Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Ve Box > VE-PRO BOX
Old 03-21-2009, 16:41   #1 (permalink)
Member: 176997
Thanks Meter: 5
extra work from vepro surpport
in the begining of chinese phone flashing and unlocking vepro sit comfortable on top but now seems to be religated i.e cant be compared with the likes of infinity,supper dr.,and co in phone supported or do we need to by another xintel product to get all these support?
Old 03-22-2009, 07:27   #2 (permalink)
mobile_hotman's Avatar
Member: 214340
Thanks Meter: 906
Bro buy other box but not VE_PRO or Xintel_Box bcoz its just dead box cannot even detect any or spydefine,,,,buy like SPIDERMAN,,,
Old 03-23-2009, 02:58   #3 (permalink)
Crazy Poster
Member: 901121
Thanks Meter: 3
what is the error for it ? can you give details so that we can try to solve it .
Old 03-23-2009, 04:53   #4 (permalink)
biochemistali's Avatar
Member: 190344
Thanks Meter: 280
sorry i am not agree with you.i am having infinity,infinity pin finder and xintel.
i have much experience with my xintel pininder and usually i give prefrence to use xintel as pinfinder then as a interface using infinty chinease mircle.
all thing are based on your experince. in 99% cases i found no problems using it as pinfinder.rest of 1 % counts for hard ware troubles.
there is a cable in xintel that is with out jack and it is opemn cable with 12 wires, this is the most importnt cable, do you know its use???
only xintel stops detecting pinout when the + and -ve powers comming out of cables re broken.
to identify u can use 2 ways.
manual: just attach both + nd _ve together and observe for the production of a little spark, if spark not produced its mean +ve or -ve tracks are broken and can be repaired very eaasily??when have problem i will post some video mnual for u.
2ndly, u cn use multivoltmetet on dc to check the voltge of these wires.
only thing is infinity team is much ahead in support and support server, a very rapid updates, onthe other hand xintel to vpreo to vebox and so on keep on changing its some hard ware modiication but no remarkable advancement in chinease miracle softwre.
anyway i love infinity team, i love xintel box my old companion.
br
hmid
Old 03-23-2009, 06:57   #5 (permalink)
Member: 214340
Thanks Meter: 906
br
hmid
Bro Tell STEP by STEP to use Xintel_BOX as interface with chinese miracle as i also have INFINITY_BOX but not pinfinder,,,BR
Old 03-23-2009, 07:30   #6 (permalink)
Member: 190344
Thanks Meter: 280
ok welcome;
1. suppose, u are working with a chin phone that is having mtk cpu.
2.u have vpro/xintel as an interface.
3. conncet vpro and dongel with pc and start the xintel main working software 2.5 to find out pinouts.
4. for that pupose u select the cable according to the pins in the phone jack. suppose u scan define sucessfully and then u set pess set define.keep on pressinf power button/key.
now u check the comport which is being used with xintel(can be seen on the top of xintel software)
5. now u start ininitybox shell and select chinese miracle nd select mt62xx bsed models and press run.
6.now chinease miracle software will start.
7.now u change the comport numberom the comport window of chinease mircle software main first page(that is disp[alyed when u open it)while holding the power key and have selected xintel as an interfaace using xintel cable. now u can start format or flash or unlock the mobile.
this is the way to use xintel cbles and xintel to work with infinity chinease mircle soft.
any other question lso welcome.
br
hamid
Old 03-23-2009, 08:24   #7 (permalink)
Member: 214340
Thanks Meter: 906
Bro Im trying to format LG_KG195 but it cannot spy c the pic
http://g.imagehost.org/0478/LG_KG195.jpg
thanx for gr8 help
Old 03-23-2009, 14:06   #8 (permalink)
Member: 190344
Thanks Meter: 280
why u r not using xintel new version 2.5?
to detect it use cable L5A.
