HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
07-18-2014, 18:25 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | [Guide] HTC ONE Hboot 1.57 Root S-Off Change CID Downgrade Hboot & OS Strp - 1 Bootloader Unlocking First We Need To Unlock Bootloader Use Any Good Tool Or Htcdev(dot)com Website For Bootloader Unlocking if You Dont know how Use Search Function You Will Find Many Post About How To Unlock Bootloader Also On Google Too. Step - 2 CWM Flashing & Root After Unlock Bootloader We Need To Flash Custom Recovery For M7_UL TWRP Recovery Is Best So Put Phone in Fastboot Usb Mode & Open Command Windows In Adb Folder & Put TWRP Recovery in adb Folder Too Now Use Command fastboot flash recovery TWRP-recovery.img After Successfully Write TWRP Now Reboot Handset In Normal Mode And Copy Super-Su.Zip Into Handset Internal Memory & Again Go Into Recovery Mode And Select install Option From Recovery Home Menu And Select Super-Su.zip From Internal storage And Flash. Now Reboot Handset To Normal Mode And Go Application Menu & Open Super Su App It Will Gives You 2 Options Flash Super su Normal Mode Or Via TWRP Select TWRP (Important Otherwise Super SU Not Install) Now Wait handset Will Reboot Into TWRP And Installing Super SU After Installation Handset Will Reboot Into Normal Mode Now Check Super SU Installed & Fully Working You Are Done Handset Now Rooted & TWRP Installed Step - 3 Flash Custom Rom & Kernel If You Need S-Off On 4.4.2 Hboot 1.57 For Flashing Custom Rom If You Need S-Off On 4.4.2 Hboot 1.57 You Need To Copy cm-11-NIGHTLY-m7ul.zip + CM11-Kernel-For-S-Off.zip Into Ur Handset Internal Memory After Copy zips Go Into TWRP Recovery & Wipe Data , Cache , Delvik Cache After Format Now Select Install Option & Select cm-11-NIGHTLY-m7ul.zip First Now Click On Add More Zip Option & Select CM11-Kernel-For-S-Off.zip & Flash Wait Until Flashing Done When Flashed Successfully Dont Reboot Handset Go Back Recovery Home Menu & Select Reboot Option And Select Reboot To Bootloader Option You Will See Again Handset Again On Fastboot USB Mode Now Again Open Command Window In ADB Folder & Copy boot.img Into ADB Folder. Now Use This Command fastboot flash boot boot.img After Successfully flashed boot.img Use Command fastboot reboot Handset Will Reboot Into Normal Mode You Are Done Custom Rom Installed + Custom Kernel For S-Off On 1.57 Step - 4 Firewater S-Off On 4.4.2 Hboot 1.57 M7_UL After Flash Custom Rom & Custom Kernel Now you can S-Off Ur Handset With Firewater. Go Into Setting / About device / Software information / More Baseband Information / Tape 7 To 8 Time On Build Number\Version Developer Mode Enable On Ur Handset Now Go Back To Main Setting Menu & Select Developer Mode And On USB Debugging Go Back Main Setting Menu And Select Super SU Option Now Go Into Super Su Setting & Change Super Su Permission Only Apps To Apps & ADB Now Open Command Window In ADB Folder & Copy Firewater In ADB Folder And Use Commands Like This adb reboot <–important!!!! Means Must Use This Command First adb wait-for-device push firewater /data/local/tmp adb shell su chmod 755 /data/local/tmp/firewater /data/local/tmp/firewater Answer Yes With Capital Y And Wait Till It Says Your Device Is S-OFF Dont Touch Ur Device During This Process You Will Get Msg ur Device is Now S-Off Congratulations You Are Done With S-Off Want To See ? Go Into Bootloader You Will See S-Off There Step - 5 Changing CID To Any Or Super CID After S-Off After S-Off Changing CID Is Very Simple & Easy Put Handset Into Fastboot USB Mode. Open Command Windows In ADB Folder And Use 1 Simple Command For Changing CID To Any Other You Want or Super CID For Super CID fastboot oem writecid 11111111 Or Any Other Just Replace 11111111 To Any Like HTC__001 ETC After Successfully Change CID Use This Command fastboot reboot-bootloader Handset Will Reboot Into Bootloader Again & Your