Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > PalmOS /HP and others
PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic
Old 04-12-2008, 05:45   #8971 (permalink)
Member: 666249
Originally Posted by NinjaBoyz View Post
Anybody know where i can find cheap palm Life Drive??
How much are you willing to spend?
Old 04-12-2008, 06:14   #8972 (permalink)
NinjaBoyz's Avatar
Member: 743791
Sonork: Naruto
Thanks Meter: 102
Around $180 or higher for used one...
Old 04-12-2008, 07:35   #8973 (permalink)
Member: 587325
Thanks Meter: 24
Skyscape KG STILL working!!
Originally Posted by RogueSaber View Post
Until a new kg is finally created & if MJ13's solution doesn't work, try this:
Once you've installed all the SkyScape progs, over-write the smart library files with an older version here: http://rapidshare.com/files/10680056...ries2.7.37.rar
Then use currently available kg to reg.
Note: After doing so, if you load any other skyscape progs, don't load the smartlibraries that come with it or you'll have to over-write them again with the older ones...
(Wow...600 pages...)
Thank you very much RogueSaber, The Skyskape KG is still working!! I opened the wrong file, --- application instead of pdb. there is no need for a second KG now. Very sorry for causing a MESS. I hope I can be forgiven by inhabitant of the great World (forum?) This is a lovely forum.
I am still waiting for the SpellingBee
Old 04-12-2008, 10:04   #8974 (permalink)
lifedrive-n's Avatar
Member: 678547
Thanks Meter: 30
Originally Posted by MIKEJONES13 View Post
NO LD, don't take it in. First get your install cd ready........ Turn the MAC off.. Then press and hold down the apple key, the option key, the P key and the R key. While holding them down.....hit the power key. Don't hold the power key down just tap it. AND HOLD DOWN APPLE, OPTION,P AND R. Your computer will kinda boot up once....continue to hold those keys down. It will take between 30 second and 1 min to boot up again. All in all you will hear that bootup sound TWICE. After the second time release all the keys.. that will reset the PRAM in your computer that should work. If not use the install CD to do an ARCHIVE AND INSTALL. It will reinstall the OS on your computer but it will also save all your settings and files you have NOW. Hope this helps!
MIKE... do you by any chance work for apple? do you work for them?
they gave me the same tricks to do this. exact same steps and all
well i went through them and archive and install didn't work so i had to go through erase and install. they asked me to bring over my mac and they would back up the data but then i'd have to pay for that despite me owning the three year APPLE CARE
so i said that the data wasn't so important yet. so i simply erased and installed and said goodbye to all my data.
NOW I AM USING TIME MACHINE
LD
Old 04-12-2008, 10:06   #8975 (permalink)
Member: 678547
Thanks Meter: 30
I juz created the google groups here is the link:
[email protected]
anyone who intrested in sharing their ordinary or problematic files can post it here and members to this group will receive any software update posted by members automatically..
anyone interested to join in juz quote their emel to this message and i will send the invitation to join this group..
well i think that this is an amazing idea.
i think this should be really good.
LD
Old 04-12-2008, 10:11   #8976 (permalink)
Member: 678547
Thanks Meter: 30
LOL, I guess I need to stop waking up and going straight to this forum I end up forgetting to add certain directions.
LD, if you are going to do the archive and install method. Turn the computer on and insert the disk. The OS does not need to load in order for you to insert the disk. Turn the computer off. If its stuck force quit (hold down the power button) it will turn off. Next Hit the power button and as soon as you hear the startup tone, hold down the C key. That will force your computer to start up using the Install CD. Hold down the C key until you see the wheel spinning under the Apple Symbol. Then and only then can you release the C key and it will Start up like your installing OS X go through the steps and when it ask what type of install....Fresh Install-means format HD and lose all Data, Archive and Install-saves all files, folders and settings this is the one you want. When It goes to check the Media of the CD....DO NOT SKIP THAT PART. I had trouble getting a G4 laptop to image and I finally installed Leapord on it only to skip the part where it checks the Media files...That was a bad move, I ended up having to FORMAT the HD and then reinstall everything. Let me tell you it was a pain in the A$$ considering I was on a time limit and G4 processor is only like 700 MHZ.
i tell you what??? i think you are an apple genius.
and sure the G4 would have been a serious pain. i bet you couldn't sit all day
well good for me that my MB is 2.4 GHz (YAY!!!)
and i also have 2 GB RAM (YAY AGAIN!!!!)
LD
PS:archive and install didn't work i have to reinstall everything (i had to format the HD Too)
LD
Old 04-12-2008, 10:12   #8977 (permalink)
Member: 678547
Thanks Meter: 30
Originally Posted by ieatlotz View Post
Does anyone know if its safe to overclock palm tx, if so which app?
1. if you want to be completely safe then don't do it.
