BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
01-23-2009, 00:12 | #125 (permalink) |
Junior Member Join Date: Jan 2009
Member: 950432 Status: Offline Thanks Meter: 0 | [quote=HITGSM SUPPORT;4035010]can anyone please explain how to use VSM files with the right phone? and how to know VENDOR ID in our phones? THANKS IN ADVANCE[/quo Finding vendor ID is easy... Alt>crtrl=>H but where is the mapping of vendor IDs to VSM files? (ant vendors)? |
01-23-2009, 11:07 | #127 (permalink) | |
Member: 953910 Status: Offline Thanks Meter: 3 | Quote:
Here is my error >>>> Retrieving the COM class factory for component with CLSID {6EDE3FE5-676E-440B-9C3F-37FAFE8AD799} failed due to the following error: 80040154. | |
01-23-2009, 19:12 | #128 (permalink) |
Member: 950432 Status: Offline Thanks Meter: 0 | 8830 is unlocked but still has Verizon vendor ID. found the ATT VSM file names (number), but get following error message from MML upon loading: "Feature not supported by firmware version command: 0xff40. Can't get confirmation. Cannot query if feature is supported. Cannot set branding info. Cannot load VSM file." Any debugging suggestions? |
01-23-2009, 19:40 | #129 (permalink) | |
Really need your help if you can... thank u so much | |
01-23-2009, 19:43 | #130 (permalink) | |
Did you put your MML folder on C:\MML I have same problem before, because i put it on drive D: | |
01-23-2009, 19:47 | #131 (permalink) |
Member: 953910 Status: Offline Thanks Meter: 3 | Need help.... Did anybody know the VMS file for Telkomsel ( vendor ID 186 ) ? Or is there software to open the vsm file? I manage to rebrand but it goes to another vendor and not my vendor ( i need to rebrand to vendor ID 186 ) Thanks in advance |
01-23-2009, 19:48 | #133 (permalink) | |
01-25-2009, 08:34 | #135 (permalink) |
Member: 945591 Status: Offline Thanks Meter: 0 | Has anyone successfully debranded an 8900? I have a Rogers one that I would either like to debrand or set to AT&T. Can I use the same AT&T VSM that I used to change my Bold from a Vodafone to AT&T? |
Pls I need solution on how to debrand blackberry bold 9700. | Slyassnakes | BlackBerry (RIM) | 0 | 03-19-2010 09:24 |
any solution for unlock blackberry ? | ALGUIEN | PolarBox 3 | 2 | 09-26-2008 07:25 |
any solution for unlocking blackberry pearl ? | TRABEL | BlackBerry (RIM) | 3 | 08-18-2007 13:49 |
