BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
10-08-2009, 15:38 | #241 (permalink) |
No Life Poster Join Date: Dec 2003 Location: in the center of the heart
Member: 46125 Status: Offline Thanks Meter: 59 | |
11-06-2009, 15:32 | #247 (permalink) |
Junior Member Join Date: Mar 2009
Member: 985100 Status: Offline Thanks Meter: 0 | Pearl 8120 on orange UK , is unlocked looking for a unbranded (RIM) VSM file and if possible the original orange uk vsm file for converting back if need to return for warrenty. thanks in advance |
11-09-2009, 04:56 | #249 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1157120 Status: Offline Thanks Meter: 0 | hey can someone post a link of this files ASY-16069-012 APP-19790-003 PRD-18297-001 they are part of a blackberry 8120 files system , i need to upload those files to my blockberry becouse some one delete it with the cfp.exe command , ( dont know how but they are not in the bb) so with out those files no bb service for this bb ... i have a bb unloked, need to be EDGE not (edge or GSM) becouse my sim is a bb compatible is working in other bb so the problem is this bb. i did all, with the mfi multiloader, the wipe. i have installed like 30 times the OS . some more info> also i debrand to a blackberry logo , provider 1 and is the same in my other bb and in the other work great but when i run the mml.exe and i see the the SW Part List this is what i get.. (alt+ctrl+shift+f12) i get this: MFI-15780-020 ( also this i use some other MFI-15780-017 i think but it work for unlockng not for EDGE SIGNAL) HWV-16149-004-2 ( this i dont know wut is) VSM-18862-001 ( this i have changed several times but nothing happed only the logo change no EDGE SIGNAL) i notice that several file system files are missing i found some place to get only the name not the real file http://forum.gsmhosting.com/vbb/arch.../t-789539.html but there is no files on the web ... could some one help me with this... |
12-02-2009, 17:05 | #252 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | Quote:
WBR ReyTech. | |
02-01-2010, 19:31 | #254 (permalink) |
Junior Member Join Date: Jan 2010 Location: UK
Member: 1222490 Status: Offline Thanks Meter: 0 | WARNING: Try on your own risk! Here is a step by step guide to debrand/change your Vendor ID on Blackberry. My Vendor ID was ### and now it is 179. I can only speak for myself as I've managed to successfully debrand my Curve There are three things to download: 1. VSM file "VSM-09712-002" 2. MML Installation h++p://rapidshare.de/files/45231476/MMLSetup.msi.html 3. MML Data (Torrent Download) h++p://www.mininova.org/tor/2125273 1 Install the MML software onto your computer 2 Copy the additional MML data files to C:\MML - Overwrite all the original files 3 Disable the Internet of your computer 4 Open up MFI and select auto start on and full erase off <-- VERY IMPORTANT!!! 5 Connect your BB Curve 6 Let it do its thing until you see fail on your BB screen and you see "1" on your Curve 7 Unplug your Curve, close and open again MFI and deselect auto start 8 With MFI opened, hold on your computer/laptop keyboard "ctl+shift+alt+f12" and once the hidden menu comes up in MFI, plug in your Curve 9 Hit "Load VSM" and locate the VSM file 10 Its going to say "VSM Loaded Succesfully" in less than a second or two 11 Close MFI, and type "start" using the qwerty on your Curve it will say "No Application Linked Factory OS" 12 Turn on the Internet again and open up Desktop Manager 13 Go on Application Loader and load the OS onto the Curve again |
03-25-2010, 19:23 | #255 (permalink) | |
Junior Member Join Date: Mar 2010
Member: 1261591 Status: Offline Thanks Meter: 1 | Quote:
I downloaded MFI through rapidshare.com (found through google) and have installed it on my machine. When running, the MFI screen comes up but it can't detect my blackberry (there is an instruction to connect the device to begin). Blackberry desktop sees the device OK. Therea re no other buttons or menus,a side from the two for auto-start and full erase, so I'm stuck. The blackberry itself does nothing, it doesn't acknowledge any running process. Does anyone know what's causing this, and how I fix? Blackburn 8700g currently branded UK O2, Windows 7 machine. Thanks | |
Pls I need solution on how to debrand blackberry bold 9700. | Slyassnakes | BlackBerry (RIM) | 0 | 03-19-2010 09:24 |
any solution for unlock blackberry ? | ALGUIEN | PolarBox 3 | 2 | 09-26-2008 07:25 |
any solution for unlocking blackberry pearl ? | TRABEL | BlackBerry (RIM) | 3 | 08-18-2007 13:49 |
