Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > _Games and App for Android phones
Old 07-11-2019, 08:10   #1 (permalink)
Member: 2905924
Thanks Meter: 6
How to root Android with Framaroot
In the Android community, we mostly talking about related stuff on Android rooting. Why people obsessed with it like this? That's a good question. Obviously because of the benefits that can get from it. Gaining Superuser privileges will open a new world of experience for you. Not to mention that there are thousands of cool apps for rooted devices. But as you all know there I a huge risk in this process. So to reduce that risk you have to select the correct rooting tools for root Android. This is one of the best. Let's learn about Framaroot.
If you intend to root Samsung Smartphone or tablet you better visit this site - https://odindownload.com/root-android/
Android rooting with Framaroot
This tool is the list of best rooting tools in 2019 in the XDA developers forum. So what is the specialty of Framaroot? Actually, this root tool considers a universal root tool because it includes a few exploits that can work with more than 300 devices. If one exploit doesn't work you can try it again with another exploit. It is so easy to use and not to mention that its so reliable tool. But before anything else you have to check the compatible list because if your device isn't there it's useless to try rooting. But one of specialty is I must mention. If you are a lover of lord of the ring series names of exploits that attached here will be meaningful for you. Those are the characters of the story.
Compatible Exploits for devices
  • Qualcomm - Gandalf
  • MTK - Boromir, Faramir, Barahir
  • Huawei K3v2 - Pippin
  • Amlogic - Gollum
  • Samsung - Legolas, Aragon
  • Exynos - Sam, Frodo, Legolas, Aragon
  • Omap36xx - Gimli
How to root Android
  1. Check the XDA Developers forum and find out your device is compatible or not.
  2. Download the Framaroot APK to your computer
  3. Connect the device with the computer using a USB cable.
  4. To enable the unknown resources go to Menu --> Settings --> Security --> Unknown Sources --> Enable
  5. Move the APK which downloaded to the SD card
  6. Disconnect the device from the PC
  7. Go to the file manager and find the APK just moved.
  8. Install the APK like a common application.
  9. Launch the application.
  10. Go to the first drop-down menu and select SuperSu from the list.
  11. Now select the correct exploit and next moment Framaroot will begin to root.
  12. You have to wait less than 10 seconds.
  13. As the final step, you have to reboot it after the process completes
https://www.youtube.com/watch?v=cIx107epvZc&fs=1" width="644" height="390">https://www.youtube.com/watch?v=cIx107epvZc&fs=1" />https://www.youtube.com/watch?v=cIx107epvZc">http://www.youtube.com/watch?v=https://www.youtube.com/watch?v=cIx107epvZc
Final verdict
As my opinion, Framaroot is one of the best for Android rooting. But it also couldn't avoid the cancellation of your warranty card on the device. But we have a method to restore it. This tool is not only for rooting but also for unrooting. So you can unroot the device if you want the warranty.
Page generated in 0.11869 seconds with 8 queries
