BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
01-13-2009, 16:45 | #91 (permalink) | |
Crazy Poster Join Date: Jan 2008
Member: 670300 Status: Offline Thanks Meter: 6 | Quote:
I want toknow that what vsm ile do I need. I have an att phone which is unlocked and I am using it with tmobile. I checked the vendor I'd on my bold and it says 102 which belongs to Cingular as the phone is from Cingular. So do I need to load the tmobile vsm file because I am going to use it with tmobile or some other vsm file. Also when connected to desktop manager what OS do I load? Where do I get that opeating system? Do I need to delete any file from the OS before I load it or etc etc. Like vendor.xml etc etc. Thanks! | |
01-13-2009, 23:00 | #93 (permalink) | |
Junior Member Join Date: Jan 2009
Member: 945833 Status: Offline Thanks Meter: 0 | you better hilight that one i messed up my BB last nite and made a brick 4 open up mfi and select auto start on and full erase off Quote:
01-14-2009, 00:20 | #94 (permalink) |
Member: 670300 Status: Offline Thanks Meter: 6 | mps3. Thankd for your point. But does anyone know the answer to my question. I have at&t bold unlocked and using with tmobile. But I do not want the att logo when it starts up and also to get the 3g/2g option. So can someone tell me what vsm file shall I use and what operating system to load and where to get it from in step 13. Thanks |
01-14-2009, 02:35 | #95 (permalink) | |
Member: 945833 Status: Offline Thanks Meter: 0 | this was given to me last nite by a good member from BB forums http://www.zshare.net/download/54055211e9ac6430/ Quote:
01-16-2009, 08:21 | #97 (permalink) |
Member: 945833 Status: Offline Thanks Meter: 0 | here is the OS http://www.blackberryforums.com/gene...ilanguage.html |
01-16-2009, 12:21 | #98 (permalink) | |
Member: 945316 Status: Offline Thanks Meter: 1 | Quote:
EDIT: duh, didn't realize it was vend 179. Ok, I've never loaded 179, so can you tell me if when you press ALT + CAP + H do you get help or Engineering Screen. Last edited by baaadandy; 01-16-2009 at 12:26. | |
01-16-2009, 16:20 | #99 (permalink) | |
FOR ANY AT&T USERS: Most at&t people know AMR-HR is way overused on the EDGE network and voice quality suffers. With the Engineering Screen you can force AMR-FR for a much much more satisfying voice experience. Anyone using the VSM-11697-001 can force this by using ALT + CAP + H. | |
01-17-2009, 05:40 | #100 (permalink) |
Member: 670300 Status: Offline Thanks Meter: 6 | Guys I have done it. Now my bold is unlocked and it says Blackberry when it turns on rather than ATT. It has the option now to choose between 2g or 3g or both. Before when it was att branded it it did not had that option as att locked that option. I followed the steps written above. But my steps did not go the as exact as it was written above. After I pl***ed in the bold for the first time with the option AotoStart ON, It read the phone and kept on doing some things on its own. Then it gave me an error and got stuck at the error attached. The error was "Load: MFI -17584-032. Unaable to cast COM of object tpye 'RIMRA" and to the right of it it said big "FAIL" in red. I got scared. But then I looked at the bold and saw that it was saying "NO Application Linked (Factory OS)" When I saw this written on Bold I saw a hope thinking that what if I did not see 1 on my bold and I didint see PASS on my phone atleast I am seeing this "NO Application Linked (Factory OS)" on my phone which I was supposed to see anyway on the phone in step11. So I just continued the steps beyond that to see what happens. SO I followed the next step of loading the OS and boommm the phone was back up debranded. It took some time for the phone to reboot and start but it did. Now follow th links below and the steps as atated by mmlp86. The steps remain the same but I am just giving here the links for the softwares to download. To debrand any blackberry phone the steps are going to be the same but the only thing that will change is the VSM file. So to get the MFI loader follow the link below http://forum.gsmhosting.com/vbb/showthread.php?t=653921 Please follow the steps exactly as written in this post. Please remember if anyone tells you to skip a step dont listen. Its your phone and it will be your brick if any step is skipped. So follow the steps dont be lazy. So once you have downloaded the MFI also download the latest OS (Operating System) for the bold. It can be found in the link below http://www.blackberryforums.com/gene...ilanguage.html Also when you are about to load the OS into the bold do follow the steps 1, 2 and 3. DO not skip any step. Make sure you follow the step number 2 to delete the vendor.xml file for sure. NOw download the VSM file for Bold from the link below http://www.zshare.net/download/54055211e9ac6430/ Now that you have for the MFI loader, the VSM file and the OS system also, follow the steps that mmlp86 posted. Now the steps are given and the links also to donwload the softwares so I believe there shouldnt be any problem. Also make sure you read the below thread also just for your knowledge so that you have a little better understanding. http://forum.gsmhosting.com/vbb/show...&highlight=mfi Take care |
01-17-2009, 05:49 | #101 (permalink) |
Member: 670300 Status: Offline Thanks Meter: 6 | I want to add and make it more clear. Please only follow the steps 1 to 6 when you are downloading the MFI loader. The other instructions after step 6 are used to unlock the blackberry. We are only debranding the phone. |
01-17-2009, 07:47 | #104 (permalink) |
Member: 949227 Status: Offline Thanks Meter: 0 | Also, has anyone debranded an att Bold and tried it with an ATT sim? I understand you get teh 2g/3g option with a tmo (or other) sim, but I have heard even after debranding, if you use an att sim, you get no 2g/3g select option. True? |
01-17-2009, 07:52 | #105 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Still thinking
Member: 139853 Status: Offline Sonork: 100.1590178 Thanks Meter: 46 | i did tried same think as explain here my handset 8800 alredy sim unlock am tried to unlock data part . handset know debrand no t-mobile splash at start-up but still not get edge in capital.. mean can't used internet service? any idea wht to do ? am used vsm file name VSM-09712-002.zip. i tried with othere vsm file also but no lock... |
Pls I need solution on how to debrand blackberry bold 9700. | Slyassnakes | BlackBerry (RIM) | 0 | 03-19-2010 09:24 |
any solution for unlock blackberry ? | ALGUIEN | PolarBox 3 | 2 | 09-26-2008 07:25 |
any solution for unlocking blackberry pearl ? | TRABEL | BlackBerry (RIM) | 3 | 08-18-2007 13:49 |
