BlackBarry 8100 at&t Flashing Problem BlackBarry 8100 Flashing Problem http://img96.imageshack.us/img96/2351/96678684.jpgI am tery Many Time Chence Flash File But Same Problem |
try this option Pre-Wipe Tasks 1. Download and install Jl_Cmder to your PC ( Click here to download Jl_Cmder ) Reference Link 2. Make sure ALL your data (i.e. contacts, appointments, memos and etc) are backed up or synced before proceeding! This will wipe everything off of the device 3. Make sure you have the latest version of both Desktop Manager and the Handheld OS installed on your PC. If you need them then download them from here: Desktop Manager and Handheld OS List 4. From the PC navigate to c:\program files\common files\research in motion\apploader and delete the file vendor.xml If you have never installed the Handheld OS before then the vendor.xml file will not be on the PC and you can skip this step 5. Plug the device into the PC using the USB cord and make sure Desktop Manager is closed 6. Remove the battery from the device Wipe The Device 1. Wipe the device using Jl_Cmder This may take several attempts to connect to the device, so keep trying until it connects and wipes 2. The device will reboot to a white screen with a '507' error If the device will not connect and wipe after several attempts then please follow the instructions here: What to do next if Jl_Cmder will not connect and wipe Install OS and Restore 1. Open Desktop Manager and select Application Loader 2. Install the OS by following the prompts and selections 3. The device will reboot. It can take up to 15 minutes for the 1st boot. 4. Restore the previously made backup or re-sync 5. Install the battery back into the device and unplug from the PC Images: http://www.blackberryfaq.com/media/cmdr/cmdr.jpg http://www.blackberryfaq.com/media/cmdr/cmdr1.jpg http://www.blackberryfaq.com/media/cmdr/cmdr2.jpg http://www.blackberryfaq.com/media/cmdr/cmdr3.jpg http://www.blackberryfaq.com/media/cmdr/cmdr4.jpg |
@ STBSL Try step by step : 1.Wipe ur BB, (using BBSAK or any tools) 2.Change USB cable. 3.Use USB without usb HUB. 4.Reload OS using Loader.exe. PS : Its communication problem try and post result. BR Delower |
