HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
01-05-2018, 12:08 | #91 (permalink) |
Freak Poster Join Date: Mar 2013
Member: 1908127 Status: Offline Thanks Meter: 14 | can i flash zip or ruu (bootloader) version:0.5 (bootloader) ramdump-mode:false (bootloader) variant:MTP eMMC (bootloader) secure:yes (bootloader) version-baseband: (bootloader) version-bootloader: (bootloader) max-download-size: 0x20000000 (bootloader) partition-type:cache:ext4 (bootloader) partition-size:cache: 0x14000000 (bootloader) partition-type:userdata:ext4 (bootloader) partition-size:userdata: 0x5e0000000 (bootloader) partition-type:system:ext4 (bootloader) partition-size:system: 0x118000000 (bootloader) serialno:FA59AYJ00781 all: |
01-05-2018, 14:48 | #92 (permalink) | |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,714 | Quote:
Please Check Sticky Thread and Post Here Your fastboot getvar all info.
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim | |
01-11-2018, 11:26 | #94 (permalink) |
Member: 1908127 Status: Offline Thanks Meter: 14 | (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) serialno: FA59AYJ00781 (bootloader) current-slot: (bootloader) imei: (bootloader) version-main: 4.17.161.11 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U114401031_124.01.70203G_F (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA10000 (bootloader) cid: VODAP102 |
01-11-2018, 13:35 | #96 (permalink) | |
Freak Poster Join Date: Nov 2015 Location: INDIA
Member: 2482400 Status: Offline Sonork: 100.1677259 Thanks Meter: 115 | Quote:
https://androidfilehost.com/?fid=817550096634776616 | |
01-11-2018, 15:09 | #98 (permalink) |
Member: 1908127 Status: Offline Thanks Meter: 14 | the block size 4096 sending sparse 'zip' 1/1 (0 KB)... error: write_sparse_skip_chunk: don't care size 2334728423 is not a m the block size 4096 error: write_sparse_skip_chunk: don't care size 2334728423 is not a m the block size 4096 OKAY [ 1.030s] writing 'zip' 1/1... (bootloader) HOSD CL#859282 FAILED (remote: 9 RU_SECURITY_FAIL zip from usb command in download m finished. total time: 2.059s what error is this |
01-11-2018, 15:18 | #99 (permalink) |
Member: 1908127 Status: Offline Thanks Meter: 14 | the block size 4096 sending sparse 'zip' 1/1 (0 KB)... error: write_sparse_skip_chunk: don't care size 2334728423 is not a multip the block size 4096 error: write_sparse_skip_chunk: don't care size 2334728423 is not a multip the block size 4096 OKAY [ 1.030s] writing 'zip' 1/1... (bootloader) HOSD CL#859282 (bootloader) ERR lzipv1_init : Cannot read header len bytes (bootloader) ERR lzipv2_init : Cannot open file /dev/fastboot_download_y (bootloader) hI3A8 (bootloader) ERR preload central directory info failed (EOCD). FAILED (remote: 99 RU_UNKNOWN_FAIL terrible mishap with original ret: 0) finished. total time: 2.090s |
01-15-2018, 23:49 | #101 (permalink) |
Freak Poster Join Date: May 2014
Member: 2194348 Status: Offline Thanks Meter: 52 | < waiting for device > INFOkernel: lk INFOproduct: htc_himaulatt INFOversion: 1.0 INFOserialno: FA53SYJ01452 INFOcurrent-slot: INFOimei: 358235060197027 INFOversion-main: 4.19.661.1 INFOboot-mode: download INFOversion-baseband: 01.01_U114401021_121.02.61214G_F INFOversion-bootloader: 1.0.0.0000 INFOmid: 0PJA11000 INFOcid: TELUS001 all: |
01-28-2018, 13:54 | #102 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Punjab Pakistan
Member: 209582 Status: Offline Sonork: 100.1607015 Thanks Meter: 149 | plz help me i am very thx full to all off u i have htc one m9 problem is unkown baseband and imei ???? come from another shop as it is i have flash with this file 0PJAIMG_HIMA_UL_N70_SENSE80_ATT_MR_NA_Gen_Unlock_4 .30.+617.12 done flash but same unkown baseband on phone back model OPJA200 but in download mode its show OPJA11000 super cid check pic off download mode at the end fast boot info Restarting in fastboot mode... Phone detected IMEI: 358609052147770 Android version: 7.0 Model name: HTC One M9 Manufacturer: HTC Device code: htc_himaulatt Product name: himaulatt_na_gen_unlock Product version: 4.30.617.12 Bootloader version: 1.0.0.0000 Language: Region: Battery: Cid: SPCS_001 Main camera: Ram: 3GB Wifi: 802.11 a/b/g/n/ac Protected: true Build line: HIMAULATT_GenericOC_WWE_N70_CRC_Sense80_Stable_MR Build changelist: 894012 Build characteristics: default Build UTC: 1491971847 Build date: ? 4? 12 12:37:27 CST 2017 Build descriptor: 4.30.617.12 CL894012 release-keys Build display id: NRD90M release-keys Build project: HIMA_UL_N70_SENSE80_ATT_MR:501592 Build Sense version: 8.0 Kernel version: Linux version 3.10.84-perf-gde2b1fd (and@AABM) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Apr 12 13:04:42 CST 2017 https://ibb.co/j4Fx3b https://ibb.co/mrR1ww https://ibb.co/hD9obw as off back menu and fast boot cid info i try to flash with 0PJAIMG_HIMA_WHL_N70_SENSE80_SPCS_MR_Sprint_WWE_4. 27.651.4 but error at just start Last edited by gsmkiller173; 01-28-2018 at 14:00. |
01-28-2018, 14:39 | #103 (permalink) | |
It Should be Relock Bootloader and Flash with Stock Rom.
