Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 10-20-2014, 09:11   #1 (permalink)
Member: 509921
Thanks Meter: 24
how to flash desire 310 mt6582
hi
i have one desire 310 i download firmware but i can`t flash with sp flashtool
when i try flash with flashtool ,i have error 2004
i tested with many version of flashtool
Old 10-20-2014, 15:55   #2 (permalink)
Member: 509921
Thanks Meter: 24
Originally Posted by gunit1 View Post
try with the link
this phone is mtk based and don`t have hboot
i think this phone only flash with sp flashtool but when i flash with sp flashtool i se error 2004 (mean sp flashtool not match with phone)
Old 01-14-2015, 12:30   #3 (permalink)
Member: 376471
Sonork: 100.1608095
Thanks Meter: 107
Originally Posted by patiot View Post
hi
change Download-Agent file to "DA_SWSEC.bin"...
Old 02-15-2015, 18:15   #4 (permalink)
Member: 1962832
Thanks Meter: 199
try this link desire 310
HTC-D310W - Download - 4shared
The Following User Says Thank You to a1mobiletirupur For This Useful Post:
Old 02-15-2015, 18:44   #5 (permalink)
Member: 2300899
Thanks Meter: 5
hi
What's fone problem?
I don't work with HTC set with sptool but if u have simple problem then just write user data area or flash the set with format + download option
Old 03-03-2015, 15:03   #6 (permalink)
Member: 682736
Thanks Meter: 457
Reallly worked for me... Windows 7 was giving error 2004..
I used flashtool as in folder and Windows xp did the job...
I flashed it to Desire 310u... working...
The Following User Says Thank You to adnon For This Useful Post:
Old 10-25-2015, 15:22   #7 (permalink)
joshvimalraj88's Avatar
Member: 1625194
Thanks Meter: 30
https://forum.gsmhosting.com/vbb/****************************/?4g050pjvj0ujyub[IMG]****************************/?4g050pjvj0ujyub[/IMG]
Old 10-25-2015, 15:22   #8 (permalink)
Member: 1625194
Thanks Meter: 30
Old 12-22-2015, 08:52   #9 (permalink)
Member: 1701545
Thanks Meter: 100
HTC desire 310 flash done this file n this tool but set startup time 1 time notice
sku number
1.00.1402.6
cid htc_038
your cie is incorrect
it must be one of below cids;
htccn703
here link
HTC-D310W by jamesjerss
Old 05-20-2016, 14:40   #10 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 527
Dear
Help to flash HTC Desire 310 MTK6582
with both boxes give error
Help
Thanks in advance
Old 05-29-2016, 14:52   #11 (permalink)
xx0o0xx1's Avatar
Member: 2033150
Thanks Meter: 624
hello everyone
i got this problem today when i tried to flash HTC desire 310 dual _ spft error 2004 !!!
but i decided to fix it and i did
pre :
- download this FW https://yadi.sk/d/7SGjVIxUbaUxe
- download this ver of spft https://mega.nz/#!WcVGyYZK!FyFVPkKTd...J0rELMocvztyNI
- Go to the Connection tab, and select the option: High Speed ​​and w / o battery.
- select the option Download DA DL All with checksum
- important step " rename checksum.ini to checksum.old into ur fw package
- press Download and connect ur device with v+ pressed until it start the flashing
i shared this to let everyone fall in the same error " 2004 " fix it
good luck
Devx
The Following 4 Users Say Thank You to xx0o0xx1 For This Useful Post:
Old 08-31-2016, 14:20   #12 (permalink)
Member: 2473064
Thanks Meter: 15
any one with a link to download htc d310n mt6582 firmware
Old 03-16-2017, 10:02   #13 (permalink)
Member: 2286149
Thanks Meter: 34
flashing failed at 1% and set dead can anybody help me?
Old 03-16-2017, 11:18   #14 (permalink)
Member: 2286149
Thanks Meter: 34
flashed with xx0o0xx1 provided file, #11, now set is alive. thanks
The Following User Says Thank You to Jamil69 For This Useful Post:
Old 10-09-2017, 15:25   #15 (permalink)
Member: 2657990
I could not do it, could result be a problem related to negative vehicle version
Page generated in 0.26893 seconds with 8 queries
