HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
04-17-2015, 06:56 | #1 (permalink) |
Junior Member Join Date: Sep 2008
Member: 852879 Status: Offline Thanks Meter: 5 | Help HTC one M7 my Get var = ootloader) version: 0.5 (bootloader) version-bootloader: 1.57.0000 (bootloader) version-baseband: 4T.29.3218.08 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 6.09.401.5 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: SH39EW9**** (bootloader) imei: 3578640595*** (bootloader) meid: 00000000000000 (bootloader) product: m7_ul (bootloader) platform: HBOOT-8064 (bootloader) modelid: PN0710000 (bootloader) cidnum: HTC__001 (bootloader) battery-status: good (bootloader) battery-voltage: 4003mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-6d8a0b9b (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! I have TWRP installed , I know i cant use RUU but i need to get as close to stock as possible to run sunshine , ANY HELP WOULD BE GREAT . thanks in advance Karl |
04-17-2015, 07:45 | #2 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Write recovery original and lockbootloader now you can flash Ruu original or use androide backup of you Cid |
The Following 2 Users Say Thank You to jmr For This Useful Post: |
04-17-2015, 08:45 | #3 (permalink) |
Member: 852879 Status: Offline Thanks Meter: 5 | Thanks for the reply ... 1 last question , which is best way to flash , I have downloaded Guru_Reset_M7_2.24.401.8 dot zip this has the recovery file, ( fastboot OR TWRP ? ) im guessing , flash thr recovery via Fastboot , then use the lock command ,, then I can use RUU ? |
04-17-2015, 13:25 | #4 (permalink) |
Member: 852879 Status: Offline Thanks Meter: 5 | Ahhhhhh please help !!! I have re locked boot loader and flashed recovery to stock , I have downloaded RUU but it only goes as far as accept License agreement, then the wizard just closes. |
04-18-2015, 07:39 | #6 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Relock bootloader Download Europe stock ruu frm here http://forum.gsmhosting.com/vbb/f485...p-ruu-1863513/ Br james |
04-21-2015, 10:48 | #9 (permalink) |
Member: 852879 Status: Offline Thanks Meter: 5 | thank you for all your help , I have 1 last problem then im done , I followed the firewater tutoral and ended up with CM11 , i needed Soff so in installed viper , got Soff using sunsine , BUT i lost my baseband and IMEI , so i re flashed CM11 and all was good again ...I am guessing this is a backward compatablity problem . what can I do to get as close to stock as possible now IM S-off |
