Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 02-17-2015, 05:39   #1 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,975
FAQ}-Blackberry z10 {Hang / Block / 10 Left Password / Red Light } ETC
HI Guys,
I seen in forum always user posting to BB Section about z10 hang on logo , Red light , blocked password Etc problem . So let's me explain here about these problem and solution . Kindly next time before post fellow my solution
Update With BB Link/Autoloader :
You can update your phone with Autoloader Remember you must use your same STL OS (EXAMPLE - STL100-1 ETC). STL version have in your phone back side . So you can download correct OS for your Phone . Also you can update your phone with BB Link Its Online updater , 1st time take long time for Os downloading 2nd time no need long time , Cases you have download already ! Remember Some time unable to detect on BB Link , This case Simple wipe your Phone With CFP ( I already share in below ) Then connect to BB Link !
Hang On Logo / Red light :
  • 1st try to update Autoloader Or BB Link . Remember if you try with Autoloader you must you same STL Version
  • If after update Still hang on logo , your problem is not solve So just wipe your phone with CFP For Blackberry Z10 By AzimBahar Then Update your phone
Password Block/10 Left :
  • 1st you need use CFP For Blackberry Z10 By AzimBahar . This case connecting is impotent . You may connect too way . 1st run WIPE from CFT tools then connect phone and entry password 10 time. If same, Once again Run WIPE and connect phone without battery and entry password 10 time.
  • After wipe update your phone that's it
Impotent note :
  1. If after wipe phone not connect to PC , Then connect battery to phone wait few min
These way tested By me 50 more time
http://forum.gsmhosting.com/vbb/f489...-done-2000413/
__________________
Use the Forum according to Rules...!
Each section has Rules to follow
Cordially,
AzimBahar/ParvezAhmed
The Following 18 Users Say Thank You to aZimBahar For This Useful Post:
Old 02-17-2015, 12:04   #2 (permalink)
Member: 1110430
Thanks Meter: 104
pls ignore the first post.its a mistake.
I mean how do you solve the problem of Q10 red blinking with blocked password.
The password remains 10 attempt even if you enter correct or wrong password?
The Following 2 Users Say Thank You to Dzelailai For This Useful Post:
Old 02-17-2015, 12:16   #3 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Already posted , Did you try my method. I already done many time 10 attempt problem its software issue. you can solve by CFP WIPE But if red light with 10 attempt then if my method fail. So phone hardware failure.
AzimBahar/ParvezAhmed.NET
The Following 3 Users Say Thank You to aZimBahar For This Useful Post:
Old 02-22-2015, 11:34   #4 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Blackberry z10 10 Attempt Left Solution / Password block 10 Attempt
Blackberry z10 10 Attempt Left Solution / Password block 10 Attempt :
Read Details - http://forum.gsmhosting.com/vbb/f489.../#post10870895
Look on the screenshot Its always in 10 Left with Autoloarder , Here show 6 LEFT cases 1st i did try with cfp tools 4 time
lets see here , Its will work with CFP tools
After 10 try entry , you need wait 10 to 15 Min
The Following 7 Users Say Thank You to aZimBahar For This Useful Post:
Old 02-22-2015, 11:38   #5 (permalink)
Member: 2265291
Thanks Meter: 22
If hardware, What is the likely Solution
The Following 2 Users Say Thank You to Gsmidea007 For This Useful Post:
Old 02-23-2015, 05:53   #6 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Post in hardware section , Its may be power section problem !
The Following User Says Thank You to aZimBahar For This Useful Post:
Old 02-26-2015, 01:15   #7 (permalink)
Member: 1007877
Sonork: BoBo
Thanks Meter: 26
what's version about CFP?
Old 02-26-2015, 03:17   #8 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Dont use any other CFP its can be kill Your phone !!!
Use it Only : CFP For Blackberry Z10 By AzimBahar
AzimBahar/ParvezAdmed
Old 02-26-2015, 12:58   #9 (permalink)
Member: 1110430
Thanks Meter: 104
pls can we get link for CFP For Blackberry Q10 and Q5 ?
Old 02-27-2015, 09:50   #10 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
I am always activate in forum . Create your own thread i will reply u with link
Old 02-28-2015, 08:54   #11 (permalink)
dey mobiles's Avatar
Member: 799558
Thanks Meter: 430
Blackberry Z10 Password Block/10 Left
bro can i remove password without user data delete this procedure
Old 02-28-2015, 09:15   #12 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
There is no way without data lost !
Old 03-01-2015, 01:16   #13 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,910
Hello
Only Via Cellebrite Can Read User Code Without Losing Personal Data
__________________
Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums!
The Following 2 Users Say Thank You to Braycel For This Useful Post:
Old 03-02-2015, 13:40   #14 (permalink)
Member: 985933
Thanks Meter: 13
Does this software work for Z-30 ?
Thank you.
Old 03-02-2015, 14:10   #15 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thank you.
Yes You can use it for Zxx
Page generated in 0.25335 seconds with 8 queries
