AQUA Dongle A.I.O Module V2.6 SPD Module Enable & Xiaomi Qcom Update 11-07-2020 Aqua-Dongle All-in-One Module V2.6 SPD Module Enable & Xiaomi Qualcomm Update We Are Glad To Announce The Start Of SPD Module eMMc ISP Active MTK Active SPD Active !!! NEW HOT Qcom Active Sam Active Huawei Active Oppo Active Vivo Active MI [Xiaomi] Active SonyActive Activated SPRD Module Daig Mode Supported CPU List is Here SC6820 SC6825 SC7715 SC7730A SC7731C SC7731G SC7731E SC8810 SC8825 SC8830 SC8830A SC8831G SC9830 SC9830A SC9832A SC9832E SC9850 SC9860 SC9863 SC9863A If Any CPU Not Work Then Report Us With Log & Screen Shot We Try To Add Support We Tested Some SPD Unisoc CPU in Daig Mode Activated Diag Mode Option [ Connection Type >> DiagMode ] >>>It Dose Not Require Select Manul BootLoader or (Headche) SPRD Module [Added] SPRD Daig Mode Protocol & Update [Added] Tab Mode To Diag [Added] Device Information -HardWare CPU Information Modem Information >>Build Information, Security Information, SOC Information [Added] Safe Format FS / Factory Reset settings (Not touch FRP) WIPE Data/Cache [Added] DiagMode Switch To and Old Both Protocol Activated [Added] Enable Diag in New Spd Devices [Added] Enable Diag in old Spd Devices [Added] Imei Repair/Read in Diag Mode [Added] Imei1,Imei2,Imei3,Imei4 Safe Repair SPRD Flash Tab AQUA SPD Falsher Like Factory Flasher [Added] SPRD SOC Write pac File [Added] Write Factory Pac File [Added] Auto Extract Full Pac File [Added] Customized Flashing [Added] Skip Partitions [Added] Reparation Option [Added] 2 Modes (Auto/manual) Models Tested QMobile LT200 Read Info /Write Factory Pac File / Enable Diag/ Safe Imei Repair QMobile I6 Metal Read Info /Write Factory Pac File / Enable Diag/ Safe Imei Repair Lava IRIS 51 Read Info /Write Factory Pac File / Enable Diag/ Safe Imei Repair Xiaomi Module Update [Update] Support for UFS Memory Devices [Update] Xiaomi Mi Account Reset [Update] Xiaomi Mi Account Relock Fix [Update] Xiaomi Factory Reset in sideload [Update] Enable/Disable ScreenLocks for Xiaomi - BETA More Detail & Update HERE Best Regard's AQUA Dongle Team (Powered By WorldGsmTelecom) |
