HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
06-08-2015, 10:41 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | How to flash firware zip Awaiting for kind replies ,,, |
06-08-2015, 16:43 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Flash via fastboot fastboot oem rebootRUU fastboot flash zip firmware.zip fastboot reboot Before flash firmware zip check the android info txt frm yur firmware.zip cid must b matched vit yur device nd main version should b same or higher version |
The Following User Says Thank You to jamesjerss For This Useful Post: |
06-08-2015, 17:52 | #3 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | sir i downloaded and extract that zip file on desktop ,,and then open command in same folder ? is it right ? should i rename that zip file ? or should be remain as it is ? Waiting for your expert reply ,, |
06-08-2015, 18:04 | #4 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | No need to extract firmware.zip only contain bootloaders nd modem files.copy firmware zip to adb folder nd flash via fastboot |
06-08-2015, 18:22 | #5 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | oh thats great becoming clear each thing one by one ,,,i have made ADB folder in my C driver,,know copying particular things which you stated in same folder and know becoming start by one by one ,,,thats it ? |
06-08-2015, 18:58 | #6 (permalink) | |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
http://forum.gsmhosting.com/vbb/f485...guide-1952646/ | |
