BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
06-02-2009, 08:07 | #1 (permalink) |
Insane Poster Join Date: Nov 2005
Member: 204198 Status: Offline Thanks Meter: 17 | use full tip for error code Description Bad load Troubleshooting Use Application Loader to re-install the operating system and applications on the BlackBerry smartphone. Overview To use the Application Loader tool to install BlackBerry Device Software, complete the following steps: Download and install the latest version of BlackBerry Device Software . Open the BlackBerry® Desktop Manager. Connect the BlackBerry smartphone to the computer. If prompted, type your BlackBerry smartphone password and then click OK. Complete one of the following steps: If the Application Updates Available window appears, click Update Now. The Application Loader Wizard appears. If the Application Updates Available window does not appear, double-click the Application Loader icon. The Application Loader Wizard appears. Click Next. If prompted, type your BlackBerry smartphone password and click Next. Note: When the Application Loader Wizard is finished examining the configuration on the BlackBerry smartphone, the Device Application Selection screen appears with a list of applications available for installation. The selected check boxes indicate applications that are already installed on the BlackBerry smartphone. Select the check box for the BlackBerry Device Software. Click Next. If the On the Device Backup screen appears, choose whether to automatically back up the data on the BlackBerry smartphone, and then click Next. Click Finish to begin loading the BlackBerry Device Software. Click Close when the software is finished loading. |
The Following User Says Thank You to piyush For This Useful Post: |
06-02-2009, 08:13 | #2 (permalink) |
Member: 204198 Status: Offline Thanks Meter: 17 | tip Error Codes 395 Error Codes 395 Description Unclassified error code This error can be caused by a third party application installed on the BlackBerry device. Troubleshooting Erase and reload the data on the BlackBerry device.
06-02-2009, 08:21 | #3 (permalink) |
Member: 204198 Status: Offline Thanks Meter: 17 | tip error code 310-314 error code 310-314 Description Hardware failure Troubleshooting Perform a hard reset on the BlackBerry smartphone. Follow these steps to perform a hard reset on a BlackBerry smartphone.
1)Network---- Handheld displays an X beside the coverage indicator. Handheld displays GSM (Global System for Mobile Communication) or lower case gprs (General Packet Radio Service) as the network status indicator. User is unable to send or receive messages on the handheld 2)Software----
Handheld display is hard to read. For example, the display shows lines obscuring text. Keypad is not functioning correctly. For example, keys do not work, the trackwheel is not functioning correctly, or the handheld does not turn on |
06-02-2009, 08:25 | #4 (permalink) |
Member: 204198 Status: Offline Thanks Meter: 17 | tip Error Code 400-564,320-325,330-339,360-363,410-411 Error Code 400-564 Description Page faults Error Code 320-325 Description AMX failure Error Code 330-339 Description Application tasks failure Error Code 360-363 Description Flash memory failure Error Code 410-411 Description Radio failure Troubleshooting Use Application Loader to re-install the operating system and applications on the BlackBerry smartphone. To use the Application Loader tool to install BlackBerry Device Software, complete the following steps:
06-02-2009, 08:43 | #7 (permalink) |
Member: 204198 Status: Offline Thanks Meter: 17 | tip Error Codes 340-343 Error Codes 340-343 Description Memory failure Troubleshooting Reduce the number of calendar appointments synchronized to your BlackBerry device.
Run Application Loader to reload the operating system and applications onto your BlackBerry device. |
06-02-2009, 08:46 | #8 (permalink) |
Member: 204198 Status: Offline Thanks Meter: 17 | tip Error Codes 350-359 Error Codes 350-359 Description Software application failure Troubleshooting Perform a hard reset on the BlackBerry device or Run BlackBerry Application Loader to reload the operating system and applications onto your BlackBerry device. In the Application Loader Wizard window, do not select any third party applications. In the Advanced options, select the Erase all currently installed applications check box. |
06-02-2009, 08:55 | #9 (permalink) |
Member: 204198 Status: Offline Thanks Meter: 17 | tiptip Error Codes 505 507 Error Codes 505-507 Description No applications on BlackBerry device CAUSE Both of the error messages indicate that no applications are loaded on the BlackBerry smartphone. The error messages can have the following causes:
The following are possible resolutions for this issue. Cause 1 While using the Application Loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded Complete the following steps:
All data and applications are erased when an incorrect password is typed ten times into the BlackBerry smartphone. Resolution Complete the following steps:
The Power Management feature on the computer disables the USB ports. Note: This resolution is for Windows® XP users only. Resolution Complete the following steps:
The BlackBerry smartphone is connected to a laptop computer through a docking station. Resolution Complete the following steps:
Note: If Error 507 is displayed on the BlackBerry smartphone, the BlackBerry smartphone will not display as connected in the BlackBerry Desktop Manager. Use the Application Loader tool to install the latest version of BlackBerry Device Software on the BlackBerry smartphone |
07-01-2009, 02:16 | #12 (permalink) | |
Freak Poster Join Date: Feb 2008
Member: 714081 Status: Offline Thanks Meter: 8 | thats a good job ,wonderfull keep it up i realy appriciate your work Quote:
MicroBOX FULL ACTIVATED for sale | jokers5 | Sell ur Old and Used Stuff | 6 | 04-04-2010 12:19 |
merry chistmas gift to all cheap price and full service for unlocking codes | BAHRI PhoneWala | Main Sales Section | 0 | 12-20-2009 02:27 |
Some use full information for nokia | shinothalumkal | Nokia Hardware & Hardware Repair | 4 | 01-25-2009 10:23 |
Easy And Use Full Step For Haier C1000 Flashing Or Upgarding | DEEPDHILLON | Various CDMA/TDMA Cell Phones | 3 | 12-08-2008 13:41 |
VERY USE FULL LINK for REPAIRING HINTS and GUIDES. | DrMobile | GSM Mobile Links | 9 | 04-12-2003 16:37 |
