HTC Rezound (Verizon Wireless) adr6425vw Sim free Global firmware + Guide Htc Rezound adr6425vw Sim free Global firmware http://shop.htcpedia.com/images/deta...rely-There.png Note: After upadte this firmware should work on all network Procedure : * Download Global firmware from bottom * Rename the file as PH98IMG.zip * Copy the file to adb folder * Connet yur device in fastboot mode * Run below givn commands to flash fastboot devices fastboot oem rebootRUU fastboot flash zip PH98IMG.zip fastboot reboot Or Copy PH98IMG.zip to sdcard Insert it to your device Boot into bootloader mode Download Global firmware ICS_4.03.605.2 PLEASE DON'T SAY THANKShttp://s2.postimg.org/f0t0fea1h/se4pqujpg.gifJUST PRESS BUTTON http://img23.imageshack.us/img23/506...atedthanks.gifBUTTON http://img40.imageshack.us/img40/606...bulletfast.gif |
i try to flash but always giving a error "C:\adb>fastboot flash zip PH98IMG.zip error: cannot load 'PH98IMG.zip" my device info... Model : VIGOR IMEI : 990000651686083 Build : 3.14.605.12 CID : 11111111 HBoot : 2.25.0000 MID : PH98***** Security : OFF Region : Super_CID |
File should be in same folder of adb,cannot load means its not found file in folder. |
also check the file extension dnt add .zip extension two times Sent from my SM-G900F using Tapatalk |
file found the correct path what to do now |
same error |
I will try it now................. |
@THE GREAT ONE its done or not..... |
10000% working solution here is result http://imagizer.imageshack.us/v2/619...913/ym8Vwk.jpg after flash done http://imagizer.imageshack.us/v2/290...661/ywGb2y.jpg special thanks to bro james jerss for ur helps :D:D:D |
thanks but now phone says (This sim card is from unknown source) how to unlock it now . Give me the procedure to enter the code or which software to unlock it |
how to unlock it ,using box |
Hi, can i flash this to... UNLOCKED VIGOR PVT SHIP S-OFF RL HBOOT-2.27.0000 RADIO-1.22.10.0421r/1.22.10.0424r OpenDSP-v13.6.0.7611.00.0104 eMMC-boot Aug 6 2012, Thanks |
