Go Back   GSM-Forum > News Section > Service Products News & Updates
Service Products News & Updates Service Products and Tools New and Updates
Old 12-17-2016, 16:38   #1 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 18,986
ChimeraTool LG | FRP Bypass & Remove on more than 300 models
Dear Forum Members,
ChimeraTool LG module
U
pdate: v 12.33.1729
17/12/2016
Bypass FRP
An FRP (Factory Reset Protection) locked phone will not let you get past the network setup in Android setup wizard.
Our Bypass FRP procedure let you skip the Android setup wizard.
Remember! The phone will still be FRP locked, so the next time you factory reset it, you will be stuck in the setup again, but until the next Factory Data Reset, you can log in to the phone.
After using the procedure, your first thing should do is to start the phone, go to setting, and find and run the following option:
Settings ( -> General ) -> Backup & Reset -> Factory Data Reset.
Issuing the Factory Data Reset from the menu of a logged in Android device should clear your FRP lock. Remember that Factory Data Reset issued from recovery, or any other means does NOT remove the lock.
Skipping the wizard is not normal, and may leave your phone in an invalid state, so some things might not work normally, but any kind of factory reset will fix any problems (remember, only factory reset from the android menu will remove FRP lock!).
How to do FRP unlock with Bypass FRP procedure:
0. Get struck on the android setup wizard.
1. Turn off the phone
2. Press and hold the volume up and connect to the PC. It should start in download mode
3. Run Bypass FRP
4. Restart the phone into normal mode
5. Go into Settings ( -> General ) -> Backup & Reset -> Factory Data Reset. Start the factory reset.
6. Wait for the factory reset to finish.
Bypass & Remove FRP:
  • Stylo MetroPCS ( LG-MS631 )
  • Stylo T-Mobile ( LG-H631MX )
  • AKA 4G LTE ( LG-H788N, LG-H788SG )
  • Escape 2 ( LG-H445, LG-H443 )
  • Escape 3 ( LG-K373 )
  • F60 ( LG-D390N, LG-D390AR, LG-D390, LG-D392D, LG-D393, LG-D390NS )
  • F70 ( LG-F370S, LG-D315, LG-D315S, LG-F370K )
  • Fireweb D300 ( LG-D300F )
  • G Flex ( LG-D959, LG-D956, LG-D950, LG-L23, LG-D950G, LG-D958, LG-D955, LG-D951 )
  • G Flex 2 ( LG-H955P, LG-H955TR, LG-H950PR, LG-H955, LG-H955AR, LG-F510L, LG-H959 )
  • G Flex Sprint ( LG-LS995 )
  • G Flex2 AT&T ( LG-H950 )
  • G Flex2 Sprint ( LG-LS996 )
  • G Pad 2 10.1 ( LG-V935 )
  • G Pad 7.0 LTE ( LG-V410, LG-UK410 )
  • G Pad 7.0 Verizon ( LG-VK410 )
  • G Pad 8.0 4G LTE ( LG-V490 )
  • G Pad 8.0 LTE ( LG-P490L )
  • G Pad F 7.0 ( LG-LK430 )
  • G Pad F 7.0 LTE ( LG-V497 )
  • G Pad F 8.0 ( LG-V496, LG-UK495, LG-V495 )