01-29-2018, 07:54 | #104 (permalink) | |
Member: 209582 Status: Offline Sonork: 100.1607015 Thanks Meter: 149 | Quote:
Code: C:\Users\gsmlover\Desktop\android>htc_fastboot flash zip 0PJAIMG.zip htc_fastboot v3.0.9.2 (2015-05-29) target rom version: 4.30.617.12 found large-zip header, file count: 7 processing file 1/7... sending 'zip' (134723 KB)... OKAY [ 8.370s] writing 'zip'... (bootloader) HOSD CL#894012 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) Perform pre-update (bootloader) WARN Skip cmnlib32.img due to unmatched partition name (bootloader) WARN Skip cmnlib64.img due to unmatched partition name (bootloader) WARN Skip keymaster.img due to unmatched partition name (bootloader) WARN Skip bootlocker.img due to unmatched partition name (bootloader) WARN Skip cir.img due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 23 images from zip(zip_type=3) (bootloader) start@23 (bootloader) apppreload.img@BYPASS (bootloader) aboot_signed.img@100% (bootloader) cota.img@BYPASS (bootloader) sbl1-8994-1.img@100% (bootloader) sdi.img@100% (bootloader) hosd_signed.img@100% (bootloader) rpm-8994-1.img@100% (bootloader) pmic-8994-1.img@100% (bootloader) boot_signed.img@BYPASS (bootloader) recovery_signed.img@BYPASS (bootloader) adsp.img@BYPASS (bootloader) cpe.img@BYPASS (bootloader) rcdata.img@BYPASS (bootloader) modem_st1.img@BYPASS (bootloader) modem_st2.img@BYPASS (bootloader) tz-8994-1.img@100% (bootloader) hyp-8994-1.img@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) sensor_hub.img@BYPASS (bootloader) tp_SYN3351.img@BYPASS (bootloader) tp_MXM11876.img@BYPASS (bootloader) splash1.nb0@BYPASS (bootloader) radio.img@BYPASS FAILED (remote: 90 hboot pre-update! please flush image again immediately ) finished. total time: 10.230s preupdate done, rebooting... resending command... sending 'zip' (134723 KB)... OKAY [ 8.380s] writing 'zip'... (bootloader) HOSD CL#894012 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) WARN Skip cmnlib32.img due to unmatched partition name (bootloader) WARN Skip cmnlib64.img due to unmatched partition name (bootloader) WARN Skip keymaster.img due to unmatched partition name (bootloader) WARN Skip bootlocker.img due to unmatched partition name (bootloader) WARN Skip cir.img due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 23 images from zip(zip_type=3) (bootloader) start@23 (bootloader) apppreload.img@22% (bootloader) apppreload.img@45% (bootloader) apppreload.img@68% (bootloader) apppreload.img@90% (bootloader) apppreload.img@100% (bootloader) aboot_signed.img@100% (bootloader) cota.img@100% (bootloader) sbl1-8994-1.img@100% (bootloader) sdi.img@100% (bootloader) hosd_signed.img@100% (bootloader) rpm-8994-1.img@100% (bootloader) pmic-8994-1.img@100% (bootloader) boot_signed.img@100% (bootloader) recovery_signed.img@100% (bootloader) adsp.img@100% (bootloader) cpe.img@100% (bootloader) rcdata.img@100% (bootloader) modem_st1.img@100% (bootloader) modem_st2.img@100% (bootloader) tz-8994-1.img@100% (bootloader) hyp-8994-1.img@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) splash1.nb0@100% (bootloader) radio.img@100% (bootloader) sensor_hub.img@BYPASS (bootloader) tp_SYN3351.img@BYPASS (bootloader) tp_MXM11876.img@BYPASS (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 16.241s] finished. total time: 24.661s processing file 2/7... sending 'zip' (459505 KB)... OKAY [ 27.222s] writing 'zip'... (bootloader) HOSD CL#894012 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_00@8% (bootloader) system.img_00@16% (bootloader) system.img_00@24% (bootloader) system.img_00@32% (bootloader) system.img_00@41% (bootloader) system.img_00@49% (bootloader) system.img_00@57% (bootloader) system.img_00@65% (bootloader) system.img_00@74% (bootloader) system.img_00@82% (bootloader) system.img_00@90% (bootloader) system.img_00@98% (bootloader) system.img_00@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 