08-07-2008, 03:10 | #4 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 811759 Status: Offline Thanks Meter: 14 | First, choose the Repeat Scan, while comport scan If not find pin out, please find the welds on the mobile board. Direct short Power A, you can find one CUP, and the same operation with Power B, and then you can find the other CPU |
The Following User Says Thank You to Bonnie_xuan For This Useful Post: |
08-21-2008, 03:28 | #6 (permalink) |
Member: 811759 Status: Offline Thanks Meter: 14 | Two methods: One method: choose the “Repeat Scan”, while comport scan. Second method: If the first method can not help you to find pin out, then you should try to find welds on the mobile board. Take something for example: one mobile board have eight welds, including RX_A,RX_B,TX_A,TX_B, POWER_B, POWER_A,GND, VBAT…… find a line which can be electrified ,one side connect with POWER_A, the other side connect with GND, and carry out your operation, then you can find the main CPU of your mobile phone, the same operation with POWER_B and GND, and you can find another CPU. Now, are you clear? Last edited by Bonnie_xuan; 08-21-2008 at 03:36. |
can spider man fix mtk 2 cpu or its just a toy | obama2 | SpiderMan | 2 | 01-01-2010 20:15 |
mtk 2.cpu 6205 6223 imei repair 100/1000 tested | turkcellgsm | VE-KING | 0 | 10-30-2008 12:31 |
