Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Rocker Dongle (By Legija)
Old 05-05-2011, 10:13   #1 (permalink)
RAMA-BEST's Avatar
Member: 1049819
Sonork: kgm
Thanks Meter: 20
rocker server down?
i fail to go to support access when i do it igot this messege
Ooops ! Your IP seems to be changed. I am sorry, but i will not allow You to share sessions. Please use same IP per session.
If You are using proxy, please disable it. wha is this? halp me
Old 05-05-2011, 12:28   #2 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
Your IP is changed. Check with Your ISP.
Old 05-05-2011, 14:05   #3 (permalink)
RAMA-BEST's Avatar
Member: 1049819
Sonork: kgm
Thanks Meter: 20
where to check it ? on my computer or what?
Old 05-05-2011, 14:41   #4 (permalink)
RAMA-BEST's Avatar
Member: 1049819
Sonork: kgm
Thanks Meter: 20
aftar cherging access support now i canbe eble to access and open all softwere acept segem, and that is geven me a messege which i show you above what shuold i do?
Old 05-05-2011, 15:50   #5 (permalink)
RAMA-BEST's Avatar
Member: 1049819
Sonork: kgm
Thanks Meter: 20
it seems to be your server has got a problem, just becouse i said that sometime it works and sometime is not work pls deal with this problem
Old 05-06-2011, 13:14   #6 (permalink)
Member: 924171
Sonork: 1615127:bamu
Thanks Meter: 70
it seems you are using amodem it is your internet connection having aproblem crosscheck on that first
Old 05-06-2011, 15:43   #7 (permalink)
Member: 22542
Sonork: 100.1660285
Thanks Meter: 102
we have been using same modems before they used to work fine it is from these two past weeks not working
Old 05-06-2011, 22:20   #8 (permalink)
Member: 1434103
Sonork: 100.1605070
Thanks Meter: 19
Some ISP change users IP during session time to time. Server security system - block this attempts. Try find ISP which have constant IP during whole session. Some ISP just ask some additional fee for constant IP feature.
And certainly it is not necessary to give dongle to the friends for next PC - one dongle on one computer in at one time.
Old 05-07-2011, 09:46   #9 (permalink)
Member: 22542
Sonork: 100.1660285
Thanks Meter: 102
today it is working and for your information using another pc for sure there is no logic that the dongle should you not work with other pc and that using modems which others say we should not use
Old 05-07-2011, 10:39   #10 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Things are very simple :
1. Once You log in, Your IP is recorded in DB for current session, and cookie is saved in Your browser cache
2. As long Your IP is same during current session, it will work
2. If Your IP gets changed during session, You'll receive error message that IP is changed
In that case, You simply need to create new session with updated IP. (Log in to support again)
There are few ISP-s which use load balancer, meaning this :
- Opening some web page using one IP
- Any download for bigger files are routed trough proxy and redirected to different link
Example :
Your ISP uses Satellite downlink. You log in, and try to download 100MB file, load balancer will try to redirect this traffic trough Satellite downlink - of course download request will come from different IP, thus security script will report an error.
Signal up and down Moc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 09-29-2001 10:57
5110 flashed down the toilet palladine Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-22-2001 16:09
1,4 GB GSM SOFTWARE ON FTP-SERVER tronix GSM Mobile Links 0 03-19-2001 17:58
Nokia link still down?!?! Bads Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 03-15-2001 13:08
need advice on 8810 headset/power down problem goof Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-24-2001 20:56
Page generated in 0.16726 seconds with 9 queries
