BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
02-18-2011, 19:55 | #4 (permalink) |
Junior Member Join Date: Feb 2011 Location: Kettering, UK Age: 36
Member: 1514219 Status: Offline Thanks Meter: 3 | How long have you let it sit at that screen? Sometimes it can take a while if it just after flash. Download the latest software here for the 8520. Install it and remove the vendor file. Depending on what your operating system is it should be in C:\Program Files\Common Files\Research In Motion\AppLoader or if you have x64 operating system C:\Program Files (x86)\Common Files\Research In Motion\AppLoader In that folder create a shortuct to loader.exe, modify the shortcut and put -nojvm on the end like this "C:\Program Files \Common Files\Research In Motion\AppLoader\Loader.exe" -nojvm Download JL_Cmder from here Run JL_Cmder and do a wipe of your blackberry Once your blackberry is wiped use the Loader.exe shortcut and try and start your blackberry again from there. Hope this helps, if it does click thanks |
The Following 3 Users Say Thank You to nickds For This Useful Post: |
02-19-2011, 17:02 | #5 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Indonesia
Member: 1290467 Status: Offline Thanks Meter: 180 | I have done all the suggestions but to no avail... This screen lasted until baterai discharged... Still waiting for some hint on how to fix this problem...) thanks advance...!!! Regard. |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
Only MAX232 ??? | AMIGO | Nokia Hardware & Hardware Repair | 7 | 04-12-2000 09:41 |
NEW ERICSSON A1018 £60 SIEMANS C25 £60 + LOADS MORE | MILLENNIUM-INTERNATIONAL | Main Sales Section | 0 | 08-31-1999 18:54 |
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed | spterminator | Main Sales Section | 0 | 08-08-1999 05:08 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
