![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007 Location: PAKISTAN
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,072 | How to use Universal cable? which color is RX,TX,GND? and how to use USB cable? Thanks... |
![]() | #3 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: P A K I S T A N Age: 17
Member: 190344 Status: Offline Thanks Meter: 280 | here is the tutorial for open cable of vpro,xintel to connect the set follow my instructions: 1. open phone. 2.suppose you find testpoint but there are no marks of rx, tx, gnd,powerkey(unknown rx,tx) 3.sold the open cable in any order or combination 4. attach + ve and -ve power crocodile / clip with the phone +ve and -ve terminals. 5.while holding the power key presss internal define. 6.now open vmtk 5.3 7.press the option you need....read flash,write,format whatever you like. 100% tested by me thousands of time. conditions: 1. phone sholud be member of mtk family. 2. it should not be the one hardware damaged. 3.set should not be short any question? love you all, remember me in prayer. br hamid |
The Following User Says Thank You to biochemistali For This Useful Post: |
![]() | #4 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | @syed tuqeer good questions should be asked openly so that it can help others as well. Q. i donot have vpro/xintel box.i got ve king ,how can i use this method for veking.? answer. supoose you encounter a phone containing mtk cpu.you tried to spy deine but you couldnot detect the phone due to any reason.you can service it with the open cable that is the wire that has at one end bout ten diferent cable not soldered with any connector. you open the phone. phone may be marked/unmarked with rx,tx,gnd,power key.. we donot know which golden circle/test point is rx,tx xintel is really intelligent in the detection of rx, and tx taht is requied for servicing a phone. you need to sold this coloured open cable in any order.no need to remember which colour cable is rx, or tx as xintel will automatically select it.what is you need is >solder the cable on the all available testpoints which may or may not be marked.ok. now you have two methods to detect the phone using veking. 1. first try the the one that is easy/less time consuming. after soldering the wire and connecting the +ve and -ve terminals (red and black cable) with the phone battary terminals . open vemtk 5.3 soft while holding the power key press read info. it will show set is connected or not. in 90% cases you will get sucess. then you can proceed to make back up by read flash, then format or what so ever you like to do. this is the first easy method. second method. connect the phone with the open coloured cable as you did for vemtk easy method. connect +ve and -ve terminals. open ve king soft. while holding the power key press internal define.and while holding the power key open vemtk 5.3 and press read info.in this way you can work/connect the phone .ok any question? br hamid |
![]() | #6 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | we donot need to know neither cable rx, tx nor phone rx, tx because vepro is capable of spy define its self once open cables are attached with phone board and executed the command internal define. so this will be help full fora phone with unknown rx ,tx but having test points on it |
SpiderMan box RJ45 pinouts definition and how to use universal cable | jack-china | SpiderMan | 138 | 11-16-2011 13:28 |
How to use Universal cable for rx & tx??? | adnanskyland | SpiderMan | 3 | 09-13-2011 00:22 |
how to use universal cable pinfinder | malik_moon | Infinity-Box | 3 | 10-14-2009 21:47 |
How To Use Universal Cable | crazy_kamal | CPF-BOX Ⅱ | 4 | 08-20-2009 08:42 |
