need m9 rom (bootloader) kernel: lk (bootloader) product: htc_himawhl (bootloader) version: 1.0 (bootloader) imei: 990005026796582 (bootloader) version-main: 2.11.651.19 (bootloader) boot-mode: download (bootloader) version-baseband: 2.10.C1144070@50824 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA20000 (bootloader) cid: 11111111 all: finished. total time: 0.023s |
here is ruu RUU_HIMA_WHL_L51_SENSE70_SPCS_MR_Sprint_WWE_2.11.6 51.19_Radio_2.10.C1144070@50824_CNV_CNV_HIMA_SPCS_ 1.14_003_release_449494_signed_2.exe Don't forget to press Thanks Button Read The Rules Careful HERE Br M@SUD |
How to flashing this rom ??? Ihave dongle bst irkey but not supoort this phone |
open the file included in the link on your computer. Plug in your phone and follow the computer screen. The file is a exe file |
what are you talking about ? , i don't understand , put some steps by step on how to do it |
The link supplied to you is a computer program to flash your phone. Download it and run it on your computer. Hook up your phone to the computer and the program will update it for you. Below is instructions from HTC site: Performing the ROM Update: 1. Download and save the HTC One™ for Sprint ROM update to your PC. 2. Connect your device to your PC via the supplied USB cable. 3. If the device is not recognized by the PC, ensure you have HTC Sync Manager installed and then disconnect and reconnect the device from the USB cable. 4. Once the device is properly recognized on the PC, locate the HTC One™ for Sprint ROM update that you downloaded. Double-click on the file to launch the system update wizard. 5. Follow all of the system update wizard instructions shown on your PC. 6. Once the update is complete, click Finish in the Wizard and the device will reboot. 7. Once the device reboots, the initial setup wizard will appear. 8. Once the initial setup process is complete, open Play Store and tap the Menu icon, then select My apps and ensure all installed apps are updated. 9. After initial setup and updating all apps, the device is ready for use. Note : If the ROM update wizard fails to recognize the device, close the wizard and then follow the steps below: · From a powered off state, hold VOLUME DOWN while powering on the device to access download mode. · Connect the device to the PC while in this state and attempt the ROM update again. To exit download mode manually, use the volume keys to navigate to reboot and press the POWER button to select it. |