  • G Pad III 8.0 FHD ( LG-V522 )
  • G Pad X 10.1 ( LG-V930 )
  • G Pad X 8.0 ( LG-V521 )
  • G Pad X 8.3 ( LG-VK815 )
  • G Pro 2 ( LG-D838 )
  • G Stylo ( LG-H636, LG-H634 )
  • G Stylo Sprint ( LG-LS770 )
  • G Vista ( LG-D631 )
  • G Vista ( CDMA) ( LG-VS880PP )
  • G Vista ( Verizon) ( LG-VS880 )
  • G flex 2 ( LG-H955RE, LG-H955A )
  • G2 ( LG-D801, LG-D802, LG-D800, LG-L-01F, LG-D803, LG-D802TR, LG-G2 )
  • G2 3G ( LG-D806 )
  • G2 4G LTE ( LG-D805 )
  • G2 LTE-A ( LG-F320S, LG-F320K, LG-F320L )
  • G2 Lite Dual ( LG-D295 )
  • G2 Mini ( LG-D620R, LG-D620K, LG-D610TR )
  • G2 Mini 3G ( LG-D610AR, LG-D610 )
  • G2 Mini Dual ( LG-D618 )
  • G2 Mini LTE ( LG-D620 )
  • G2 Sprint ( LG-LS980 )
  • G2 isai ( LG-L22 )
  • G3 ( LG-D852G, LG-D855TR, LG-D855AR, LG-D850PR, LG-F460S, LG-D855, LG-D851, LG-D852, LG-D855P, LG-H441, LG-D850, LG-D855V, LG-D855RE )
  • G3 ( CDMA) ( LG-US990 )
  • G3 Beat ( LG-D722AR, LG-D723TR, LG-D722P, LG-D722PA, LG-D723 )
  • G3 Beat LTE ( LG-D722J )
  • G3 Beat LTE-A ( LG-F470S, LG-F470K )
  • G3 Beat TD-LTE ( LG-D722K )
  • G3 Dual LTE ( LG-D856 )
  • G3 LTE-A ( LG-F400S, LG-F400L, LG-F400K )
  • G3 S ( LG-D725PR, LG-D722V, LG-D722 )
  • G3 S Dual ( LG-D724 )
  • G3 Sprint ( LG-LS990 )
  • G3 Vigor ( LG-D725 )
  • G3 Vigor 4G LTE ( LG-D727 )
  • G4 ( LG-H810PR, LG-H815RE, LG-AS986, LG-AS811, LG-H815L, LG-H812, LG-H815AR, LG-F500L, LG-H815TR, LG-H815, LG-F500K, LG-H525TR, LG-H815T, LG-H815P )
  • G4 Beat Dual ( LG-H736P, LG-H736 )
  • G4 Beat LTE ( LG-H735L, LG-H735TR )
  • G4 Dual ( LG-H818P, LG-H818, LG-H818N )
  • G4 LTE ( LG-US991 )
  • G4 LTE-A ( LG-H810 )
  • G4 Sprint ( LG-LS991 )
  • G4 Stylus ( LG-H630 )
  • G4 Stylus LTE ( LG-H635, LG-H635CX, LG-H635AR, LG-H635C )
  • G4 Stylus T-Mobile ( LG-H631 )
  • G4 T-Mobile ( LG-H811 )
  • G4 Verizon ( LG-VS986 )
  • G4 Vigor ( LG-H731 )
  • G4c ( LG-H525N )
  • G4c DUAL ( LG-H522Y )
  • G4s ( LG-H735MT, LG-H735P, LG-H735AR, LG-H735 )
  • G5 ( LG-H850, LG-RS988, LG-F700K, LG-H850TR, LG-F700S, LG-H860 )
  • G5 AT&T ( LG-H820 )
  • G5 LTE-A Specs ( LG-H831 )
  • G5 Lite ( LG-H845 )
  • G5 SE ( LG-H840 )
  • G5 Silver ( LG-H850AR )
  • G5 Sprint ( LG-LS992 )
  • G5 Tmobile ( LG-H830 )
  • G5 Verizon ( LG-VS987 )
  • Isai VL ( LG-V31 )
  • Isai Vivid ( LG-V32 )
  • Isia FL ( LG-L24 )
  • Joy ( LG-H221G, LG-H222F, LG-H222G, LG-H221F, LG-H220 )
  • K10 ( LG-K420PR, LG-K428, LG-K430TV, LG-K420DS, LG-K430T, LG-K430DSY, LG-K420N )
  • K10 MetroPCS ( LG-MS428 )
  • K4 ( LG-K120, LG-K121, LG-K120GT, LG-K130F )
  • K4 4G ( LG-K120E )
  • K5 X screen ( LG-K500TR )
  • K7 ( LG-K330, LG-K332 )
  • K7 4G LTE ( LG-AS330 )
  • K8 ( LG-K350N, LG-US375, LG-K350H, LG-K350AR )
