Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2009 Location: Egypt Age: 40
Member: 995280 Status: Offline Sonork: 100.1582835 Thanks Meter: 91 | v3 Edge Unlocking Problem Please check all [09:17:44 م] Unlocking started - MSS Service Software ver. 1.28 - R3442A_G_0E.43.0AR, Boot:0CF4 Reading data... Phone is powered off Please disconnect phone and connect battery hook (adapter version 3) and not powered (original) USB cable Phone found. Continue... Please connect special testpoint Please hold testpoint connected... Please disconnect special testpoint Flash type: Tyax 16 bit, size - 32 Mb Backing up PDS area... Unlocking started... Critical Error: 159! [09:18:26 م] Error - 40% C:\Program Files\MSS_II_Box\MSS\Backups\Auto\PDS_IMEI35179902 805906_SN099B222501D09590_27.03.10_21.18.mbc |
![]() | #2 (permalink) |
Member: 995280 Status: Offline Sonork: 100.1582835 Thanks Meter: 91 | Problem Solved By doing this Important step when the box asks for this Please disconnect phone and connect battery hook (adapter version 3) and not powered (original) USB cabl u have to take the battery away and connect the Red Hook which on the test point Cable . and phone will ask for connecting the Special test point and use the Yellow One to make perfect Unlock and enjoy using Mss ![]() BR. Zalhaf |
The Following 3 Users Say Thank You to G$m For This Useful Post: |
![]() | #3 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Sep 2007
Member: 587392 Status: Offline Thanks Meter: 6 | V3re [9:49:20 1.28] Switching phone to flash mode... [9:49:41 1.28] Loading RAM Downloader... [9:49:44 1.28] Erasing flash memory... [9:49:45 1.28] Flashing started [9:49:48 1.28] Phone is powered off [9:49:49 1.28] Please disconnect phone and connect battery hook (adapter version 3) and not powered (original) USB cable [9:50:21 1.28] Phone found. Continue... [9:50:21 1.28] Please connect special testpoint [9:50:29 1.28] Please hold testpoint connected... [9:50:34 1.28] Please disconnect special testpoint [9:50:37 1.28] Flash type: Tyax 16 bit, size - 32 Mb [9:50:37 1.28] Backing up PDS area... [9:50:41 1.28] Unlocking started... [9:50:48 1.28] Complete [9:50:48 1.28] [9:50:48] Ok [9:50:48 1.28] C:\Program Files\MSS_II_Box\MSS\Backups\Auto\PDS_IMEI35464503 030171_SN099B1C0910D07550_20.05.10_09.50.mbc [9:50:49 1.28] |
The Following User Says Thank You to serpic For This Useful Post: |
![]() | #4 (permalink) |
Member: 995280 Status: Offline Sonork: 100.1582835 Thanks Meter: 91 | [10:58:19 م] Unlocking started - MSS Service Software ver. 1.28 - R3442A_G_0E.42.04R, Boot:Unknown Switching phone to flash mode... Reading data... Phone is powered off If phone will not power up within 10 seconds, please, reconnect phone cable (and battery if used). If phone will not power up after this, turn on phone in flash mode manually (*, #, PWR) Phone found. Continue... Switching phone to flash mode... Loading RAM Downloader... Erasing flash memory... Flashing started Phone is powered off Please disconnect phone and connect battery hook (adapter version 3) and not powered (original) USB cable Phone found. Continue... Please connect special testpoint Please hold testpoint connected... Please disconnect special testpoint Flash type: Tyax 16 bit, size - 32 Mb Backing up PDS area... Unlocking started... Complete [11:00:41 م] Ok C:\Program Files\MSS_II_Box\MSS\Backups\Auto\PDS_IMEI35464503 019371_SN099B092B04D00550_05.11.10_23.00.mbc زلهف ![]() |
![]() | #5 (permalink) |
Member: 995280 Status: Offline Sonork: 100.1582835 Thanks Meter: 91 | [10:25:58 PM] Unlocking started - MSS Service Software ver. 1.28 - R3442A_G_0E.43.08R, Boot:0CF4 Reading data... Phone is powered off If phone will not power up within 10 seconds, please, reconnect phone cable (and battery if used). If phone will not power up after this, turn on phone in flash mode manually (*, #, PWR) Phone found. Continue... Loading RAM Downloader... Erasing flash memory... Flashing started Phone is powered off Please disconnect phone and connect battery hook (adapter version 3) and not powered (original) USB cable Phone found. Continue... Please connect special testpoint Please hold testpoint connected... Please disconnect special testpoint Flash type: Tyax 16 bit, size - 32 Mb Backing up PDS area... Unlocking started... Complete [10:27:19 PM] Ok C:\Program Files\MSS_II_Box\MSS\Backups\Auto\PDS_IMEI35 ![]() ![]() ![]() ![]() ![]() |
m120 unlocking problem... please check | ryumahon | Z3X-Team Products | 1 | 03-02-2010 06:04 |
V3 EDGE, Unlocking | winston_006 | Motorola P2k | 15 | 04-10-2008 15:10 |
V3 edge unlocking problem | bawheid | Smart-Clip | 4 | 01-18-2008 13:16 |
V3 Edge Unlocked Successfully | jins jisha | Smart-Clip | 0 | 11-09-2007 16:47 |
6131 unlocking problem... please check. thanks! | ryumahon | BB5BOX | 2 | 09-30-2007 19:24 |
