PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
02-08-2008, 06:27 | #6796 (permalink) |
Junior Member Join Date: Feb 2008
Member: 695029 Status: Offline Thanks Meter: 0 | |
02-08-2008, 06:30 | #6798 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: super saiyan BLOCK,G-O-Ds CITY
Member: 678547 Status: Offline Thanks Meter: 30 | Quote:
so sad no problem you can always usethe patched file lifedrive | |
02-08-2008, 07:01 | #6803 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Around
Member: 416272 Status: Offline Thanks Meter: 1,095 | Destaller 3.0 Quote:
Destaller Pro is an application oriented uninstaller. Applications store many different files that often cause resets and the necessity to do a hard reset when not removed properly. Destaller removes this danger and headache. In addition Destaller allows you to maximize the memory of your device by allowing to safely remove single files, 'a68k' Files, saved and unsaved preferences and more. If you ever had problem with an application and were told by tech support to gather specific information about your device plus a list of all installed applications and Hacks, you will greatly appreciate why Destaller Pro is an excellent tool for trouble-shooting problems. It can export or copy a list of all applications found in RAM and on memory cards, has an extra screen for important device information, and lets you delete an application's data files separately. 1. Install Keygen ONLY 2. Reg with any digits you want 3. You will receive your reg code and your device will reset 4. Uninstall the keygen 5. Install the program 6. Register with your given number | |
The Following User Says Thank You to RogueSaber For This Useful Post: |
02-08-2008, 11:40 | #6805 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: New York where the Giants roam Age: 34
Member: 457382 Status: Offline Sonork: 700p, Centro, Pre, Evo, I Thanks Meter: 4,365 | Quote:
here is bookbag plus exe http://rapidshare.com/files/90104660...setup.exe.html and here is the keygen for it http://rapidshare.com/files/90104975/keygen.exe.html enjoy | |
02-08-2008, 12:52 | #6806 (permalink) |
Member: 698860 Status: Offline Thanks Meter: 0 | |
Pocket PC Appz & Games | HuBMOBILE | HTC & PDA WM( With Touchscreen) | 8203 | 12-05-2019 14:12 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Palm OS Appz & Gamez | LBOZ_GSM | PalmOS /HP and others | 1014 | 05-05-2009 21:45 |
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% | usman8416 | Nokia Multimedia | 0 | 06-24-2008 21:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
