How to remove an I.T. Policy from a BlackBerry by Subrata 1 Attachment(s) Procedure Step 1 Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again. If you don't have the CD that came with your Blackberry, the Software can be downloaded here. Step 2 Download the file policy.bin and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry). Step 3 Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe on the Device. Step 3 If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest Desktop Manger Software, then the latest Handheld Software. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts. Step 4 Close the Desktop Manager if it is open. Step 5 From the Windows Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to: HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to: C:\Program Files\Research In Motion\BlackBerry\policy.bin Step 6 Open the Desktop Manager. Step 7 Connect the Device. Verification Once complete, the Options/Security screen on your Blackberry should not contain references to an IT Policy, you should now be able to change all settings (including password prompts), and install Third Party Applications. I've used this on my 8700g, & my 8100 Pearl, and it works! ***use as is, and am not responsible for data loss, or BlackBerry / PC corruption! Also, you could get dismissed for doing this! FYI - Removing the I.T. Policy is really more for people that have bought a BlackBerry on eBay or something, and it came with an I.T. Policy and thus they can't install anything...*** The End ! B.R. Subrata G$MBangladesh.kom |
Already posted > point no : 19. how to remove IT policy ? in Blackberry Faq . |
Ok fine. if its double post. I would like to request Section mod to Trash this thread. That is all. Thanks ! |
repost ? no problm ... this s good info must be sticky ....thanks subrata |
Already posted almost 1 year now by me in furious section http://forum.gsmhosting.com/vbb/show...54&postcount=7 |
already^posted by RAMJAN , already tested by me and working 1000% |
Now calculate all of you. which post should removed and which one should stay remain :D |
