PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
01-15-2011, 10:03 | #1 (permalink) |
Insane Poster Join Date: Feb 2009 Location: It's More Fun in D Philippines
Member: 969009 Status: Offline Thanks Meter: 18 | Palm Pre Plus Lock to AT&T Success Unlock Via USB And Here's the result- I used SUN Cellular I Follow This Procedure! Palm Pre2, Palm Pre & Pixi Unlock Instructions Run the unlock client from “START > Multi Unlock Client > Unlock Client”, you will also need to enter your username and password and click “save login data” and make sure “main Server” is selected under the settings tab, make sure you click “Save Login Data” NOTE: Pix, pre & Pre2 require different credits; please insure your account has the required service active for the type of phone you are trying to unlock. 1. On the phone enter “Diag Mode” a. On your Palm Pre go to ‘Device Info’, write down the 12 digit serial number (please remember it is case Sensitive) b. Enter the serial number into the calculator “START > Multi Unlock Client > Pre Pass Through Keygen” (exactly the same if you have a pixi ot a pre) c. Go to the phone app on your palm pre or pixi d. Start typing #*8727277# and press DIAL as if trying to call this number e. Enter the code from the ‘Pre Pass Through Keygen’ and click ‘validate’ (if requested) f. In the window that appears, select “Configure USB pass-through” g. Set DIAG for USB Port 1 h. Connect your Phone to the PC using USB cable. i. If/when prompted by the phone select “Just Charge” 2. You need to install drivers when the new hardware found message dialog appears on your PC (see page4 for more info) a. When asked if you would like windows to search for a driver, select “No not this time”, Then select “Install from a list or specific location”, then click “Next” b. Then select “Search for the best driver in these locations”, then check “Include the following location” c. on the next screen click on “Browse” d. Browse to “C:\Program Files\Multi Unlock Client\Palm Pre\Drivers” or “C:\Program Files\Multi Unlock Client\Palm Pixi\Drivers” depending on the phone you are unlocking. e. Click “Next” and the wizard will install the drivers f. Once the drivers are installed, Unplug & replug phone, click “OK” on the unlock client dialog box. 3. Unplug & Replug Phone to USB cable. 4. Select Palm Tab, and replug phone. 5. Now to Unlock Your Phone a. When the software tells you that “you may proceed”. b. Click “Unlock” , the software will now unlock your phone c. Where possible the blocked counters will be reset. Last edited by makasa; 01-15-2011 at 10:10. |
01-29-2011, 21:03 | #2 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1482280 Status: Offline Sonork: 100.1600954 Thanks Meter: 23 | Quote: Make sure you have Diag driver installed If you have any USB monitors installed Uninstall and reboot before using the software Now you should install Diag drivers if it's not installed Palm device connected Data collection error, check drivers AND WHEN I CONECT USB Media sync usb drive just charger i select what?????????? |
02-24-2011, 21:01 | #10 (permalink) |
Insane Poster Join Date: Oct 2007
Member: 621321 Status: Offline Thanks Meter: 8 | cant find drivers hi guys, i have looked every where for the WIN XP drivers Generic SERIAL Reduced CDC Abstract control Modul (R-ACM) RNDIS Ethernet Gadget i have installed the v38 multiunlock client and dongle but it cannot find the drivers. can anyone help? thanks in advance |
02-24-2011, 22:04 | #11 (permalink) | |
No Life Poster Join Date: Jul 2010 Location: North Africa
Member: 1350724 Status: Offline Thanks Meter: 188 | Quote:
Now Disable Diag Mode:- 1. On the phone enter “Diag Mode” a. On your Palm Pre go to ‘Device Info’, write down the 12 digit serial number (please remember it is case Sensitive) b. Enter the serial number into the calculator “START > NEXTGEN SERVER > Multi Unlock Client > Pre Pass Through Keygen” (exactly the same if you have a pixi ot a pre) c. Go to the phone app on your palm pre or pixi d. Start typing #*8727277# and press DIAL as if trying to call this number e. Enter the code from the ‘Pre Pass Through Keygen’ and click ‘validate’ (if requested) f. In the window that appears, select “Configure USB pass-through” g. Go to the phone app on your palm pre or pixi h. In the window that appears, select “Configure USB pass-through” i. Set USB Port 1 to “diag” | |
02-25-2011, 02:04 | #12 (permalink) |
Member: 621321 Status: Offline Thanks Meter: 8 | Thanks ive already done all that , now when i plug it into my pc, it asks for the drivers, which are supposed to be in the C:\Program Files\Multi Unlock Client\palm pre\drivers folder, but they aren't there also not in the C:\Program Files\Multi Unlocker Dongle\palm pre\drivers folder either. ??? there's no support for this anywhere ive tried googling the driver name and cant find anywhere |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
