Is there anyway to use vepro with rj45 cable n how. hello is there any way to use vepro with rj45 cable as we use in infinity...because sometime vepro cant find correct pinouts (mostly sigmatel cases)..then we can attact direct rx tx gnd which was on board..plzz anyone tell the solution.. |
where is supporter to help us plzzzzz...? |
above all, find tx and rx on the board, then use any two lines of rj45 to connect with them. ..... |
Bonnie_xuan you are totally wrong.seem u have never worked with china mobiles.... right answer is cut any jaf rj45 cable.use as under Red coloured cables is rx ie pin no 2 from left for my cable green tx pin no 3 from left side black gnd pin no 9 from left (while locating number of pins, hold it in the same way , direction u are inserting the cable in the box. understand) br hamid |
no solution till now..................................... |
use infinity/furious/uni r45 open cable rx7 tx8 this is for ve-pro rj45 port... gud luck br |
no support in this section from ve...plz reply supporter...if there is no rx tx define on charging jeck how we format the set...???? |
i think there is no way to connect vepro with infinity |
i hvnt ask how to connect vepro with infinity. plz read carefully... |
use this pinouts of rj45 connector. 100%worked. http://www.freeimagehosting.net/uploads/5c65eb5249.jpg |
this is for infinity box....not for vepro..as infinity hv 8 pin adoptor and vepro hv 10pin adoptor.. |
No confusions, no difficulties>>>> Just get a "RJ45 Female" connector and connect any 8 wires of "RJ48 Cable" which is shipped with your vepro box. Now your RJ48 connector is converted to RJ45. Tested by me, I am using Infinity Box cables through this RJ45 converter. BEST OF LUCK. yawarniazi |
PM the product supporter... |
plz give me ur yahoo id yawarniazi. |
plz supporter give RJ45 pinouts definition for vepro box as spiderman box has discribed for there box.. http://forum.gsmhosting.com/vbb/showthread.php?t=483651 |
