BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
01-23-2013, 10:46 | #1 (permalink) |
Major Poster Join Date: Jan 2011 Location: indore
Member: 1493898 Status: Offline Thanks Meter: 0 | blackberry bold 9900 stuck on loading screen i have tried restoring software twice the firmware load successfuly but after that also stuck on the same position as it was earlier befor guyz plz help me to solve this prob...??? |
01-24-2013, 14:22 | #2 (permalink) |
Insane Poster Join Date: Aug 2012
Member: 1804175 Status: Offline Thanks Meter: 25 | use this tool http://forum.gsmhosting.com/vbb/f489...cript-1445534/ first nuked ur device and then dual wipe ur device. Done |
01-24-2013, 17:32 | #3 (permalink) |
Member: 1804175 Status: Offline Thanks Meter: 25 | or using this tool http://forum.gsmhosting.com/vbb/f489...bbcdm-1604213/ first nuked ur device and then wipe system ur device. Done.. |
01-26-2013, 10:36 | #4 (permalink) | |
Moderator Join Date: Feb 2006 Location: Bangladesh & Bahrain
Member: 233205 Status: Offline Thanks Meter: 5,014 | Quote:
how much percent its stuck or restart (although there no % count on screen) any idea? | |
01-27-2013, 13:22 | #8 (permalink) | |
Major Poster Join Date: Sep 2010 Location: baskom
Member: 1384861 Status: Offline Thanks Meter: 0 | Quote:
Look here broo your Problem Solved | |
10-15-2015, 13:09 | #12 (permalink) |
Freak Poster Join Date: Jan 2014 Location: pakistan
Member: 2114397 Status: Offline Thanks Meter: 157 | blackberry bold 9900 stuck on loading screen 1000000000% solution 1 charge your battery 2 download this tool (bb cmd by del_fanfan) link is below 3 install blackberry 9900 firmware download it searching by google 4 run bb cmd by del_fanfan tool 5 connect your bb9900 by usb cable with pc install driver if you are using window7 driver automatically will be install 6 on cmd by del_fanfan tools select WIPE FULL option 7 now your bb9900 is full wipe now you can see just red blinking light no lcd display its mean you successfully wipe your mobile if u can see lcd display after full wipe its mean your mobile not full wipe . 8 after wiping go to C drive where you install bb9900 firmware (c:\program files\common files\research in motion\apploader) and delete the file vendor.xml 9 Plug the device into the PC using the USB cord and make sure BB Desktop Manager is closed 10 RUN apploader now you can see bb9900 commport now just click next next and next bb9900 begin for flashing 11 just sit down be relax after 15 minutes your mobile start. during flashing dont connect any other mobile with your pc say thanx and reply if you got success 4shared.com - free file sharing and storage - Login |
The Following User Says Thank You to atiqmalik For This Useful Post: |
10-15-2015, 13:26 | #13 (permalink) |
Member: 2114397 Status: Offline Thanks Meter: 157 | use this link for tools downloading bb cmd by del_fanfan - Download - 4shared - fanfan del |
