GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   BlackBerry (RIM) (https://forum.gsmhosting.com/vbb/f489/)
-   -   Fix a Bricked BlackBerry PlayBook Tablet & Updating (https://forum.gsmhosting.com/vbb/f489/fix-bricked-blackberry-playbook-tablet-updating-1848629/)
jamesjerss 08-16-2014 10:45
Unbrick yur playbook using AutoLoader
http://crackberry.com/sites/crackber...ook_white1.jpg
Playbook AutoLoader
* Download Below given Autoloader OS
* Run the Autoloader.exe
* Connect yur playbook to yur pc
* Press power button for 10 to 12 sec nd release
* If yur Playbook detected by pc it vil start the process
PlayBook OS 2.1.0.1753 Download
Guide to update via pc using desktop manager
Download Latest Desktop manger here
Update using Desktop Manager
* Connect the BlackBerry PlayBook to a computer running BlackBerry Desktop Software
On the home screen of the BlackBerry Desktop Software, click Update.
* To download an update, click Get Update.
* To view other available versions of the BlackBerry® PlayBook OS software, click View other versions. If applicable, select another version. Click Install.
* After the BlackBerry PlayBook OS update is complete, disconnect the BlackBerry PlayBook from the computer.
Unbricking Tutorial
Open up BlackBerry Desktop Manager on your Computer
and plug in the bricked PlayBook using the USB Cable.
It will bring up a window that says “BlackBerry Desktop
Software cannot communicate with the connected device.”
and present you with options to “Retry“, “Update“or “Cancel“
http://s27.postimg.org/rcfdqoqsj/BB_...e_with_the.png
If it doesnt bring up this window when you plugged in
your PlayBook via USB, consider unplugging and reconnecting,
possibly to a different USB port, until you hear that familiar
sound your computer uses to indicate a newly connected device.
On the popup window, click “Retry” first, to allow it to attempt
to reboot your PlayBook for you. Be patient as it will take a while.
If after 10 mins and your PlayBook still won’t boot, unplug and reconnect
it again until it opens up the same window described and shown in Step 3.
When presented with the choices to Retry, Update, Cancel, click on “Update” this time.
BlackBerry Desktop Software will open up a new popup window “Confirm device repair“,
and forewarn you of what you’re about to do.
http://s27.postimg.org/fsjqq4wir/image.png
Click on “Repair”. This will then open up a popup window that says “Checking for
BlackBerry Tablet OS Updates“. Duration will depend on computer resources and internet
connection, but it should take only about a minute.
http://s27.postimg.org/3yl6jzd0j/image.png
n some cases, you may be prompted/asked to “Reset your device.”
before BlackBerry Desktop Software can proceed in checking for the OS Updates.
Just follow the instruction provided [as shown in the picture below].
http://s27.postimg.org/lyudod57n/image.png
Once BlackBerry Desktop Software completes the OS Update check,
it will report the latest officially available OS for your PlayBook,
and prompt you to either “Get update” or “Update later“.
http://s15.postimg.org/wyd2db8rf/image.png
Click on “Get update.” This will bring up another
confirmation popup window forewarning you of the duration,
and giving you the option to “Install update” or “Cancel“.
http://s15.postimg.org/jzfuo1dej/image.png
Click on “Install update” if you are totally sure.
BlackBerry Desktop Software will begin the download process,
which can take up to hours depending on your internet connection speed
Once it’s done downloading, BlackBerry Desktop Software will
then automatically extract and install the OS onto your PlayBook,
and then connect to the PlayBook to reboot it
http://s16.postimg.org/mcyphu005/image.jpg
If everything proceeded well, your PlayBook should boot up
mike_shinoda 11-25-2014 08:38
Playbook AutoLoader
PlayBook OS 2.1.0.1917 Download
Unbricking Tutorial
please check link download 2.1.0.1917
I_PHONE 11-25-2014 08:53
plz Help me
http://forum.gsmhosting.com/vbb/f489...rgent-1864655/
salik.iqbal 11-26-2014 11:49
links are not working of files, can you please update it? :(
jamesjerss 11-26-2014 19:39
Autoloader link has been updated
james
Sent from my SM-G900F using Tapatalk
mike_shinoda 11-27-2014 16:52
last ver 2.1.0.1917
http://forum.gsmhosting.com/vbb/10698572-post79.html
jamesjerss 11-27-2014 17:25
Originally Posted by mike_shinoda (Post 10704309)
its not autoloader exe
james
ALI_MAFIA 12-03-2014 05:33
Playbook AutoLoader
Unbricking Tutorial
hello bro i tried both method what you provide but no luck for me. every thing is going well when update processing but playbook not run. when updating only green light. when i plug charger its just show red light and blink after 30 second then again red light.
do you have any salutation for this palybook.
thanks..
cazwj 05-03-2015 07:42
Hell bro my playbook no thal languages ,need uodate thal ,but i found't rom,plz help me,thank you so much
venu_151415 01-10-2016 05:20
hi jamesjerss sir
plz solve my problem how to remove/bypass blackberry id in playbook
thankq....
hariichha 03-27-2016 05:31
Originally Posted by venu_151415 (Post 11537583)
hi jamesjerss sir
thankq....
Need Autoloader for blackberry playbook 32gb and my problem was same remove/bypass blackberry
md6080 04-25-2016 08:20
playbook dead
hi to all i have blackberry playbook dead after power just 5 times green light blinking please help me about that
jony25 09-05-2016 20:39
PB_2.1.0.1753_RADIO_2.1.0.1283 - Download - 4shared
krishna.cell 09-23-2016 10:50
PB_2.1.0.1753_RADIO_2.1.0.1283 - Download - 4shared i will try
mfeliu07 06-25-2020 21:22
Hello
Please i need rapido instaler PlayBook OS 2.1.0.1917
Thanks
mfeliu07
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.16446 seconds with 6 queries
