mobileEx Service Suite v3.2 revision 5.6 v3.2 revision 5.6, Public-Release #Minor update - MAIN Added, Application Signing system ~ This is new application security improvement ~ Application will check it signatures when needed, this will check unique card id, application version, and signature datetime validity ~ New created signature will be valid for next 6 month after signing ~ It means that after new update, you might need to 'Sign Application' if the current signature doesnt meet the requirement. ~ Before signing request, sw will set system datetime from ntp server if datetime is not correct. ~ Note: Make sure you have set you computer date,time. ~ The application signing system will not work on the computer with invalid date time ! Removed, Ping on server check Fixed, Windows Vista SP2 compability. - NK Added, BB5 RAPU USB Flashing(spesially for new Flash) Added, Dynamic Camera Configuration upload ~ This features located at 'Phone Test->Camera' Added, TIKU CDMA Product Data (PREPAID_CS_TYPE) fix using server calculation ~ This features will consume credit, how much it will take will be displayed once you logged in using 'Dongle Id' ~ The Service tag is 'DCT4 IMEI+PRODUCT DATA' Added, BB5 RAP3NAND Erase User Area in the 'Quick Fix' tab ~ Usefull to fix BLANK/BLINK or doesnt switch on problem. Added, BB5 PA_SL identification from PASUBTOC Added, New CS type info for newer phone Improved, FAST flash routine ~ SW will keep in flash mode when processing image file, means that it will skip boot and loader upload if config from each file is similiar. Improved, BB5 RPL write ~ SIMLOCK_DATA will be uploaded after NPC write, since new BB5 phone will only accept SIMLOCK_DATA if NPC is valid ! Fixed, BB5 'Security block invalid' bug Added, Detailed information for each 'Quick Fix' function. Download from: MXKEY- support area and download page Public discussion for this update in this thread: http://forum.gsmhosting.com/vbb/showthread.php?t=840424 BUY ONLY FROM AUTHORIZED RESELLERS POSTED HERE: http://forum.gsmhosting.com/vbb/showthread.php?t=686432 Best Regards from mr. Manole GSM: +8613077861111 ICQ: 66-11-11 YM: manole4000 MSN: [email protected] SONORK: 100.88888 Web Page: http://www.manole.ro br, |
