HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
09-28-2016, 09:46 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: Slovakia
Member: 272319 Status: Offline Thanks Meter: 99 | HTC Desire 820G Dual SIM (D820i) (A50MGP_DUG) CID change If yes how, generic HTC MTK code doesnt work on this model #243# Thanx in advance. |
10-03-2016, 10:46 | #8 (permalink) |
Member: 272319 Status: Offline Thanks Meter: 99 | Phone have fastboot mode, but seems that oem commands are not allowed. So no solution for this phone right now? Code: h:\adb-htc>fastboot getvar all (bootloader) partition-size:userdata: 32000000 (bootloader) partition-type:userdata: ext4 (bootloader) partition-size:cache: 2c000000 (bootloader) partition-type:cache: ext4 (bootloader) partition-size:system: 80000000 (bootloader) partition-type:system: ext4 (bootloader) partition-size:expdb: d60000 (bootloader) partition-type:expdb: raw data (bootloader) partition-size:cota: 3200000 (bootloader) partition-type:cota: ext4 (bootloader) partition-size:ebr2: 80000 (bootloader) partition-type:ebr2: raw data (bootloader) partition-size:logo: 800000 (bootloader) partition-type:logo: raw data (bootloader) partition-size:misc: 80000 (bootloader) partition-type:misc: raw data (bootloader) partition-size:sec_ro: 600000 (bootloader) partition-type:sec_ro: ext4 (bootloader) partition-size:recovery: a00000 (bootloader) partition-type:recovery: raw data (bootloader) partition-size:boot: a00000 (bootloader) partition-type:boot: raw data (bootloader) partition-size:uboot: 60000 (bootloader) partition-type:uboot: raw data (bootloader) partition-size:seccfg: 40000 (bootloader) partition-type:seccfg: raw data (bootloader) partition-size:protect_s: a00000 (bootloader) partition-type:protect_s: ext4 (bootloader) partition-size:protect_f: a00000 (bootloader) partition-type:protect_f: ext4 (bootloader) partition-size:nvram: 500000 (bootloader) partition-type:nvram: raw data (bootloader) partition-size:pro_info: 300000 (bootloader) partition-type:pro_info: raw data (bootloader) partition-size:ebr1: 80000 (bootloader) partition-type:ebr1: raw data (bootloader) partition-size:mbr: 80000 (bootloader) partition-type:mbr: raw data (bootloader) partition-size:preloader: 40000 (bootloader) partition-type:preloader: raw data (bootloader) kernel: lk (bootloader) product: LCSH92_CWET_HTC_KK (bootloader) version: 0.5 all: Done!! Code: h:\adb-htc>fastboot ? usage: fastboot [ <option> ] <command> commands: flash <partition> [ <filename> ] write a file to a flash partition erase <partition> erase a flash partition getvar <variable> display a bootloader variable getfb <filename> get frame buffer boot <kernel> [ <ramdisk> ] download and boot kernel devices list all connected devices reboot reboot device normally reboot-bootloader reboot device into bootloader help show this help message version show Version num dump emmc <filename> <start sector> <sector number> dump the emmc content to the specified file dump ram <filename> <start address> <size> dump the memory conten t to the specified file duplicate <partition> <source SN> <target SN> duplicate the specific partition from source device to target device options: -d disable the auto resend function for Hboot pre-update -w erase userdata and cache -s <serial number> specify device serial number -p <product> specify product name -c <cmdline> override kernel commandline -i <vendor id> specify a custom USB vendor id -b <base_addr> specify a custom kernel base address -n <page size> specify the nand page size(Bytes). De fault: 2048 -m <memory usage> specify the Max. memory usage(1~50MB) for zip flashing. Default: 2 |
The Following 2 Users Say Thank You to janda For This Useful Post: |
10-15-2017, 21:32 | #10 (permalink) | |
Junior Member Join Date: Feb 2009
Member: 970365 Status: Offline Thanks Meter: 0 | Quote:
same problem here..did you find a solution? | |