2ndly it is usually detected as follows>
attach cable ,keep on pressing power key and in the window select chip:mtk and then press auto spy define, when pinout detected, in the set define window clear all the rx, tx, gnd, vpp and preesing the power key preess internl define and the open mtk5.2 or infinity soft and do as required.
br
hamid
Old 03-24-2009, 08:26   #9 (permalink)
Member: 214340
Thanks Meter: 906
br
hamid
Bro I'm using ver_2.50 now i tell u that i acted upon ur advice n it detected successfully thanx for that help ,,,but BRo it could read info or format nither with INIFINITY nor with Xintel_Box,,,more help needed,,,
Old 03-24-2009, 10:40   #10 (permalink)
Member: 214340
Thanks Meter: 906
SUCCESSFULLY_FORMATED_MY_LG_KG_195
Bro thanx alot for such gr8 help NOW I MUST say Xintel_BOX is gr8 BOX for chinese models,,,
her is the logs
PL2303 USB To COM9
Found VE-Dongles ...
connect to VE-Dongles!
Ve-Dongles sn:068AEC4D-020011F8
VE-Dongles Ver.:V2.3 Datetime:2007-10
VT-Dongles data success!
READ INFO
open comport:COM9
please turnon your phone ,until connect success(press F4 Abort).
connect to Phone.
CPU model :6226 ( HW_VER: 8A02 ) LG_KG_195
download Boot ...
boot File Ver.:04.02
NOR flash model :[TOSHIBA] TV00578002DABD
NOR flash size:01000000 (16.0M)
NOR flash ID code :00980049 (00000000) [92]
NAND flash model :[TOSHIBA] TC58NWM9S3B
NAND flash size:04000000 (64.0M)
NAND flash ID code :00800095 (00000000) [65]
Int.RAM size:00047000 (0.284M)
Ext.RAM size:00400000 (4.0M)
Bootloader in [NOR] flash
Read flash information operation done!
READ_FLASH
open comport:COM9
connect to Phone.
download Boot ...
baud set:921600
start address :00000000 operation size:01000000
Read flash...
operation done.
elapse:3 min55 sec speed :69 KB/ sec
File save to:C:\Documents and Settings\XPPRESP3\My Documents\LG_KG_195_MT_6226.bin
Phone Lock Password:0000
FORMAT_FLASH
open comport:COM9
connect to Phone.
download Boot ...
Auto format address £؛00E00000 operation len£؛00200000
NOR (auto) format operation ...
>>operation done.
Old 03-27-2009, 05:41   #11 (permalink)
Member: 190344
Thanks Meter: 280
very good, nice to see all logs.
i am here to help for any other matter, on some other day i will write a tutorial for sets which are difficult to detects with xintel like trend 7..... series.
br
hamid
Old 03-27-2009, 05:45   #12 (permalink)
Member: 190344
Thanks Meter: 280
please write briefly what is the proble.
as i am using xintel 2.50 and i am able to format and read using xintel soft and making it interface for infinity also.
br
hamid
Old 03-27-2009, 08:52   #13 (permalink)
Member: 214340
Thanks Meter: 906
br
hamid
HAIMD BHAI it was my second last msg but after this msg i succeeded,,,
thanx for gr8 help
Old 03-27-2009, 11:10   #14 (permalink)
Member: 176997
Thanks Meter: 5
br
hmid
i agree with you vepro works well in place of pinfinder but what of updates and support and i dont think i heard of any agreement btw infinity & vepro so let us all tell vepro to work harder to gain "promotion back to the elite stage"
Old 03-27-2009, 11:25   #15 (permalink)
Member: 190344
Thanks Meter: 280
yes u r right. xintel have to work hard.
Jobs in India, work from home online jobs, Form Filling Jobs From Home, Form Filling pradeep101 Job Opportunities / Vacancies 0 02-01-2010 08:04
Form Filling Jobs From Home, Form Filling Job, Form Filling Work from Home, Online Fo pradeep101 Motorola P2K (USB-Smart) 0 01-16-2010 08:26
Extra money from your opinion- Possible? fahmohd Off Topic Zone 0 08-29-2006 18:05
Page generated in 0.43257 seconds with 9 queries
