01-17-2009, 06:21 | #1 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | new user help so please help for setup and guide how to use thanks |
01-17-2009, 16:07 | #2 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | Quote:
01-18-2009, 08:39 | #5 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | http://www.xintel.com.cn/ box-soft] QT-box V3.7 Update 2009-01-07[box-soft] VEKing V3.3c Update 2009-01-07[box-soft] Xintel-box V2.50 Update 2009-01-07[box-soft] VE-VBOX V2.6 Update 2009-01-07[box-soft] VEKing V3.3c MainSoft 2009-01-07[box-soft] VE-VBOX V2.6 2009-01-07[box-soft] QT-BOX V3.7 MainSoft 2009-01-07[box-soft] Xintel-box V2.50 MainSoft 2009-01-07[ve-soft] VE-INF V3.1 2009-01-07[ve-soft] VESPD V4.0 2009-01-06[ve-soft] VEMTK V4.9 2009-01-05[ve-soft] VEINIF V3.0 2008-12-31 VicEasy Distributor and Resel...2008-02-19·FAQ:vepro sn error,dongle error.... 2008-03-13·how to change language to englis... 2008-03-11·How To Buy 2008-02-21·Xintel Pro Box Configuration Lis... 2008-02-21·Xintel Box Configuration List 2008-02-21·About VicEasy 2008-02-20 |
01-18-2009, 08:47 | #6 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | [quote=syed tuqeer;4069703]and what is difference between vepro and vepro11[/quote] ve box+veboxII Function introduction: 1.The inner purchases USB HOST,can scan USB mobile more fast and exactly. 2.24pin self-defining port, support RXD,TXD,USBD-,USBD+... 3.Online update MCU chips,also the firmware and software can be updated on line. 4.one key detected feature.Support some chips like MTK,used without computer can be directly detected. 5.Scan define can be accomplished by box itself.more fast and efficient. 6.Automatically change the two poles and short-circuit protection function. 7.The function of short-circuit and VCC, GND Scan will be fully showed on. 8.The inner purchases VE dongle,use bran-new crust designed. xintel pro Function: 1. 24pin self-defining port, support RXD,TXD,USBD-,USBD+,VCC,GND,RTS,CTS,DSR,DTR,PULL high ,pull low, inside RXD, inside TXD. 2. The instrument has two USB output connecter 3. adopt the chips which could be updated online and only update the software to update the instrument 4. Change the chips by from fast track; enable you to use the multi-signals at the same time 5. Automatically change the two poles and short-circuit protection function 6.New built-in algorithm, the speed of scan become faster, 90% mobiles can be scan out in a few seconds. 7.You can scan by the internal of the box or by the main soft. 8.The usage of the new intelligence line make the smaller volume and better quality 9.Scan VCC and GND, short circuit function will fully show. 10.With the internal self-developed procedure and cryptographic technique, the brand-new QT soft dog brings you stronger encryption and function. |
01-18-2009, 13:53 | #8 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | http://www.xintel.com.cn/uploadfile/...ox%20V2.50.exe if this link is not working then try the one in the text file. br hamid |
01-18-2009, 14:04 | #9 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | when u install the Xintel-Box V2.50 then see in the installed folder 1. ÐÂÌìÖÇÄÜÒÇ Ê¹ÓÃ˵Ã÷Êé,xintel box user manual 2. a folder named help< ontaining 2 movies i MTK_error ii teach see tgem again and again. if any difficulty we are here with ve pro moderatos and prooduct supportors. |
01-19-2009, 08:20 | #10 (permalink) | |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Quote:
Welcome to uses Vepro box. GuangZhou VicEasy Http://www.Xintel.com.cn find available comport... Comport:COM3 can't connect to box. >>warn:don't connect datacable to phone. i am using this software in cd show Welcome to uses QT-Box. GuangZhou VicEasy. Http://www.VE100.com www.xintel.com.cn find comport and connect to box... comport:COM3 COM3 connect box success. box ver:V1.3 fireware date:2007-12-18 box sn:01-****57 manuf date:2008-01-22 Connecting QT-Dongles! QT-Dongle Sn:******306 - 1200 Reg. Infor.:VicEasy0801 Dongle mainsoft Ver.:V1.0 compile Date:2007-11-23 >>data verify ok,thankyou! please check blue words and help for new main soft thanks in device www.hengwei168.com website but there is no update found | |
01-21-2009, 16:38 | #11 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | updates are there just search. for vproII given link soft ware will not work. hope Http://www.Xintel.com.cn here is that u need |
01-22-2009, 10:05 | #12 (permalink) |
No Life Poster Join Date: Dec 2008 Location: mombasa kenya
Member: 924171 Status: Offline Sonork: 1615127:bamu Thanks Meter: 70 | what to do uninstall ur setup then temporary disable antivirus run then reinstall ur setup and then connect ur box and dongle try everything if okay disconnect and restart ur comp then u will get amessage such as ,one of ur files may make other programes to mulfulction rename it ,please select ignore and continue everything will okay .goodluck |
new user - help to unlock lobster 320 | khem | FuriousGold | 3 | 08-10-2009 15:57 |
New user......Help for NKTEL C3000 | amol_sm | SpiderMan | 4 | 10-15-2008 06:08 |
New User Help needed...U700v. | harim_1981 | Easy-Unlocker | 11 | 07-01-2008 21:31 |
new user help vygisteam | asad_nomy7 | VygisToolbox | 1 | 05-27-2008 00:54 |
Iam a new user. Help me! | alvaroc | Infinity-Box | 13 | 04-27-2007 19:51 |
