Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 04-11-2009, 19:49   #226 (permalink)
Member: 956117
Thanks Meter: 66
Originally Posted by clive48 View Post
Ok. I fixed tthe issue by reloading the prl.
Now voice & sms is working but nw is 1x & not 1X
BTW I don;t have BIS but only have data active on ESN which I swapped.\]
SO no idea how to make it work in 1x
Try loading VSM-18932-001, that might work.
Old 04-17-2009, 03:36   #227 (permalink)
Member: 171808
Which file will rebrand a 8320 to Rogers? I wish I knew how to decypher the VSMs and I'd gladly search myself. Need to enable UMA on an unlocked T-Mobile BB and I can't change the servers manually, it seems.
Thanks.
Old 04-17-2009, 07:40   #228 (permalink)
Member: 171808
Answer to my own question: VSM-21230-001
Much thanks to elseWescott in this thread for providing a VSM parser:
http://forum.gsmhosting.com/vbb/show...7&postcount=51
It's much easier to figure this stuff out when you can see the actual images and read the content in the files.
Old 04-17-2009, 12:33   #229 (permalink)
Member: 1002620
is there any way to debrand a blackberry storm 9530
Old 04-20-2009, 08:33   #230 (permalink)
Member: 1012267
Does anyone know the VSM for T-mobile 8100 Please and thanks..
Old 04-20-2009, 10:10   #231 (permalink)
Member: 956117
Thanks Meter: 66
Yes, the 9530 can be debranded by finding someone skilled in surface mount soldering and have them remove the flash memory and put it in a reader and create a dump file from it. I'll be happy to review the dump file for you to point out where the VSM file is and then you can choose the VSM file you wish to load and replace the one currently in the dump file. Finally you will have the modified dump file loaded onto the flash memory and have the flash memory soldered back in to the BlackBerry.
I am not aware of any other means of "debranding" the 9530 at this time.
Old 04-20-2009, 12:21   #232 (permalink)
Member: 1011667
Thanks Meter: 12
8700c unlock done
flash for recconect jvm set restart
not flash
Old 04-23-2009, 11:12   #233 (permalink)
Member: 989283
I am from Venezuela, using a Blackberry storm 9530 unloked I need debrand my 9530 change logo verizon for rim screen logo
thanks..
Old 06-09-2009, 07:53   #234 (permalink)
rajan nishchal's Avatar
Member: 75612
Thanks Meter: 1,427
Finally we have solve the mystery of vsm files
FINALLY WE HAVE SOLVE THE MYSTERY OF VSM FILES (DEBRANDING - Prosumer Data UNLOCK - SUCCESS !! )
http://forum.gsmhosting.com/vbb/showthread.php?t=765762
Old 07-25-2009, 08:13   #235 (permalink)
Member: 75773
Sonork: dss
Thanks Meter: 3
8700 ke pad not work
hi
help me
[email protected]
Old 07-31-2009, 20:32   #236 (permalink)
Member: 642071
Thanks Meter: 54
8310
Originally Posted by sdtv13 View Post
load servis software with loader
open hidden menu(ctrl+shift+alt+f12) on MML
hit load vsm
http://rapidshare.de/files/41130096/VSM-09712-002.html
and reaload software
THANKS! work on 8310
Old 09-04-2009, 16:46   #237 (permalink)
dexter_mn's Avatar
Member: 311316
Thanks Meter: 41
what will do on full erased phone?
cant become no os mode?
Old 09-15-2009, 21:33   #238 (permalink)
cpr.orlando's Avatar
Member: 843747
Thanks Meter: 40
Im looking for a at&t vsm file for the 8800 so i can rebrand it.. Anyone have any ideas?
Thanks in Advance
Old 09-19-2009, 13:51   #239 (permalink)
Crazy Poster
Member: 574744
Thanks Meter: 8
9530 debranding
Hi
Is it possible to debrand 9530 Verizon?
If yes, can I use the same vsm files which are used for 8xxx?
Pl confirm & also tell teh process as Mfi loader doesn;t work with 95xx
Old 10-08-2009, 15:15   #240 (permalink)
vrepair's Avatar
Member: 46125
Thanks Meter: 59
Any newest version of mfi loader? And now in recent blackberry bold its not possb to change the operator logo by loading vsm files bcoz of new firmware and new security
Pls I need solution on how to debrand blackberry bold 9700. Slyassnakes BlackBerry (RIM) 0 03-19-2010 09:24
any solution for unlock blackberry ? ALGUIEN PolarBox 3 2 09-26-2008 07:25
any solution for unlocking blackberry pearl ? TRABEL BlackBerry (RIM) 3 08-18-2007 13:49
Page generated in 0.20909 seconds with 10 queries
