your TP #1 is ok) 4. press "TP STAGE #2". read "instructions" and execute them. 5. now the the phone is cid49 brown |
The Following 7 Users Say Thank You to Mohsin-* For This Useful Post: |
08-12-2008, 10:24 | #2 (permalink) |
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | 6. staying on "emptyboard fill and repair" write correct gdfs_in_ssw format === now write db2020gdfs_in_ssw_format_CID49_BROWN.ssw"==== 7. if flashing went fine, flash db2020 erom with needed CID = since my otp cid is 51 so i used "DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw", === === warning;=== example if your otp cid is CID51 === do not write erom with lower cid ex..k800_erom_cnv_RED49_BROWN_CID49_DB2020.ssw because you cant flash the phone it gives you an error when you perform fullflash |
The Following 4 Users Say Thank You to Mohsin-* For This Useful Post: |
08-12-2008, 10:27 | #3 (permalink) |
The Following 3 Users Say Thank You to Mohsin-* For This Useful Post: |
08-12-2008, 10:27 | #4 (permalink) |
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | 8. phone now retail and repaired. fullflash phone as usual. |
K800 corrupted gdfs done again by SEtool w/ guide | rea1One | SETool2 | 45 | 04-15-2010 16:52 |
K800 corrupted gdfs done by new SETOOL update | rea1One | SETool2 | 30 | 03-26-2009 08:35 |
K530 corrupted gdfs done w/ SEtool | rea1One | SETool2 | 9 | 09-27-2008 11:58 |
k800 corrupted gdfs can Ub repair it? | kungpaoski | Universalbox | 11 | 03-14-2008 21:33 |
