Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC & Smartphones ( WM Without Touch)
HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices
Old 01-04-2009, 14:48   #1 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
HTC kais 130 successfull unlock
Kaiser 130 successfull unlock but now no sound
can any one tell me now what shold i do
very very argent pls
The Following 3 Users Say Thank You to delower10 For This Useful Post:
Old 01-04-2009, 21:42   #2 (permalink)
szig's Avatar
Member: 365452
Thanks Meter: 838
Hi!
Flash it with a proper radio rom or official rom(full official roms contain radio rom and those 100% compatible).Maybe your unlock method works with radio downgrade or a different radio rom,that needs reflash original radio rom after unlock.
Szig
Old 01-08-2009, 07:34   #3 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
thanks for reply my problem is solv now.............thanks
Old 02-09-2009, 11:46   #4 (permalink)
Member: 556786
Thanks Meter: 20
Bro i am having same problem with my set which from 3G oparetor. Tried to update with different files but no sound.
Can any one solve my problem.
Thanks
Old 02-09-2009, 11:56   #5 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
Kais 130 rom download
Bro update ur kais then all ok this file working 100% thanks
The Following 11 Users Say Thank You to delower10 For This Useful Post:
Old 02-09-2009, 13:15   #6 (permalink)
Member: 852575
Thanks Meter: 11
hi,
Flash it with a proper radio rom or official rom(full official roms contain radio rom and those 100% compatible.)its always better to flash with orginal firmware. you can search it from fourm its there.
Old 02-09-2009, 16:05   #7 (permalink)
szig's Avatar
Member: 365452
Thanks Meter: 838
Originally Posted by umeradeel View Post
hi,
Hi!
It's strange.The first sentence is so familiar to me,why?
That is what I wrote above:
Hi!
Szig
Please appreciate my work and at least quote my post,not copy-paste.
Thanks!
Szig
Old 02-10-2009, 05:54   #8 (permalink)
Member: 556786
Thanks Meter: 20
yes bro my problem solve with update bro again thanks for reply
Old 02-15-2009, 07:38   #9 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
congrates for successfull unlock well done
Old 05-29-2009, 12:11   #10 (permalink)
doonyi's Avatar
Member: 821156
Thanks Meter: 42
Originally Posted by szig View Post
Hi!
Szig
i have the same problem how do i unlock this phone . please, i need procedure.
Old 05-29-2009, 12:17   #11 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,184
Upgrade Rom
http://www.4shared.com/file/80379367...E_3347212.html
Old 05-29-2009, 19:24   #12 (permalink)
doonyi's Avatar
Member: 821156
Thanks Meter: 42
Originally Posted by nasirkhan007 View Post
no file in rapidshare?
Old 05-29-2009, 19:35   #13 (permalink)
doonyi's Avatar
Member: 821156
Thanks Meter: 42
please, i need to unlock my kais 130 can any body give me procedure as to how i can unlock it. it is t mobile and network code. thanks in advance
Old 05-29-2009, 19:37   #14 (permalink)
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,184
FIRST YOU NEED TO UNLOCK CID UNLOCK YOUR DEVICE.
DOWNLOAD LINK : http://rapidshare.com/files/85462026...-tool.zip.html
Instructions
0. Make sure there is a working SIM in the device.
1. Make sure you installed HardSPL as follows: power off and then press power on while keeping camera pressed, this will enter the so called bootloader mode and you see a tri-color screen (Red, Green, Blue). You should see "SPL-1.0 OliPof" or "SPL-1.1.JockyW" on the second line in the top left corner. You can exit this mode by means of a "soft reset": press the reset button with the stylus. Note that the security unlocker does not work with "SPL-3.28.Hard" and "SPL-3.29.Hard".
2. Make a note of the radio version that is currently installed. You see the version strings in the splash screen which appears soon after power on (e.g. "R 1.27.14.09"). Since we will flash a special radio in step 5 you need to flash back your original radio in the last step. You can download radio roms from XDA devs here.
3. Connect PC and Kaiser with a USB cable and keep it connected until the last step.
4. Power on the Kaiser and let it boot into Windows Mobile. On the PC make sure the activesync icon is green.
5. After you unpacked the download you see directories "step1" and "step2". Go into "step1" and run KaiserCustomRUU.exe. This will flash the special patched radio rom. Follow the instructions until it is finished. IMPORTANT: Make sure that the flash correctly finished. The device will restart automatically once the flashing is completed.
6. Power off and power on in tri-color bootloader mode.
7a. right-click activeync icon and uncheck "Allow USB connections" from Connection Settings
7b. On your PC go into the "step2" directory and run "kaiser-supercid.exe". If all went well you will see the text below
7c. right-click activeync icon and check "Allow USB connections" from Connection Settings
Text shown if all went well:
=== Kaiser SuperCID and Security Unlocker v0.2 (c)2008 by jockyw2001
=== Donations happily accepted, paypal to [email protected]
[] Done, your device should now be superCID and Security Unlocked
[] Your device is unlocked and you can change anything anytime
[] Don't forget to flash your original radio
Press Enter to exitIf you see this:
Your CID = HTC__001
[] Failed! Please soft reset and try again
[] To soft reset press and hold camera button and then press reset with stylus
Press Enter to exitthen do a soft reset (press and hold the camera button first and then shortly press the reset button with the stylus) and run "kaiser-supercid.exe" again.
8. Download the original radio from here to the "step3" directory on your PC and flash it with KaiserCustomRUU.exe
That's all folks
AFTER CID UNLOCK USE THIS ROM FOR ENGLISH LANGUAGE.
http://rapidshare.com/files/57816419..._Ship.rar.html
The Following 3 Users Say Thank You to nasirkhan007 For This Useful Post:
Old 05-29-2009, 20:31   #15 (permalink)
:: Micron ::'s Avatar
Member: 252289
Thanks Meter: 107
Search this file and flash it, that's all " KAIS_Radio_Only_1.27.12.11_CustomRUU "
htc kais 130 o2 unlock? zena1122 HTC & Smartphones ( WM Without Touch) 0 11-17-2008 12:55
HTC kais 130 stuck on "smart mobility" dannyogolo HTC & Smartphones ( WM Without Touch) 1 10-14-2008 18:27
Htc kais 130 Warptech HTC & PDA WM( With Touchscreen) 1 10-13-2008 05:01
HTC Kais 130 vipimg HTC & PDA WM( With Touchscreen) 0 09-26-2008 07:04
HTC Kais 130 (TyTN II) grgoni HTC & Smartphones ( WM Without Touch) 0 09-03-2008 17:41
Page generated in 0.24535 seconds with 9 queries