21.511s] finished. total time: 48.733s processing file 3/7... sending 'zip' (425308 KB)... OKAY [ 24.441s] writing 'zip'... (bootloader) HOSD CL#894012 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_01@8% (bootloader) system.img_01@16% (bootloader) system.img_01@24% (bootloader) system.img_01@32% (bootloader) system.img_01@41% (bootloader) system.img_01@49% (bootloader) system.img_01@57% (bootloader) system.img_01@65% (bootloader) system.img_01@74% (bootloader) system.img_01@82% (bootloader) system.img_01@90% (bootloader) system.img_01@98% (bootloader) system.img_01@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 17.621s] finished. total time: 42.092s processing file 4/7... sending 'zip' (476876 KB)... OKAY [ 27.291s] writing 'zip'... (bootloader) HOSD CL#894012 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_02@8% (bootloader) system.img_02@16% (bootloader) system.img_02@24% (bootloader) system.img_02@32% (bootloader) system.img_02@41% (bootloader) system.img_02@49% (bootloader) system.img_02@57% (bootloader) system.img_02@65% (bootloader) system.img_02@74% (bootloader) system.img_02@82% (bootloader) system.img_02@90% (bootloader) system.img_02@98% (bootloader) system.img_02@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 17.631s] finished. total time: 44.922s processing file 5/7... sending 'zip' (419429 KB)... OKAY [ 24.151s] writing 'zip'... (bootloader) HOSD CL#894012 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_03@8% (bootloader) system.img_03@16% (bootloader) system.img_03@24% (bootloader) system.img_03@33% (bootloader) system.img_03@41% (bootloader) system.img_03@49% (bootloader) system.img_03@57% (bootloader) system.img_03@66% (bootloader) system.img_03@74% (bootloader) system.img_03@82% (bootloader) system.img_03@90% (bootloader) system.img_03@99% (bootloader) system.img_03@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 17.541s] finished. total time: 41.692s processing file 6/7... sending 'zip' (225829 KB)... OKAY [ 13.541s] writing 'zip'... (bootloader) HOSD CL#894012 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_04@13% (bootloader) system.img_04@27% (bootloader) system.img_04@41% (bootloader) system.img_04@55% (bootloader) system.img_04@69% (bootloader) system.img_04@83% (bootloader) system.img_04@97% (bootloader) system.img_04@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 11.671s] finished. total time: 25.212s processing file 7/7... sending 'zip' (13477 KB)... OKAY [ 1.800s] writing 'zip'... (bootloader) HOSD CL#894012 (bootloader) get 2 images from zip(zip_type=3) (bootloader) start@2 (bootloader) dzdata_32g.img@100% (bootloader) boot_signed.img@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 8.161s] finished. total time: 9.961s rompack updated htc_fastboot finished. total time: 307.357s htc_fastboot flash zip 0PJAIMG.zip htc_fastboot v3.0.9.2 (2015-05-29) target rom version: 4.27.651.4 found large-zip header, file count: 6 processing file 1/6... sending 'zip' (103623 KB)... OKAY [ 6.661s] writing 'zip'... (bootloader) HOSD CL#894012 (bootloader) ERR Model ID not matched (bootloader) ERR [SD_UPDATE_ERR] MODEL ID NOT ALLOWED (bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 10 (bootloader) ERR Update zip file failed. (bootloader) Update zip file OK (bootloader) ERR ZIP ERROR CODE, 10 (bootloader) end@Done FAILED (remote: 10 RU_MODELID_FAIL modelid in android-info mismatched ) finished. total time: 9.451s htc_fastboot finished. total time: 15.681s Last edited by ...:::SHAMIM:::...; 01-29-2018 at 18:30. | |
01-29-2018, 18:38 | #105 (permalink) | ||
Your Phone Product id is AT&T. Quote:
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim | ||
