Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC & Smartphones ( WM Without Touch)
HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices
Old 03-11-2008, 06:43   #16 (permalink)
Member: 88996
Thanks Meter: 86
any one know how to make hard reset for kaiser ppc
The Following 3 Users Say Thank You to sunnyboy For This Useful Post:
Old 03-11-2008, 07:23   #17 (permalink)
::.::RAMJAN::.::'s Avatar
Member: 258172
Thanks Meter: 10,367
HTC Kaiser TyTN II P4550
To perform a soft reset:
Use the stylus to press the RESET button found at the bottom of your device. Your device restarts and displays the Today screen.
HTC Kaiser hard reset
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings - the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost. Only Windows Mobile® software and other pre-installed programs will remain.
Important If Encrypt files placed on storage cards is or was enabled before, then backup all files from the storage card before using Clear Storage, hard reset or updating the ROM system software. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a hard reset using device keys
1. Press and hold the left SOFT KEY and the right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom of your device.
2. Release the stylus, but continue pressing the two SOFT KEYs until you see the following message on the screen:
3. Release the two SOFT KEYs, and then press the green button on your device.
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
To perform a hard reset using Clear Storage
1. Tap Start > Settings > System tab > Clear Storage.
2. Type “1234” in the box and tap YES.
The Following 6 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post:
Old 03-12-2008, 22:15   #18 (permalink)
Member: 258172
HTC Touch Dual - Nike - P5500 16key
Remove the back cover and then with the stylus, press the RESET button found at the left side of your device. Your device restarts and displays the Today screen.
Hard reset
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings -‑ the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost. Only Windows Mobile® software and other pre-installed programs will remain.
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the left side of your device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:
3. Release the TALK and END buttons, and then press ENTER on your device.
Clear Storage
Another way of clearing the device storage and reset all settings back to factory default settings is to use the Clear Storage feature. You will lose all your data and files on the device storage when you use Clear Storage, so make sure to do a backup first.
2. Enter “1234” then tap Yes.
The Following 9 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post:
Old 03-15-2008, 09:26   #19 (permalink)
Member: 258172
Thumbs up Palm Treo 750
How to perform a hard reset
* If charging, disconnect your smartphone from its charger.
* Take off the battery door, but don't take out the battery yet.
* Press and hold Power/End key.
* While holding Power/End, remove the battery for approximately one second, then replace it while still holding Power/End.
* When you see "Erase all data?" you can release Power/End. Press Up to confirm the hard reset.
* If a language selection screen appears, pick the same language you use in your desktop software.
File Type: jpg palm_treo_750_hard_reset_soft_reset.jpg (10.9 KB, 237 views)
Old 03-17-2008, 11:33   #20 (permalink)
Member: 258172
BenQ P50
Hard reset
1. Locate the recessed Reset button at the bottom of the phone.
2. Press and hold down the Power button.
3. Without removing the Power button, insert the stylus into the recess to trigger the Reset button. Hold down both the Power button and the Reset button until the screen fades off.
4. When the screen has faded off completely, release both the Power button and the stylus.
5. You will notice the Power indicator light up green, at this point, press the Power button to turn ON the PDA phone.
Old 03-17-2008, 11:48   #21 (permalink)
..::: Naveed :::..'s Avatar
Member: 352237
Sonork: 100.1577161
Thanks Meter: 605
Really very very nice work we appriciate your good work and effort thanx brother
Old 03-18-2008, 18:41   #22 (permalink)
meknes gsm's Avatar
Member: 376587
Thanks Meter: 8
plz windows mobile for qteq 1010 fench
The Following User Says Thank You to meknes gsm For This Useful Post:
Old 03-18-2008, 19:30   #23 (permalink)
Member: 258172
Qtek 1010
To perform a full reset - hard reset:
A full device reset clears memory, deletes all data and restores the Pocket PC Phone to its default settings. Programs installed at the factory remain, while data you have created and programs you have installed are erased.
1. Unscrew the stylus and use the smaller point of the top-half.
2. Press the battery switch once to turn it off, and then once more to turn it back on.
The Following 5 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post:
Old 03-20-2008, 15:55   #24 (permalink)
Member: 671865
Thanks Meter: 15
hilfe MDA t.mobile HERM300 unlocker ???? proo rest
Old 03-21-2008, 18:31   #25 (permalink)
Member: 258172
Motorola Q Hard reset
Hard reset
To perform a hard reset, hold down the center select key (s) for
5 seconds while turning the phone on.
