Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 07-04-2009, 15:13   #1 (permalink)
PhoneCareCenter's Avatar
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
Bypass T-Mobile G1 Google Activation by PhoneCareCenter
This Guide is for Customers who got Unlock Code but stuck with Google Activation Screen.
You must have either RC29 or earlier, or Modded RC30.(RC29 is US firmware, RC7 is UK firmware) If U have higher
Versions like (RC33 US firmware or RC8 UK firmware) then u Need to Downgrade.
To Check Firmware Version Do the following without Sim
<enter>reboot<enter>
If Phone Reboots then u have version RC29 or Lower, Skip Upgrading/Flashing Procedure.
(Flash your phone to RC29/RC7 or lower to be able to Exploit Root Access)
Step 1- Format the SD card to FAT32 (Make Sure of this, otherwise it wont Work.
Step 2- Unzip the RC29 or RC7 image file (DREAIMG.nbh) to the SD card & Rename it to (DREAIMG.NBH)
Step 3- Switch Off the Device then Insert the SD card.
Step 4- Now U have to Put your G1 in BootLoader Mode (Hold Down Camera Button, and press Power Button) DO NOT DO ANYTHING TO INTERRUPT THIS PROCESS.
Step 5- Press Power button to Start Upgrade/Flashing Procedure.
Step 6- Once its done, Reboot your G1.
For Those with RC29 or Earlier Versions, Just Follow The Below Guide.
You must have ADB installed on your Computer (Extract to C: Drive), Download & Install the USB drivers. U can Manually Install when Computer Asks for the Drivers once U Connect your G1.
1- Plug your G1 & Install Drivers.
2- Without Sim Card in Your G1, <enter>setprop persist.service.adb.enable 1<enter> Even though u dont see what u typing, but u are actually executing a Command on your G1 to Enable USB Debugging in Settings.
3- Once u Execute that Command USB Drivers will be Installed again, but this time will be recognised as ADB Interface.
4- Click Start>Run>cmd> to Command Prompt
5- Type c:\adb devices (If your Device is Connected u will see it)
6- Restart your G1 but now With Sim, to see the Activation Screen then Plug USB Cable & Type c:\adb devices (to make sure u are connected)
7- Type c:\adb shell (U will see a $ sign) Just Copy & Paste this into Command Prompt (am start -a android.intent.action.MAIN -n com.android.settings/.Settings) The Settings Screen will Appear, now Switch on Wi-Fi & Connect to the Internet.
8- Now u can either Login with your Existing or Create New Account with Google.
PhoneCareCenter
Monrovia-Liberia
McnPro Team
Good Luck
"Get your Codes from allGSMUnlock Server, Contact AtrixJ (MY GOOD FRIEND)for Credits, Contact me if u have any problems with this Guide & Pls no $tupid Talk like its Not working. Tested on my Personal Phone like 10 times before I made this Guide. Took me 5 hours the First Time, now takes less than 10minutes."
The Following 113 Users Say Thank You to PhoneCareCenter For This Useful Post:
Old 07-04-2009, 15:25   #2 (permalink)
Member: 1024839
Sonork: 100.1592057
Thanks Meter: 64
very good information mate have u tested
The Following 3 Users Say Thank You to bluerays For This Useful Post:
Old 07-04-2009, 15:27   #3 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
yes it's tested by me many times
The Following 2 Users Say Thank You to amanvir For This Useful Post:
Old 07-04-2009, 15:39   #4 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
Sure, if u follow Exact Details......
The Following 4 Users Say Thank You to PhoneCareCenter For This Useful Post:
Old 07-05-2009, 04:53   #5 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@amanvir
When U say Many Times, How Many Exactly????? Am Interested to know, cuz I havent Seen u're Guide.
McnPro Team
The Following 2 Users Say Thank You to PhoneCareCenter For This Useful Post:
Old 07-09-2009, 07:27   #6 (permalink)
Member: 221355
Thanks Meter: 25
Could you make a video of this procedure? I understand most parts, but I get confused with some of the instructions. Thanks.
The Following User Says Thank You to Zukison14 For This Useful Post:
Old 07-09-2009, 19:32   #7 (permalink)
Member: 199538
Thanks Meter: 54
I don't undestand exactly what's mean ENTER-REBOOT-ENTER without SIM ... what is that,, when phone On or OFF ??? ,, what key is reboot ... more details please ..... thanks ...
i need to check my firmware for continuos working in desactivate this google activation.. waiting for your help and thanks
The Following User Says Thank You to humbedj For This Useful Post:
Old 07-10-2009, 01:17   #8 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@Zukison14
Guide/Instructions are clear, wat exactly u dont understand?? Details of where u get stuck will be ok for me to help u.
