Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 11-26-2013, 20:04   #16 (permalink)
Crazy Poster
Member: 1297027
Thanks Meter: 34
how can rebuild imei, i got 9860 red blink fixed, but still problem rebuilding imei, mep0 cable its neccesary?
Old 11-27-2013, 01:35   #17 (permalink)
rogerboogie's Avatar
Member: 103024
Thanks Meter: 616
all process work fine for red blink , but after this imei became corrupted , second tool said unsuported device
this is a half solution
The Following 2 Users Say Thank You to rogerboogie For This Useful Post:
Old 11-27-2013, 02:26   #18 (permalink)
Member: 2072215
Send me the link again, the download file is rosak bro.
Old 11-27-2013, 05:50   #19 (permalink)
Member: 896483
Thanks Meter: 95
any one knows what is the range address for nv file? all qualcomm model
thanks
Old 11-28-2013, 03:59   #20 (permalink)
Member: 126522
Thanks Meter: 10
red blink
pls can you explain how to write imei
Old 11-28-2013, 10:35   #21 (permalink)
Member: 597777
Thanks Meter: 2
Originally Posted by hector bermudez View Post
Phone Not Supported. My pone is 9900
your handheld must be on 'NO APLICATION LINKED"
TESTED BY ME..
The Following User Says Thank You to idris_o For This Useful Post:
Old 11-28-2013, 11:17   #22 (permalink)
Crazy Poster
Member: 1870518
Thanks Meter: 13
Good work bro
But it only work in some few phone.
The Following User Says Thank You to Holatech For This Useful Post:
Old 11-28-2013, 14:17   #23 (permalink)
Member: 1067261
Thanks Meter: 54
yes it will be work for limted fhones that efs not scoured if efs secoured then no work and after eras efs will kill the cdma signal ................
Old 11-28-2013, 14:48   #24 (permalink)
Pablo Velasqu's Avatar
Member: 2074524
Sonork: 100.1627435
Thanks Meter: 137
not perform the process in the hybrids as redblink 9860 9850 or 9930 or those using meid also because the corrupted efs and imei is 000000000000 and meid in
and if you just repair the meid imei and not the same no signal rise since setool does not support it
The Following User Says Thank You to Pablo Velasqu For This Useful Post:
Old 11-28-2013, 17:23   #25 (permalink)
tozbeka's Avatar
Member: 1651733
Thanks Meter: 21
hi broz pls smbdy help me i olrady reset EFS then imei go 004400.15.202000.0 then i make it to NO APLICATION LINKED bt when i repair IMEI still remain with 0044 i evn try to repair with mep cable bt still duing same smbdy guide me plss where i lost
Old 11-28-2013, 21:16   #26 (permalink)
wawan tato's Avatar
Member: 1774307
Thanks Meter: 225
make it sure your handled in No Alication Linked ..
write IMEI with another IMEI phone ...
it can work too, BIS is OK not SUSPEND .. TESTED
Old 11-29-2013, 05:33   #27 (permalink)
Member: 1067261
Thanks Meter: 54
when we erase modem it erased many working secotrs that are casued in cdma fhones damged meid like 000000000,red blink proper salution is not erase modem the proper modem salution is to write modem file only wihtout some perametters like Bsn and imeis.This file we can read only from the proto typs fhones that no have secourty..............
Old 11-29-2013, 08:54   #28 (permalink)
Registered User
Member: 291029
Thanks Meter: 97
EQS Update...
- Remove Read ASK button ("nothing ask file for send,don't send mail for me")
- Fix Rebuild imei still remain with 0044.xxx.xxx
- Added Magic Re-partition 4 & 8Gb
Wait today for upload...
The Following 7 Users Say Thank You to raditya For This Useful Post:
Old 11-29-2013, 11:04   #29 (permalink)
Member: 1067261
Thanks Meter: 54
well if you have real salution of red blink then why you want ppl wast time and kill cdma signal during process erase modem why not you share here only modem files why you want ppl kill first imei and then repair with the tool that is not your creat .........if you realy want to help ppl then here plz shre the repair proper way............
Old 11-29-2013, 20:04   #30 (permalink)
Member: 2074524
Sonork: 100.1627435
Thanks Meter: 137
I changed several imei to 9810 and only up signal to an operator and in my country Venezuela there are three operators with the other two operators never lifts I used imei valid for all types (Hope Floats SOS) that may happen??
Page generated in 0.20966 seconds with 9 queries