Master reset
Resets all options except the carrier
security code, and lifetime timer:
Press Start > System Tools > Master Reset
The Following 7 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post:
Old 03-25-2008, 00:14   #26 (permalink)
Member: 405806
Thanks Meter: 17
please help me to on how to format i-mate spl
Old 03-31-2008, 20:06   #27 (permalink)
Member: 258172
Dell Axim X3
To perform a hard reset:
Press and hold the power button.
With the stylus, hold the reset button for about 2 seconds.
Follow the instructions on the screen.
Old 04-05-2008, 19:13   #28 (permalink)
Member: 258172
NEC MobilePro 790
Using the Soft Reset Button
Before using the soft reset button to reset the MobilePro, close any open
files or applications, if possible. When you soft reset the MobilePro, you
may lose open/unsaved files.
Follow these steps to use the soft reset button to reset the MobilePro.
1. Open the display panel and remove the stylus from its holder.
2. Power on the MobilePro.
3. Turn over the MobilePro.
4. Locate the soft reset button on the bottom of the MobilePro.
5. Using the stylus, press the soft reset button. (You may need to press
the button more than once.) This resets the unit.
Using the Full Reset Button
Use the full reset button only when your unit does not respond after doing
all of the following:
! Installing a charged battery.
! Connecting the unit to an AC power source.
! Verifying that the battery lock is in the locked position.
! Using the soft reset button to reset the system.
Using the full reset button to reset your
MobilePro returns your unit to its original shipping configuration. All data
and applications are erased from RAM. All open/unsaved files are lost and
all user specific data such as contacts, tasks, etc., are erased.
You can only restore data that has been backed up to your host PC. For
more information, see the section in Chapter 3, “Backing Up and Restoring
Data.”
The full reset button is located inside of the main battery’s bay. Follow
these steps to remove the battery before using the full reset button to reset the NEC MobilePro.
2. Remove the battery pack as follows:
! Locate the battery lock and release latch on the bottom of the
system.
! Slide the lock to the unlocked position in the direction of the
arrow, as indicated in the following figure.
! Slide the release latch in the direction of its arrow, as indicated in
the following figure, and hold it.
3. Locate the full reset button inside of the battery bay, as indicated in
4. Using the stylus, press the full reset button. This resets the unit and
restores your system to its original shipping configuration.
You may be able to use a recent backup of your data to restore your
system to a more recent configuration. Refer to MicroSoft
ActiveSync on your host PC or the section in Chapter 3, “Backing Up
and Restoring Your Data,” for details about backing up and restoring
your MobilePro.
! Remove the battery from the bay.
Removing the battery pack
File Type: jpg nec_mobilepro_790_hard_reset_soft_reset.jpg (9.6 KB, 94 views)
File Type: jpg nec_mobilepro_790_hard_reset_soft_reset_1.jpg (17.1 KB, 100 views)
File Type: jpg nec_mobilepro_790_hard_reset_soft_reset_2.jpg (15.2 KB, 97 views)
The Following 4 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post:
Old 04-05-2008, 19:21   #29 (permalink)
Member: 258172
Palm Z22
hard reset
While holding the power button, use the tip of the stylus (or a similar object
without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
Wait for the Palm Powered™ logo to appear, and then release the power button.
When you see the message that warns you about erasing all of the info on your handheld, do one of the following:
• Press Up on the 5-way navigator to finish the reset and show the touchscreen.
• Press any other button to do a soft reset.
When prompted, tap to align the screen, and then select the language you want to use on your handheld. A screen appears showing the Palm logo and a progress bar.
When the Welcome screen appears, the hard reset is complete. Follow the instructions to set up your handheld
Old 04-05-2008, 19:46   #30 (permalink)
Member: 258172
Audiovox PPC-4100
1. Hold down the Power button on the front panel of
your device.
2. While holding down the power button , gently press
the tip of the stylus to the reset button.
The Confirmation message box appears.
3. Press the volume rocker key up.
File Type: jpg audiovox_ppc_4100_hard_reset_soft_reset_2.jpg (16.5 KB, 88 views)
::.:: All Smart Phones & PDA/PALM Latest Official ROM Download ::.:: ::.::RAMJAN::.:: HTC & PDA WM( With Touchscreen) 8 09-14-2010 10:53
All Smart Phones & PDA/PALM Enter Into Bootloader with picture ::.::RAMJAN::.:: HTC & PDA WM( With Touchscreen) 11 01-16-2009 13:06
All Smart Phones & PDA/PALM Hard Reset Key Total InfoHere msmobile Trash 2 06-02-2008 17:04
How can i be unlocking Smart Phones & PDA/PALM Organizers & Apple Iphone Smart Phones globalnetwork iPhone 2 / iPhone 3G / iPhone 3GS 1 12-24-2007 13:43
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.37350 seconds with 9 queries