2. if you still feel that T|X is slow and want to really overclock it then use warpspeed by dmitry. (posted by me)
LD
Old 04-12-2008, 10:14   #8978 (permalink)
Member: 678547
Thanks Meter: 30
Don't give up on me yet...I'm not done trying to fill your request....
Download v.5.45 here:
http://www.zztechs.com/product.php?prod=ZLauncher
And use the kg below to reg.
Note: I believe this one is in Spanish so:
Put your hotsync ID under where it says "Nombre:" (I can't recall if this is done automatically, I think it is). Then you can click "Copiar al Portapapeles" [Copy to Clipboard]. From there you can register like most other apps [In ZLauncher: "Menu >> About/Register >> Register"].
(Hey, what do ya know...I can upload files again...Server fixed?)
remember country, no one ever gives up on saber. it's only he who gives up on others
LD
Old 04-12-2008, 10:18   #8979 (permalink)
Member: 678547
Thanks Meter: 30
not from me. i am selling it for 996 USD.
if you are willing to buy it then i may think about it.
prices are subject to market demand (with me it only goes up)
well, i did find some links at amazon and ebay.
did you search them?
although they do fool sometimes
LD
Old 04-12-2008, 10:42   #8980 (permalink)
Member: 678547
Thanks Meter: 30
thank you for the site kingtyce.
i am now downloading acrobat corporate edition for mac, photoshop exrended and i am downloading flash form adobe site and using the patches i have to patch them.
thank you again
and thanks MIKEJONES13 for constant help and always helping me out when i had problem with my new MB
thank you all as sometime or another, all of you have helped me.
thank you zfrank for creating this forum and thank you administrators for not banning me till now which would be catastrophic for me to be posting this post here
PS: thank you roguesaber... you have also helped me with my LD on numerous occasions which i cannot forget.
LD
PS2: now start counting how many times i have used "thank you" in this post
PS3:bye
PS4:i am trying to create a sony play station series here
LD
Old 04-12-2008, 15:52   #8981 (permalink)
Member: 666249
Ok, so listen........This may sound a little bit crazy but I bought both my treo 650 and blackberry curve on eBay. I have absolutely no regrets about my purchases. The treo was a total hit! It was used and came in great condition with absolutely no trouble or glitches. That cost me $135.00 USD. The curve was also a total hit, it was brand new and cost me $299.00 USD. It was unlocked and unbranded and came from a Canadian seller, which cut down on shipping and because I live in Canada, there were no customs charges. My wireless phone company wanted to give me the same phone for the same price , but I had to sign an additional year if I purchased it from them. I said f%c# that and f&c# them. Now with that said, be advised that I have had some bad experiences on ebay. But it always ended up with me getting my money back. If you do decide to go the ebay route, make sure that you check the sellers ratings before purchasing a product. Here is a link to ebay that may interest you.
http://cell-phones.attr-search.ebay....Z1QQsofocusZpf
Let me know what you think.
Blizz
Old 04-12-2008, 16:59   #8982 (permalink)
Member: 718168
Sonork: Treo650 507mhz, Nokia5800
Thanks Meter: 441
Originally Posted by cyangemini View Post
On another note, I'd like to "second" this request for a new Skyscape KG
I think you can find it here: http://crackzplanet.com/index_3_a.html
Old 04-12-2008, 18:42   #8983 (permalink)
Member: 587325
Thanks Meter: 24
Skyscape KG on the thread WORKS WELL
The Skyscape keygen on this forum really works very well. I used it just yesterday and it is fantastic. I initially had problems because I opened the wrong file. There may not be a need for a new KG now.
IS THERE A KG FOR THE DESKTOP VERSIONS? I would love to have that.
Old 04-12-2008, 18:59   #8984 (permalink)
Member: 718168
Thanks Meter: 441
this is for everyone, good sites:
katz.cd
joox.net
Old 04-13-2008, 02:58   #8985 (permalink)
RogueSaber's Avatar
Member: 416272
Thanks Meter: 1,095
Originally Posted by LtOpie View Post
Hey All,
For the RegCodes for
Pocket Mini Golf...
Opie
Since I've already posted PMG-Extra....Here's PMG w/ kg:
http://rapidshare.com/files/10704175...etMiniGolf.rar
RS
Pocket PC Appz & Games HuBMOBILE HTC & PDA WM( With Touchscreen) 8203 12-05-2019 14:12
Nokia Latest Appz & Games Section HuBMOBILE Nokia Multimedia 17 11-21-2010 14:03
Palm OS Appz & Gamez LBOZ_GSM PalmOS /HP and others 1014 05-05-2009 21:45
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% usman8416 Nokia Multimedia 0 06-24-2008 21:01
WM5 Pocket PC Appz & Games eboy44 HTC & PDA WM( With Touchscreen) 2 08-08-2006 22:23
Page generated in 0.38058 seconds with 10 queries
