BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
01-30-2012, 10:16 | #1 (permalink) |
Junior Member Join Date: Jan 2012 Location: B A N G L A D E S H
Member: 1716250 Status: Offline Thanks Meter: 37 | BlackBerry software * hardware reset here BlackBerry software * hardware reset here BlackBerry 9700 Bold hard reset Press: ALT + SHIFT + DEL or Format the device memory or a media card If you format the BlackBerry® device memory or a media card, all the files in the device memory or on the media card are deleted. Depending on your device model, you might not be able to format your device memory. 1. On the Home screen or in a folder, click the Options icon. 2. Click Memory. 3. Press the Menu key. 4. Click Format. 5. Complete the instructions on the screen. Warning: All data on your phone will be deleted. |
The Following 10 Users Say Thank You to Gsmjker.love For This Useful Post: |
01-30-2012, 10:17 | #2 (permalink) |
Member: 1716250 Status: Offline Thanks Meter: 37 | BlackBerry 9670 Bold Reset the device Performing a Hard Reset on a BlackBerry Style 9670 Series A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry Style 9670 returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: 1. On the Home screen or in a folder, click the Options icon. 2. Click Security *gt; Security Wipe. * To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. * To delete all third-party applications that you have added, select the User Installed Applications check box. * To delete all files from your media card, select the Media Card check box. 1. Type blackberry. 2. Click Wipe. |
The Following 3 Users Say Thank You to Gsmjker.love For This Useful Post: |
01-30-2012, 10:18 | #3 (permalink) |
Member: 1716250 Status: Offline Thanks Meter: 37 | BlackBerry 9300 Reset the device A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry Curve 9300 returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: On the Home screen or in a folder, click the Options icon. Click Security *gt; Security Wipe. To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. To delete all third-party applications that you have added, select the User Installed Applications check box. To delete all files from your media card, select the Media Card check box. Type blackberry. Click Wipe. |
The Following 2 Users Say Thank You to Gsmjker.love For This Useful Post: |
01-30-2012, 10:19 | #4 (permalink) |
Member: 1716250 Status: Offline Thanks Meter: 37 | BlackBerry 9100 hard reset Reset the Blackberry 9100 pearl device A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry Curve 9300 returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: On the Home screen or in a folder, click the Options icon. Click Security *gt; Security Wipe. To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. To delete all third-party applications that you have added, select the User Installed Applications check box. To delete all files from your media card, select the Media Card check box. Type blackberry. Click Wipe. |
The Following 4 Users Say Thank You to Gsmjker.love For This Useful Post: |
01-30-2012, 10:20 | #5 (permalink) |
Member: 1716250 Status: Offline Thanks Meter: 37 | BlackBerry 9600 Tour hard reset Reset the device A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry 9600 or 9630 Tour returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: On the Home screen or in a folder, click the Options icon. Click Security *gt; Security Wipe. To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. To delete all third-party applications that you have added, select the User Installed Applications check box. To delete all files from your media card, select the Media Card check box. |
The Following User Says Thank You to Gsmjker.love For This Useful Post: |
01-30-2012, 10:22 | #6 (permalink) |
Member: 1716250 Status: Offline Thanks Meter: 37 | BlackBerry 9500 Storm hard reset Reset the Blackberry 9500 or 9530 device A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry Storm 9500 or 9530 returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: 1. On the Home screen or in a folder, click the Options icon. 2. Click Security *gt; Security Wipe. * To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. * To delete all third-party applications that you have added, select the User Installed Applications check box. * To delete all files from your media card, select the Media Card check box. 1. Type blackberry. 2. Click Wipe. |
01-30-2012, 10:23 | #7 (permalink) |
Member: 1716250 Status: Offline Thanks Meter: 37 | BlackBerry 9630 Bold Reset the device A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry Bold 9700 Bold2 or 9780 returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: On the Home screen or in a folder, click the Options icon. Click Security *gt; Security Wipe. To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. To delete all third-party applications that you have added, select the User Installed Applications check box. To delete all files from your media card, select the Media Card check box. Type blackberry. Click Wipe. |
01-30-2012, 10:24 | #8 (permalink) |
Member: 1716250 Status: Offline Thanks Meter: 37 | BlackBerry 8500 hard reset Reset the device A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry Curve 8520 or 8530 returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: On the Home screen or in a folder, click the Options icon. Click Security *gt; Security Wipe. To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. To delete all third-party applications that you have added, select the User Installed Applications check box. To delete all files from your media card, select the Media Card check box. Type blackberry. Click Wipe. |
01-30-2012, 10:25 | #9 (permalink) |
Member: 1716250 Status: Offline Thanks Meter: 37 | BlackBerry 8900 Reset the device A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry Curve 8900 or 8910 returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: On the Home screen or in a folder, click the Options icon. Click Security *gt; Security Wipe. To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. To delete all third-party applications that you have added, select the User Installed Applications check box. To delete all files from your media card, select the Media Card check box. Type blackberry. Click Wipe |
The Following 5 Users Say Thank You to Gsmjker.love For This Useful Post: |
10-29-2013, 23:03 | #10 (permalink) |
Junior Member Join Date: Sep 2012 Location: Al-ahsa,Dammam,Saudi Arabia.
Member: 1818129 Status: Offline Sonork: leo Thanks Meter: 0 | hello... i have BB 8900, its charge battery but after some time its start blink red light... plz tell me is it hardware or software.....? |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
ORIGINAL SOFTWARE FOR SALE OR TRADE !!!!!!!!!!!!!!!!! | andrew bennett | Main Sales Section | 1 | 07-27-1999 21:31 |
