Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC & Smartphones ( WM Without Touch)
HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices
Old 08-06-2009, 22:47   #1 (permalink)
yarra's Avatar
Member: 493205
Sonork: 100.1581647
Thanks Meter: 525
how i can unlock kyocera e4000 windows mobile
i see this post in form how unlock benq e72 its same kyocera e4000
and see the post here
How to unlock BenQ E72
1. copy unclock directory to sd card.
2. First install "E72_Unlock.cab" inside firstinstall directory
3. Then run "Unlock.Enable.cab"
4. Finally application security is unlocked.
Note: You can create shorcut for Unlock.Enable.cab and Unlock.Disable.cab
through start menu. In order to call with fring first, run
"Unlock.Disable.cab" then run fring. Thus, during call there is no
gsm disable problem. After exit fring you can run "Unlock.Enable.cab"
and go without security lock. "System.Default.cab" inside default
directory returns device default factory settings. In order to activate
unlocked again you have to run "E72_Unlock.cab" first.
Yes, only unlock install Aplications
but in kyocera e4000 not done i try with all steps but nothing happend the phone still ....network pin need
please i search by google but nobady know how i can unlock this phone .
if any one have solution tested please post here
Old 12-18-2009, 18:16   #2 (permalink)
Member: 829391
Thanks Meter: 21
The process you've done is for unlocking app install. Now you can install any app you want.
If you want to SIM umlock it (to use it on antoher carrier), then you have to flash it with a different ROM
How to block incoming calls for windows mobile phone imtpro HTC & PDA WM( With Touchscreen) 0 08-18-2009 02:26
Unlock Kyocera M1000 Virgin Mobile hihihaha GM-Box 0 06-25-2009 04:04
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.09676 seconds with 8 queries