Handset CID Now Changed You Are Done This Step Step - 6 Downgrade Hboot From 1.57 To Any Older After S-Off For Downgrade OS Version After S-Off Downgrading Hboot Is Also Very Simple & Easy If You Want To Use Any Older Version. You Need Ur Required hboot Firmware zip And ADB Package. Put Handset Into fastboot USB Mode And Copy hboot Firmware Zip Into ADB Folder Now Open Command Window In Adb Folder And Use This Command fastboot oem rebootRUU Ur Handset Will Go Into RUU Mode Now Use Command As Ur Choice Of Hboot Version Witch You Want fastboot flash zip hboot-1.43.zip If 1.44 Then fastboot flash zip hboot-1.44.zip If 1.54 Then fastboot flash zip hboot-1.54.zip If 1.55 Then fastboot flash zip hboot-1.55.zip If 1.56 Then fastboot flash zip hboot-1.56.zip After Successfully Flashed Zip Now Type Command fastboot reboot-bootloader Handset Rebooted To Bootloader Again Now Check ur Hboot Version Downgraded & You Are Done With Hboot Now Use This Post If You Want Downgrade M7_UL Stock Roms http://forum.gsmhosting.com/vbb/f485...loads-1677358/ All These Files Are In 1 Package Download With Resumable Link In This Zip All Things Have Witch You Need Custom Rom , Custom Kernels , Firewater , TWRP , Super-Su , hboot zips Download Click Downlad Link Below HTC One M7 4.4.2 S-off.zip Br, ..::Rizwan::.. Last edited by ..::Rizwan::..; 07-18-2014 at 18:34. |
The Following 8 Users Say Thank You to ..::Rizwan::.. For This Useful Post: |
07-19-2014, 23:36 | #2 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2225573 Status: Offline Thanks Meter: 0 | Hi Rizwan, Thanks very much for your tutorial. I'm stuck though, after all the steps, my adb shell exits with no messages while firewater is chugging the first bottle. The phone reboots, but still s-on. Any ideas?? |
07-20-2014, 00:47 | #3 (permalink) |
Member: 2225573 Status: Offline Thanks Meter: 0 | Ok, I was able to finally get this to work. Some info in case it helps anyone: HBOOT 1.57 T-Mobile One M7 cm-11-20140106-NIGHTLY-m7tmo teaMseven_v57_CM11_CPUQUIET_BACK_MENU_HOME Did as above, although firewater failed the first few times. I rebooted and kept trying, third time was successful. My phone is now s-off |
08-25-2014, 18:23 | #5 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2072045 Status: Offline Thanks Meter: 0 | Hi guys. Will this work on one m7-ul , android 4.4.3, hboot 4.4.3 ? I have tried before but I always get the same message from firewater... It goes from bottle 1 to 12, and it always says this bottle is empty, trying bottle number (x) and so on, and in the end it tells me all bottles are empty and that I should restart my device and try again... I tried doing this on 2 different computers,and used 2 different usb cables... I have also tried all kinds of combinations of kernels and roms... I have root, unlocked bootloader and custom recovery.. I havent yet tried that combination from first post.. Please tell me why do I get from bottle 1-12 without getting s-off. Thanks in advance |
09-20-2014, 08:59 | #7 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
br allumts | |
09-20-2014, 10:10 | #8 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: Motalib Plaza,Dhaka,Bangladesh Age: 39
Member: 485407 Status: Offline Sonork: 100.1580486 Thanks Meter: 183 | Quote:
Is it all about hboot? Let's talk about hboot 1/54.0000, M7_WLJ , S-ON You can't unlock bootloader from htcdev Can you please tell/guide how to s-off this crap (HTL22..One from AU JAPAN)? | |
11-11-2014, 06:17 | #14 (permalink) |
Freak Poster Join Date: Apr 2013 Location: PAP-Haiti Age: 36
Member: 1914596 Status: Offline Sonork: 100.1619364 Thanks Meter: 59 | HTC One SPRINT 4.4.2 HBOOT 1.57 Unlocked Yes i tryed to downgrade and unlocked this htc sprint You can contact me here to helpful you will get successfully : 1-Unlocked Bootloader 2-S-OFF 3-Downgrade 4-Sim Lock removed and if you want 5-Update to 4.4.2 |
