Bye the way, Your Phone is working thats fine :) Recovery Doesn't happened to you anymore. |
Device Info Security status: S-ON Model Id: 0P6B67000 Custom Id: HTC__J15 (HTC-GCC) Serial number: HC53AWM01415 Product: m8_ul IMEI: Platform: hTCBmsm8974 Bootloader ver: 3.19.0.0000 Baseband ver: 1.29.214500021.12G Cpld verersion: None Microp version: None Main version: 6.21.401.1 Battery Status: good Battery Volt: 0mV PartitionLayout: Generic Commitno bl: 205bdca3 Hbootpreupdate: 11 i need this device firmware, i tried to flash with this firmware 0P6BIMG_M8_UL_M60_SENSE70_MR_HTC_Europe_6.12.401.4 _Radio_1.29.214500021.12G_20.72.4196t.01_release_4 64360_signed.zip but get FAILED Here is the RBsoft logs Connecting to server wait..Ok Login Success Credit : 0 Rebooting Phone To RUU Mode..Ok Loading firmware It may Take Some Time sending 'zip'... (53965 KB) OKAY writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... FAIL41 model id check fail sending time = 2.655 secs FAILED (remote: 41 model id check fail) Execution time is 6(s) i tried via adb fastboot method and sdcard method too, but same result, |
http://download1514.mediafire.com/fc..._GeM_FlAsH.rar If you need more help , post it below. Thanks |
what is the password sir |
Model : M8_UL IMEI : 35xxxxxxxxxxxxx Build : 6.21.401.1 CID : HTC__J15 HBoot : 3.19.0.0000 MID : 0P6B67000 Security : ON Region : HTC-GCC RBSofts V1.5 Mobile Tool. need firmware |
use this as password |
The file and the password is perfectly correct. |
I need RUU for HTC M8 cidnum: HTC__G09 someone can help me? |
bootloader is relocked version : 0.5 version-bootloader : 3.19.0.0000 version-baseband : 1.29.214500021.12G version-cpld : None version-microp : None version-main : 6.12.161.4 version-misc : PVT SHIP S-ON serialno : FA46MWM00677 imei : xxxxxxxxx590 imei2 : Not Support meid : 00000000000000 product : m8_ul platform : hTCBmsm8974 modelid : 0P6B10000 cidnum : VODAP304 battery-status : good battery-voltage : 0mV partition-layout : Generic security : on build-mode : SHIP boot-mode : FASTBOOT commitno-bootloader : 76df2b54 hbootpreupdate : 11 gencheckpt : 0 thanks in advane |
(bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.29.214500021.12G (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: HT46AWM00672 (bootloader) imei: 352442060229646 (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: m8_ul (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0P6B65000 (bootloader) cidnum: HTC__038 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 205bdca3 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.047s need firmware tnx in advance |
unable to update sir i hav dis file but unable to update handset ..there is no sdcard slot in handset.. i tried fastboot ruu and fastboot zip flashing it says (unable to load op6bimg.zip) plz help me tnx handset is in normal condition som one flash it with custom rom twrp recovery handset baseband is unknown... i hav locked bootloader ..it shows on screen relocked..but still unable to flash tnx in advance |
If no, install zip file via USB OTG Method. This way same like sd card method just put the file in usb drive and connect usb drive with usb otg. Enter phone Bootloader mode and Start flash. If you doesn't getting my way then use search button after you will get many others way or tutorial to update this rom. Best Regards Shamim |
