Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 01-24-2009, 20:33   #1 (permalink)
Member: 948885
Help! Need to clear "activation required" on a Verizon BB Storm..can someone help me?
I found this thread, just wondering if it might work for Verizon??
ok here goes.
Obtain these two programs:
1. uniCDMA
2. Hexworkshop
1. Install your blackberry desktop manager. (Im using version 4.7 and it hasnt given me any problems.) Plug In blackberry.
2. Run desktop manager
3. Minimize DM and run uniCDMA
4. Select "Qualcomm" under the mode drop menu
5. Click setup and change the port to com4
6. Click Read all and it should fill in the boxes on the left with your blackberry information
7. Click HF ->DM
8. Click memory and change the starting address to 0x17c47cce and length to 524288. Click read and save to file.
9. Now open Hexworkshop and open the file you just created.
10. In the right box you will see a 6 digit number. That is your MSL password.
11. Unplug your blackberry and call ##XXXXXX (XXXXXX is the MSL password) Press Send
12. Change the Mobile Directory Number to you 10 digit cell number.
13. Press Menu then close and it will reset your phone and you are good to go.
Hope this helps. Let me know if you have any problems and ill try to help. Im not totally sure if your MSL code will be in the same area as mine so if not let me know and i can find some number adjustments for you.
Old 01-24-2009, 21:15   #2 (permalink)
Member: 530176
If you are using an unlocked Verizon Storm and have "Activation Required" on your home screen or your phone number displays incorrectly, Dial ##000000 (Send). In the Menu add your phone number and select save. The device will reboot and activate.
Old 01-25-2009, 09:43   #3 (permalink)
Member: 933758
Thanks Meter: 2
the original post here is for telus storms. it is used to obtain the MSL password which is needed to remove the activation required on the home screen.
Old 02-08-2009, 10:23   #4 (permalink)
Member: 255811
Hi Buddy,
I have an unlocked Verizon BB storm and am using a GsM from the Middle East. But my phone reads activation required. Please advise
Do I followe the process quoted above? Will this help me activate all servvies?
Thanks a bunch
Old 02-08-2009, 17:28   #5 (permalink)
Member: 933758
Thanks Meter: 2
Originally Posted by stivan View Post
Hi Buddy,
Thanks a bunch
try diaaling ##000000 and then in the top 2 lines type in your 10 digit phone number and then save. your phone will reset and the activation required will be gone. it doesnt activate any services, it just removes that writing at the top.
The Following 2 Users Say Thank You to rolandj For This Useful Post:
Old 02-08-2009, 17:33   #6 (permalink)
Member: 255811
Thanks a ton for the info I shall t ry it.
I cant seem to find the browser on my phone :-( also the Verizon Navigator doesnt load.
How do i search for all of this. Thanks again
Old 05-05-2009, 13:25   #7 (permalink)
Member: 164316
Thanks Meter: 6
how
what number i must add ? because I dont use cdma. thanks in advise
Old 05-14-2009, 23:28   #8 (permalink)
Member: 427492
Hi all,
I made the steps until # 7 ,
nothing seem to happen here!
I don't know why, and I don't know how to continue!
I have a telus, but the sticker under the battery isn't there, so I don't know if it's 9500 or 9530 !
Plz help.
Thanks.
Can someone give me clear picture of modification of cable N95 sharaz191 J.A.F. V-SPEC 2 08-20-2008 18:34
Can someone help me with this as Griffin Team dont seem to answer me pearsonjohnboy MT-BOX 7 12-13-2006 17:15
Help needed to hide a folder on an N70 drkev Nokia Base Band 5 ( BB-5 ) 2 11-10-2006 17:04
Please help....need to unlock the sim on GD55 adir Panasonic 0 05-28-2003 04:33
Help can someone show me where i can down manuel on rolis 477 online 2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-21-2002 01:00
Page generated in 0.20933 seconds with 9 queries