  • Kite ( LG-H221AR )
  • L Fino ( LG-D290AR, LG-D290TR, LG-D290G, LG-D295F, LG-D290N )
  • L35 ( LG-D150G, LG-D150 )
  • L40 ( LG-D160J, LG-D165, LG-D160, LG-D165G, LG-D160F, LG-D160G, LG-D165AR )
  • L40 Dual ( LG-D157F, LG-D170, LG-D175F )
  • L70 ( LG-D320G8, LG-D325G8, LG-D320F, LG-D320J8, LG-D340F8, LG-D320TR, LG-D320N, LG-D325F8, LG-D320AR, LG-D320, LG-D320F8 )
  • L70 Dual ( LG-D325 )
  • L80 ( LG-D375AR, LG-D373EU, LG-D373, LG-D370TR, LG-D370 )
  • L80 Dual ( LG-D380, LG-D385 )
  • L90 ( LG-D415, LG-D405N, LG-D410H, LG-D400H, LG-D410HN, LG-D400HN )
  • L90 DUAL ( LG-D410 )
  • Lancet ( LG-VS820 )
  • Leon ( LG-H342FT, LG-H342F )
  • Leon 4G LTE ( LG-H340AR )
  • Leon LTE ( LG-H340GT, LG-H340F, LG-H340Y, LG-H340N )
  • Leon LTE Metro PCS ( LG-MS345 )
  • Lucid 3 ( LG-VS876 )
  • Magna LTE ( LG-H520G )
  • Optimus F60 MetroPCS ( LG-MS395 )
  • Optimus L65 ( LG-D280F, LG-D285G, LG-D280N, LG-D285F, LG-D280G )
  • Optimus L70 ( LG-MS323, LG-D321 )
  • Optimus Zone 3 ( LG-VS425PP )
  • Phoenix 2 ( LG-K371 )
  • Prime Plus DUAL ( LG-H522F )
  • Realm ( LG-LS620 )
  • Risio LTE ( LG-H343 )
  • Spirit 4G LTE ( LG-H440AR, LG-H440N, LG-H440 )
  • Spirit LTE ( LG-H440F )
  • Spray ( LG-402LG )
  • Stylo 2 ( LG-LS775 )
  • Stylo 2 Cricket Wireless ( LG-K540 )
  • Stylo 2 Plus ( LG-MS550 )
  • Stylo 2 Plus T-Mobile ( LG-K550 )
  • Stylus 2 ( LG-K520TR, LG-K520, LG-K520K, LG-K520DY )
  • Stylus 2 Plus ( LG-K557, LG-K530F )
  • Transpyre Verizon ( LG-VS810PP )
  • Tribute ( LG-LS660 )
  • Tribute 2 ( LG-LS665 )
  • Tribute 5 ( LG-LS675 )
  • Tribute 5 Metro PCS ( LG-MS330 )
  • V10 ( LG-H960P, LG-H960TR, LG-H960ATR, LG-H900, LG-H960AR, LG-H960AY, LG-F600L, LG-VS990, LG-H961N, LG-H960A )
  • V10 T-Mobile ( LG-H901 )
  • Vista 2 ( LG-H740 )
  • Volt ( LG-LS740 )
  • Volt 2 ( LG-LS751 )
  • Volt LTE ( LG-F540L )
  • Wine Smart ( LG-F480S, LG-H410 )
  • X Power ( LG-K210 )
  • X Screen ( LG-K500N, LG-K500Z, LG-K500H )
  • X screen ( LG-K500DSZ )
  • Zero ( LG-H650, LG-H650E )
  • Zero 4G LTE ( LG-H650AR )
  • L25 ( LG-L25 )
  • Leon LTE T-Mobile ( LG-H345 )
More about this ChimeraTool LG update: >> click here <<
The Following 41 Users Say Thank You to Chimera Tool For This Useful Post:
[IMG] code is Off
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f475/chimeratool-lg-frp-bypass-remove-more-than-300-models-2169279/
Posted By For Type Date
ChimeraTool LG | FRP Bypass & Remove on more than 300 models | Tips and Tricks This thread Refback 12-19-2016 05:37
ChimeraTool LG | FRP Bypass & Remove on more than 300 models - GSM-Forum This thread Refback 12-17-2016 16:58
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.17046 seconds with 7 queries
