HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
04-04-2014, 17:21 | #1 (permalink) |
Major Poster Join Date: Dec 2010
Member: 1467041 Status: Offline Thanks Meter: 7 | HTC Wildfire S Hboot 1.03.0000. I can not update RUU and unlock bootloader (HTC DEV) I wanted to create Gold Card for HTC Wildfire S because my new digitizzer not working ( I try 3 pieces), but I have a BIG PROBLEM. I want created GOLD CARD, but I can not write it to the phone --> UPDATE FAIL SECURITY FAIL I have Hboot 1.03.0000, and I can not unlock bootloader ( HTC DEV SITE), because each version of the RUU is NOT SUPPORTED My ROM version is 1.36.92.2, and if I want update to 2.26.401.3 I see signature updates and ERROR 131... Program EasyUnlockTool not working. Can anyone help me?? |
04-04-2014, 20:20 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
Things U Need 2Gb Memory Card ( Wildfire S OK Debug Mode On ) Or ( PC Or Laptop Built In Memory Card Reader ) Or ( Any Working Htc Android Handset Minimum ) If U have 3rd option android HTC Working Handset Then Its Better 1- Power On Ur working Android With 2Gb SD card 2- Now Open App Store And Download application goldcard helper.apk And Install 3. Launch GoldCard Helper on your phone. 4. Write down the ‘Card:mmc2, Reverse CID’ value, making sure to use mmc2 and not mmc1. (If You See mmc0 & mmc1 Then Use mmc1) 4. Go to this page and choose reverse CID Then enter the reverse CID mmc2 (Or mmc1 ==> if mmc0 & mmc1 Come in app) 5- Click Download Goldcard & Save Downloaded Img Any Where In PC 6- Now U Must Know About Ur Handset Cid Use fastboot Command '' fastboot getvar cid '' 7- Now Remove SD card Form Working Phone And Plug In Sd Card Reader With Pc & Format As FAT32 ( Not Quick Format ) 8- Download GoldCardTool_0.0.7 9- Run Gold Card Tool And Select MMC Section Ur Plugged Sd card Write Ur Handset CID In CID Section And Then Load Downloaded GoldCard.img And Then Select "Patch MMC" and once it's done, you have a GoldCard! 10 - Now U Need To Get Rom.zip From Ruu Witch U Want To Write And Rename It To PG76IMG.zip Paste In Ur SD Card 11- Put SD Card In handset Boot into bootloader Mode Make Sure Bootloader Status Locked In few Sec Hboot Flashing Start And You Are Done ( This Is For Those who Not have any Device Or Dongle For GoldCard Making Better to buy Any Tool And Make Fast everything ) BR, ..::Rizwan::.. | |
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post: |
