HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
08-14-2012, 20:35 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Croatia Age: 37
Member: 343004 Status: Offline Thanks Meter: 12 | HTC EVO 3D GSM AND CDMA SIM UNLOCK TUTORIAL (FREE - no codes involved) Note: This method is universal and will work despite the HBOOT version preinstalled TESTED & SURE WAY 1.) DOWNLOAD NEEDED FILES FROM HERE: Code: http://www.mediafire.com/?1h23fnn0n9e033s from here: Code: http://developer.android.com/sdk/win-usb.html 4.) Boot phone in bootloader mode (hold VOL down + POWER buttons), select FASTBOOT option with power button -> now plug in usb cable and you should see FASTBOOT USB on device 5.) Open command prompt in Windows with Admin rights and navigate to C:\Android folder where you should have following files: adb.exe, AdbWinApi.dll, AdbWinUsbApi.dll, cwm-4.0.1.4-shooteru.img and fastboot.exe Now type the following command in Cmd: Code: fastboot flash recovery cwm-4.0.1.4-shooteru.img 6.) Turn on phone, turn it off and boot again in bootloader mode, select second option 'Recovery' and press power button to select it -> in recovery use option instal zip update from sdcard and install "Superuser-3.0.7-efghi-signed.zip" file which needs to be placed in root directory of microSD card. If you get error during install make sure that "Toggle signature verifaction" is set to Disabled state. Try 2-3 times until you see SUCCESS at the end At this point you have already unlocked bootloader & rooted the device with S-ON security state 7.) Turn on phone, turn it off and before proceeding make sure your battery is at least 75% charged or you will not be able to continue procedure.. Boot phone in bootloader fastboot usb mode again and launch "ControlBear.exe" on PC (use controlbear from GB_WIN folder if you have Gingerbread 2.3 OS or controlbear.exe from ICS_WIN if you have upgraded your phone to ICS 4.0.3 firmware) During procedure controlbear will ask you to do Wire Trick to achieve S-OFF state Instructions how to do this go here: Code: http://unlimited.io/juopunutbear-public-beta-0-1/instructions/evo-3d-gsm-shooter_u/ 8.) Now you need to acquire unique 'config.dat' file to remove SIMLOCK which needs to be placed at root folder of your microSD card. To do this go here: Code: http://www.sieempi.eu/blog/2011/09/22/universal-sim-unlock-for-s-offed-htc-devices-536 Type and IMEI serial and press Send when done. Check your email address and download your config.dat file 9.) Put config.dat to root of your microSD card and in bootloader mode choose option SIMLOCK and install file.. Voila! Your phone is now fully unlocked for free! EnJoY Please confirm if you were able to unlock your phone aswell with this method If you have any questions/problems please post here.. Last edited by dekoslav; 08-14-2012 at 20:45. |
06-26-2013, 12:25 | #3 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1967376 Status: Offline Thanks Meter: 0 | Immediate inquiry. Dear everyone I have a number of chinese android phones of different models from Coolpad. some of them are only cdma and some are gsm+cdma. But they are locked to use only in china. I want to unlock their network. Please tell me is it possible or not. If it is possible how can I unlock them? Note that they have different android os like 4.0.4, 4.1 etc. Please help me. |
01-10-2014, 19:15 | #4 (permalink) | |
Junior Member Join Date: Jul 2007
Member: 543818 Status: Offline Thanks Meter: 0 | Quote:
what is the PHONE TYPE? just evo 3d or pg86130 etc? | |
01-11-2014, 01:11 | #6 (permalink) |
Member: 543818 Status: Offline Thanks Meter: 0 | I DID IT I DID IT I DID IT WEEEEEEEEEEEEEEE!!! i did it, thanks to you, thank you very much, my problem was i bougth a code but my carrier had disabled the sim unlock prompt window in rom, and the stock ruu isnt available from my carrier (it is not a regular evo 3d it is called "inspire 3d" model PG 86130 and it is a somehow different model that no pages around the web seem to even mention.) well the code i got for 2 dollars so no big loss, plus i learnt a lot doing this. again thank you very much , i even s-off in the first try , i had s-off'ed other htc devices that didnt need the wire trick, so that was a first to me and i did it on first attemp, im very happy. now that i have unlocked and s-off i migth even throw in some jb rom or something xD weeeeeeeeee!!! |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
