Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 09-09-2014, 04:25   #1 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
9810 only EDGE after repair red blink
have problem 9810 after repair red blink singnal only EDGE wont 3G and H+
rebuild imei and write NV but still same.
any others solution for get 3G and H+ on my set?
thanks
Old 09-10-2014, 02:11   #2 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
45 peoples reading my post..but no one have solution......
Old 09-11-2014, 06:22   #3 (permalink)
Member: 25662
Thanks Meter: 190
not neccessary all peoples reading your have solution for your problems,may be they also need soultion as you need.
1.In manual search does it show 3g network? If yes than hardware if no than software.
2.For hardware in your country which band is used for 3g. they are most 3 band used for 3g network.band-1, band-2 and band-8.according to your net work change 3g PA U302 for band-1, U301 for band-2 and U300 for band-8. also check its supply volt V_PA(3.6v).
take help of schematic i m very lazy to creat picture from schematic.
3.than also not ok than change U202 main antenna switch ic.
now
Old 09-12-2014, 12:17   #4 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
now
iin manual searching not show 3G....before red blink 3G signal is oke.
Old 09-12-2014, 12:37   #5 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
thanks
You could tell me how and what you used for the repair tool
Old 09-12-2014, 12:50   #6 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Just verified its the new OS either something is broken or there is a new setting I need to change.
Another quick note you must compared both your phone and the co-workers phone who is running the older firmware and all settings are the same, iE browser push, firewall, etc.
I think the only resolution will be to roll back your firmware or wait for the next release from failberry firmware team.
When you do the network Diagnostic what does your phone show? UMTS or HSPA+?
Ive been reading that a lot of android phones show H+ even for standard UMTS 3G signals. Wondering if thats the same for Blackberry's.
"The "H+" icon is a network indicator. When present, it lets you know that your phone is operating on our 3G or 4G network (where available)."
"The H+ icon will remain lit while connected to either our 3G mobile broadband or 4G network (where available). Should you travel outside of those coverage areas and/or experience extreme network congestion, the icon may display EDGE or E while on our 2G data network or, in some instances, it will display GSM."
Page generated in 0.16330 seconds with 8 queries