@humbedj
When Phone is on and without sim, on the keyboard Press Enter> then Type R E B O O T> then press Enter. If phone Restarts then u're good to go, if not then u gotta follow Flashing Instructions before u Attempt the 2nd Instructions.
Good Luck
The Following 9 Users Say Thank You to PhoneCareCenter For This Useful Post:
Old 07-10-2009, 07:46   #9 (permalink)
ryumahon's Avatar
Member: 4021
Thanks Meter: 782
hi there...im having problem with steps 6-8.... mine i think is a newer version coz it doesnt reboots if i try enter reboot enter
now my problem is... when the first time i plug my android, it detects as usb storage.. so i updated d driver and it became, ADB under it is HTC DREAM.... i suppose that im doing it right coz when i go to CMD PROMPT and type ADB DEVICES... it responses and shows something like DAEMON has started...
and now according to step 6.. i should reboot my phone with sim in it.... now here comes the problem... when i power on the android with sim in it, should i press the ANDROID LOGO so that it would continue to SET UP OF GOOGLE ACCOUNT?? before i connect the USB CABLE??
coz after rebooting the G1, it wont detect to command prompt ADB DEVICES anymore (BUT if i check my device manager still there is ADB DEVICE connected and in it is HTC DREAM)... it says NO DEVICES ATTACHED... no matter how i retry.... so i cant continue to step 7-8...
please guide me...
thanks alot!!!
The Following 2 Users Say Thank You to ryumahon For This Useful Post:
Old 07-10-2009, 12:06   #10 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@ryumahon
Your G1 is a New Version, u have to follow Flashing Procedure so u can <enter>rebot<enter>. If u did that already, then Insert a Sim into the G1 & go to the Screen where u will be asked (New User/Existing User) then Plug your G1 and continue Step 6-8 (If it says Devices not Connected, just Retype it again Unplug then Replug your Device)
Post your Result
Good Luck
Old 07-10-2009, 13:21   #11 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
on ur phone keyboard press enter button than type REBOOT n press enter again, if its restart that mean u have rc29 or rc7 firmware. if not restart, u have to downgrade it first
The Following User Says Thank You to amanvir For This Useful Post:
Old 07-10-2009, 13:30   #12 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@amanvir
AM sure u can see that it has been Answered Here
The Following User Says Thank You to PhoneCareCenter For This Useful Post:
Old 07-10-2009, 14:02   #13 (permalink)
Umair Rashid's Avatar
Member: 421117
Sonork: +92 346 5544377 (PHONE)
Thanks Meter: 2,522
nice to see ur post .
just one noob question .
how to flash it ?
where to get firmware ,rom etc?
The Following User Says Thank You to Umair Rashid For This Useful Post:
Old 07-10-2009, 20:48   #14 (permalink)
cover_one's Avatar
Member: 97299
Thanks Meter: 43
have formated the sd card fat 32
copyed DREAIMG.nbh to sd card renamed to DREAIMG.NBH
powered off phone inserted sd card
put phone in BootLoader Mode
Looading checking
then i gut that error
00028002
not allow
any ideea ?
The Following 2 Users Say Thank You to cover_one For This Useful Post:
Old 07-10-2009, 20:53   #15 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@cover_one
Make sure u are using US Version for US Phones & UK Versions for UK....
Post Result
Good Luck
The Following 3 Users Say Thank You to PhoneCareCenter For This Useful Post:
Bypass T-Mobile G1 Google Activation by PhoneCareCenter PhoneCareCenter HTC Android based 20 08-01-2013 11:43
Bypass T-MOBILE MYTOUCH GOOGLE ACTIVATION SCREEN kdaviator Android based Phones / Tablets 8 11-01-2011 14:29
Compatible USB Battery Cradle for T mobile HTC Dream G1 Google Android Phone IPMART ipmart WebShop 0 05-08-2009 01:50
[22-10-08] T-Mobile G1 (Android) supported by IMEI UnlockBase.com UnlockBase 1 10-24-2008 22:26
Page generated in 0.28328 seconds with 11 queries
