Solution : HOW TO FIND PIN OUT in SPD CPU How To Find Pin out with Ve_king http://www.bestncheap.net/FILE/veking1.JPG 1. Run Ve-king s.w and then go to SCAN TAB 2. In Scan Tab, chose USB SCAN 3. Change to 6600M CPU 4. Select Correct Pin 5. Clip Negatif/Black Cable to Battery (-), then click scan Power. s.w will find GND position. http://www.bestncheap.net/FILE/veking2.JPG 6. Remove Clip and put on battery. Then Press SCAN USB. s.w will find USBDM- and USBDP+ 7. Move to tab DEFINE 8. If u want save the setting, in DEFINE TAB, Chose 18USB. 9. Write your model phone 10. Press save. So next time if got same phone dont need to find USB pinout again. 11. Then Press SET Define. Then we can use the s.w Thank for Mentari/Along for made indonesian version.. i just translate to english version. BR bNc |
I Have Use Many Box For Chine Pnone Pinfiner Like Infinity,vepro,mss {mtk Cpu} Pin Find Working But {speadtrum Cpu} Not Pin Finding , Ve King Is Working FOR {SPREADTRU CPU} I Use This Box ITS GREAT WBR RICKY RAYYA |
How To Find Pinout How To Find Pinout Hitech H39 And Nokia N95 Singgle Card Use Usb Or Pin 18/24 Thanks |
your phone is MTK based cpu. use Comport Scan, and use VEMTK soft. |
2 Attachment(s) TRY **** box for spreadtrum chip pinfinder scan com scan usb scan udisk scan charger scan usb boot (spreadtrum ) |
Is it another box from VE GROUP? |
No.UP box is not ve box. |
1 Attachment(s) While I scaning spd cpu 6600D5-180 this error msg came.See pic. |
@cellbhai U Need Ve-king New Spreadtrum Solution Vepro Cant Work On Spreadtrum Thanks |
Almost Model Of Spreadtrum Supported In Veking Thanks |
usb spy is for 6600m/r BR. |
1 Attachment(s) @Sir Mentari.!!! Could U help me with this.??? I new user of them, just bought last days :D.. When I try search for N95, choose selected on Scan -> Comport Scan -> PC Scan. Error like this after got RX TX :confused:.. Are there any wrong procedure or other missed by me.??? :confused:.. |
then after success find you must unplug all cable immediately, save the cable and use battery for read/write flash or format operation. br. note : also you can try another spy method, like mtk spy, and box scan. |
