LG2G Rocker v1.48 (SLOT12) Released 03.05.2011 LG2G Rocker v1.48 released, 82 models added |
and what about the dead :confused: LG3g modul ? there is to much phones to add .!!!!! i personally never used this fu-ked lg 3g but paid for it :rolleyes:. |
and in this case to use the new update for LG Rocker, in my case I have not even stand up. activation must be paid or not needed? |
Activation string not success Why When I used 50 credits, I enabled the version 03.05.2011 LG2G Rocker v1.48 released with the activation string that gives the support, the software give the message unlimited but on having opened again the version 1.48, surprise, the activation is not unlimited, 50 credits enabled again and began to deduct it again.... but when it came to zero I wanted to turn it to enable and he says to me that activation not success . I bought the LG rocker activations for 99 Euros, ´why it does not allow me to enable again. Legija, Please is possible enable LG2G Rocker v1.48 . Card id:C177ACA726E32DD4. Expires on: 2011-10-12 New LG Rocker activation string is: 6A4391D64159839xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx09831 F29B4CD36C6F2F Best regard Rocker Team. |
Check for new string. There was error with activation strings, now its okay. |
Activation string ok thank you Mr Legija, Activation String ok B.R. |
want to use a program ,LG,Samsung pay ? tHANK YOU |
exist 2 different activation - one is for Samsung phones, other for LGs. |
we already paid for activation long time ago and now we will pay again for activation? update is not good. |
LG C305 telcel error in LG2G Rocker v1.48 (SLOT12) log.. Version : V 1.48 5/13/2011 - 13:00:26 Supported models count in total : 394 Loaded 158 models. Version : V 1.48 5/13/2011 - 13:00:55 Phone model : C305 Please wait ... Phone : C305 Attach USB cable to PC. Connected to \\.\USB1 Detected : USB PMB8810. Phone Found. Loading Boot... CRC is wrong. Boot-loader is active. EBL version: XMM2130_RAM_Bootloader_B9.3_V 1..1 Boot type 0xBB Skip erase feature : Enabled by default. Skip write crc feature : Enabled by default. Erase verify feature : Disabled by default. Compression feature : Disabled by default. Flash: Intel PF38F6070M0Y1CE 128MB CFI stage 2. Start reading. Reading completed in 00:00:02 min. Data not found. Boot Loading Error |
try connect this phone as GU230. |
LG C305... the same result like GU230 no work ... Like GU230 Version : V 1.48 5/13/2011 - 15:14:00 Phone model : GU230 Please wait ... Phone : GU230 Attach USB cable to PC. Connected to \\.\USB1 Detected : USB PMB8810. Phone Found. Loading Boot... Main loader size not accepted. Aborted Boot Loading Error |
ok. use C305 . please check ""skip info" checkbox. check "Read FULL" checkbox. Then press do job button. and put fill flash on 4shared.com |
The same thing here Mr legija can you help . CardID: A9F5AB694B2B0F01 |
The same thing here Mr legija can you help . activation free o pay versiones beta |
