Service Products News & Updates Service Products and Tools New and Updates |
11-04-2020, 09:12 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.08 - NAND, Forensic and more features As ordinary, unique functions and methods released Core Changed : FlashCore protocol updated Changed : NAND support rebuild Changed : X64 SS/RS loader line handling optimized New SOC : SC9820E with NAND support New SOC : SC7731E with NAND support Flasher Changed : NAND support rebuild Changed : Big files handling optimized Changed : NVM manager updated Firmware reader New Feature : UniSoc NAND SC9820E/SC7731E support activated ! - Allow backup FW from range of phones, based on SC9820E/SC7731E SoC with NAND flash memory - Firmware is complete, not damage any security, ota or any other compatibility Changed : Improved structure identification Changed : Forced reading ( disable deep verify ) option enabled - Use WITH CAUTION! Changed : Android 4.x / Mocor 5 specific changes Changed : UBI defragmentation for NAND devices activated by default Service New Feature : Security Repair allow change BT/WiFi MAC - Useful only in DiagMode for UniSoc(E-line), Flash/Diag for SPRD line Changed : Security Repair options - Generate MAC's - double click at MAC field to generate and activated Changed : Security Repair options - AutoIncremental set SEC2/SEC3 fields, when SEC1 set. Just double click in next field Changed : Security Repair : NVM Manager updated according latest devices changes Changed : Identify : Support identify for UniSoc NAND line Changed : Identify : NAND identify speed increased UserData Changed : Privacy reading types increased to 4 ( +2 new types ) New Feature : UserData DeepVerify and DUMP activated! - Available for users with active Infinity Data Explorer module! - Ignore ALL sprd protocol limitations, which require MEMORY DESOLDER and EXTERNAL MEMORY PROGRAMMER using! - Allow verify and dump COMPLETE USER image for wide range of types and filesystems 1. eMMC with EXT3/EXT4 filesystem. FDE check may differs from Identify! 2. eMMC with F2FS filesystem. FDE check may differs from Identify! 3. NAND with UBIFS. Result image defragmented and prepared for further forensic analyze - Internal checks during dumping make differ, than Identify option, analysis. Even if Identify say FDE - device can be not encrypted. - Ability to resume dumping in case of read fails, can be used much times, as need - After dumping device must be flashed! 1. Get FW or make FW backup from WORKING/GOOD device with complete options if SW asks 2. Complete Flash device or 2. If need revert device to initial state 2.1 : Select FW, uncheck all items ( Rmouse - > Uncheck all ) 2.2 : Select UBOOT/SPL 2.3 : All other settings must be default, not touch anything 2.4 : Flash device Model DB Changed : New generic loaders included, changes some existing once for better compatibility Changed : Generic SC9820E NAND loaders included Changed : Generic SC7731E NAND loaders included QIN QF9 ( QIN1 SC9820E ) - full support : Read/Write FW,Reset Settings,Security,Service - Firmware can be found on support area - Boot key : Call button - Change Lang sequence : Ok, Left, down, ok, 15 times - down, ok, ok, select need language ( English ) Discussion and download links are HERE |
The Following 64 Users Say Thank You to YellowBoss For This Useful Post: |
