HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
12-11-2015, 22:37 | #31 (permalink) |
Freak Poster Join Date: Jul 2015 Location: AG COMM QATAR Age: 38
Member: 2426327 Status: Offline Sonork: 100.4294967295 Thanks Meter: 70 | HTC 8126 DUAL PHONE IS SWITCH DURING THE UPDATE THROUGH WIFI.AFTER THAT ONLY I CAN ACCESS RECOVERY MODE .I WILL NOT GET FAST BOOT MODE.HOW CAN FIND OUT ITS CID, |
12-11-2015, 22:46 | #32 (permalink) |
Member: 2426327 Status: Offline Sonork: 100.4294967295 Thanks Meter: 70 | HTC 816 DUAL HTC 816 SWITCH OFF WHILE UPDATING THROUGH WIFI . AFTER THAT ONLY CAN ACCESS RECOVERY MOD.I WILL NOT CHECK CID number,main version.now phone cannot switch to fastboot mode.how i can find out its cid version ? |
01-08-2016, 09:44 | #34 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | hello sir one x cid 044 bricked i am using this file OTA_ENDEAVOR_U_JB_50_S_hTC_Asia_WWE_4.19.707.3-3.14.707.24_release_3346060yp26w70ibi8zm1g i renamed it as= pg46img but not working please guide me |
01-08-2016, 21:17 | #35 (permalink) | |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
Guide nd fastboot drivere : http://forum.gsmhosting.com/vbb/f485...guide-1952646/ | |
01-11-2016, 12:19 | #37 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 44
Member: 136052 Status: Offline Thanks Meter: 75 | Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 1.44.0000 (bootloader) version-baseband: 4A.15.3250.22 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.29.1402.25 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: HC39MW900192 (bootloader) imei: 355653777708614 (bootloader) meid: 00000000000000 (bootloader) product: m7_u (bootloader) platform: HBOOT-8064 (bootloader) modelid: PN071**** (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 3770mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: RUU Please help what file i need wright to thease |
01-11-2016, 12:47 | #38 (permalink) | |
http://forum.gsmhosting.com/vbb/f485...p-ruu-1863513/ | |
01-12-2016, 07:56 | #39 (permalink) |
Member: 136052 Status: Offline Thanks Meter: 75 | if i flash these file PN07IMG_M7_U_L50_SENSE60_MR_HTC_Europe_7.19.401.12 1_Radio_4T.35.3218.16_10.33Q.1718.01D_release_4303 65_signed_2_4.zip i haw these error Starting flash process... sending 'zip'... (50278 KB) OKAY writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... Execution time is 3653(ms) FAIL22 loading zip info fail FAILED (remote: 22 loading zip info fail) Flash process completed. if i flash these PN07IMG_M7_UL_L50_SENSE60_MR_HTC_Europe_7.19.401.2 _Radio_4T.35.3218.16_10.33Q.1718.01L_release_42179 0_signed.zip these error too Starting flash process... sending 'zip'... (43286 KB) OKAY writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... Execution time is 3594(ms) FAIL22 loading zip info fail FAILED (remote: 22 loading zip info fail) Flash process completed. for these PN07IMG_M7_U_L50_SENSE60_MR_HTC_WWE_MMR_7.24.1136. 4_Radio_4T.35.3218.16_10.33Q.1718.01D_release_4376 56_signed_2_4.zip Starting flash process... sending 'zip'... (50282 KB) OKAY writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... Execution time is 7160(ms) FAIL22 loading zip info fail FAILED (remote: 22 loading zip info fail) Flash process completed. these file 100% work files , and others phones work fine with these and these phone work with custom rom , bat phone do not HAWED CUSTOM RECOVERY ... I WONT FLASH ORIGINAL FIRMWARE , bat these nothing happened if i wright these file with combo boot cable (y cable) i rename these files to PN07IMG.zip phone write not flash file or flash file wrong after scan in hboot and then nothing |
01-14-2016, 10:55 | #40 (permalink) |
No Life Poster Join Date: Dec 2001 Location: malang, east java, indonesian
Member: 7700 Status: Offline Thanks Meter: 28 | C:\ADB>fastboot flash zip PN07IMG.zip sending 'zip'... (43286 KB) OKAY sending time = 2.906 secs writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) Read zipped android_info fail FAILED (status read failed (Too many links)) Execution time is 9(s) please help sir |
01-14-2016, 11:40 | #41 (permalink) |
Member: 7700 Status: Offline Thanks Meter: 28 | i try download again file PN07IMG_M7_UL_L50_SENSE60_MR_hTC_Asia_HK_7.18.708. 2_Radio_4T.35.3218.29_10.33R.1718.01L_release_4205 59_signed try to extrack but corrupt i think thatfile corrupt |
01-14-2016, 13:12 | #42 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2512501 Status: Offline Thanks Meter: 0 | Failed Reading block 524288 Hello to you When I use the command fastboot oem rebootRUU, I receive the following errors: ----------------------------- INFOError: Command never completed Error: Command timeout error Error: Command completed with errors Failed Reading block 524288 ----------------------------- 1. Why? 2. How can I avoid it? Thanks in advance |
01-14-2016, 19:24 | #43 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | If unable to reboot yur device into ruu mode then mostly hardware issue friend . Sent from my XT1068 using Tapatalk |
01-15-2016, 00:01 | #44 (permalink) |
Member: 7700 Status: Offline Thanks Meter: 28 | sir, help another link download for this file PN07IMG_M7_UL_L50_SENSE60_MR_hTC_Asia_HK_7.18.708. 2_Radio_4T.35.3218.29_10.33R.1718.01L_release_4205 59_signed |
01-17-2016, 18:59 | #45 (permalink) | |
The Following User Says Thank You to jamesjerss For This Useful Post: |
